CorkSport.com is MAZDA PERFORMANCE!
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 34
Thread: Blown something
  1. #16
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    581
    I normally do but I took my toolbox out when I got my new bike last week and didn't put it back in haha.
    And I never replaced any of the fuses since I had the car.
  2. #17
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by NaturalFlavored View Post
    I might just replace the ECT anyways...
    That's probably not necessary.
    If the ECT sensor was a problem, it would have blown the new fuse as soon as you tried to start the car.
    Probably a case of leave well enough alone.
    My only concern is why the fuse blew in the first place.
    You may have it blow again.
    (or it was just a crusty old fuse)
    The Diagram Dude
  3. #18
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    581
    Well I looked over the harness and I didn't see any visible exposed wiring, I check from the AC straight down the line to injectors until I couldn't follow it back behind the engine. So I don't know what caused it.
  4. #19
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    I think you're fine but if the fuse is gonna blow again, it's probably gonna happen sooner than later.
    Keep it in mind for the next week or two.
    I think it was just an old fuse.
    It can get brittle over time.
    I've seen fuses where they were full of white corrosion inside.
  5. #20
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    581
    I have fuses in the car now just in case but I will keep an eye out for anything out of the ordinary.
  6. #21
    Registered Member Shamrock 1693's Avatar
    Mazda 323f Hatchback
    Join Date
    Sep 2018
    Location
    Dublin Ireland
    Posts
    21
    Check your dip stick if theres coolant on it its a head gasket problem, if not it could be a faulty water pump or faulty temp sensor if your replacing that you might aswell do the timing belt and full coolant flush aswell just to be safe. Start with the simple stuff before getting elbow deep in a riming belt replacement.
    Ive 2 photos of the temp sensor that needed replacing on mine and the water pump.
  7. #22
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by Shamrock 1693 View Post
    [IMG]
    That's the thermostat, not the temperature sensor.
    The OP had his temperature gauge in his cluster read full hot when the engine was cold due to a blown engine fuse in the cabin which made his gauge give a false reading.
    He never did actually overheat.
  8. #23
    Join Date
    Sep 2018
    Location
    Dublin Ireland
    Posts
    21
    Did i not say thermostat i rushed that reply to try help out, a silly thing like a fuse and we all jump to the worst case of blown head haskets and faulty thermos and fault water pumps
  9. #24
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    No kidding !!
    I wonder how many shops would have sold him a new head gasket and timing belt kit when it was just a blown fuse.
  10. #25
    Join Date
    Sep 2018
    Location
    Dublin Ireland
    Posts
    21
    Can only imagine well over this side of the pond, if your where to replace timing belts and V belts your looking at about 200 euro after VAT and excluding labour.
  11. #26
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    I replaced my timing belt, idler & tensioner pulleys, water pump, thermostat, v-belts, and all associated gaskets for ~ $400 CAD.
    I was quoted $1,600 for the job at a shop. (not including the water pump and v-belts)
  12. #27
    Join Date
    Sep 2018
    Location
    Dublin Ireland
    Posts
    21
    Quote Originally Posted by pcb View Post
    Thats eye watering when a Mazda P5 over here is deemed a banger or a beater and is picked up on irish car sites for 1000 euro. Hard to justify spending 1600CAD-1075. When you can do it at a fraction with a bit of know how.
  13. #28
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    He said the timing belt kit was $800. The rest was labor and I had to supply the water pump.
    This is the price at Rockauto today...
  14. #29
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    ... When you can do it at a fraction with a bit of know how.
    I never would have attempted a timing belt job on my car without the help of the "How-To" instructions provided by this site.
    Thanks Mazda247
  15. #30
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    ..Mazda P5 over here is deemed a banger or a beater and is picked up on irish car sites for 1000 euro...
    That's around the same price as here but they're all rusty turds over here.
    I paid $6,300 for my car in 2009 and did the timing belt about two years later.
    I'm not going to change the timing belt again.
    I'm just going to drive it till the belt snaps then push it off a bridge.
    And yes, my car has been deemed "unfit for resale". (at least I'm allowed to drive it.)
Similar Threads
  1. Blown Turbo? Blown seals? Sad owner.
    By bspeed3 in forum Mazdaspeed3
    Last Post: 01-29-2014, 10:22 AM
  2. Replies: 2
    Last Post: 01-25-2013, 02:51 AM
  3. Another Blown N/A
    By xelderx in forum Mazda How-To
    Last Post: 06-29-2004, 09:42 PM
  4. sub blown?
    By BoostedBlueMSP in forum Mazdaspeed Protege
    Last Post: 02-08-2004, 12:07 PM
  5. JL sub - blown?
    By nate0123 in forum Mazda How-To
    Last Post: 12-20-2003, 08:42 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
