Bikerboysmiler
- Mazda 5 Sport Nav
Hello forum.
I'm a new owner of the 5, loving it so far. But my Bluetooth unit is unresponsive. I have searched the forum and online and not found much strangely.
I got it to respond once after having disconnected the battery and unplugging the Bluetooth module. I foolishly didn't program it immediately because I wasn't expecting it to work (was the following day) and was in a hurry. But it's never worked again since. I've tried to replicate by removing fuse 7 to entertainment system and unplugging the module. But nothing worked.
Strangely the voice control doesn't work at all when the Bluetooth module is disconnected but it works for short hold commands when connected. However it doesn't recognise most commands and just responds with gibberish...
Do I need to reprogram/reset the unit, is it not communicating properly (bad connection) or does it need to be replaced?
I specifically chose this car for the factory Bluetooth rather than fitting aftermarket so I'd like to have it working if anybody can help please.
Thanks
Tyler
Thanks
Tyler
