Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 104
Thread: 2018 CX 5 Low Speed Transmission Hesitation/ Jerk / Lurch
  1. #46
    Registered Member jmhumr's Avatar
    2017 BMW X1
    Join Date
    Oct 2006
    Location
    Reston, VA
    Posts
    533
    For what itís worth, my BMW does this too. I think its just an annoying habit of these turbo-fours tuned with a sporty throttle response. They can probably soften it with a tune, but Iím guessing itíd come at the expense of some acceleration performance.
    I donít think there are enough dots connecting this to CD, especially considering that feature doesnít even come into play until cruising speeds.
  2. #47
    Registered Member
    Mazda CX 5 2019
    Join Date
    Feb 2019
    Location
    Raleigh, NC
    Posts
    2
    Quote Originally Posted by jaggrey View Post
    If we're thinking the cylinder deactivation is to blame, then the next question is are turbo others experiencing this? Cuz I don't believe the turbos have cylinder deactivation.
    Yes, my 2019 GTR does this as well
  3. #48
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,879
    Is the following correct?
    2019 normally aspirated models have CD, the turbos do not.
    Therefore, the NA and T have different engines AND different transmissions.
    Or do the turbos use the same tranny?
  4. #49
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,443
    They both use the same gearbox hardware but whether the settings are the same, you*d have to ask Mazda. They probably do but that is my opinion, not my knowledge..
  5. #50
    Donated: $5
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,879
    Quote Originally Posted by Anchorman View Post
    This is why I asked:
    Quote Originally Posted by yrwei52 View Post
    From available document on cylinder deactivation, Mazda says:
    MAZDAíS NEW CYLINDER-DEACTIVATION OFFERS IMPROVED FUEL-EFFICIENCY WITHOUT SACRIFICING DRIVING PERFORMANCE
    To control vibration caused by cylinder deactivation, the added components with additional software controlling them may cause some side effects making transmission jerking during the low speed.
    I'm just trying to correlate the anecdotes people are reporting with different yrs/models having this problem to find the common factors.
  6. #51
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    81
    Quote Originally Posted by 2001birdowner View Post
    Something that Iím noticing on the 19, that I donít really find on the 16.5 that is more annoying(and concerning) is that it seems confused when going into second under some scenarios.
    Scenario 1:
    light acceleration from a stop, lift off the throttle slightly as it goes into 2nd, then get back on the throttle- the RPMs jump for a second then drop down as it engages into 2nd.
    Scenario 2:
    Slowing down to make a right turn with no stop sign, lift off the throttle, make the turn, get back on the throttle, the RPMs jump for a second then drop down as it engages into 2nd.
    When the RPMs jump, itís around 500 over where it engages.
    If I donít lift of the throttle, the RPMs donít jump. However, it seems like itís a softer shift into second than the rear of the gears.
    Is this what folks are describing in this thread or is it the rough/jerky downshift into 1st when slowly rolling to a stop? My 19 has the jerky downshift into first. I donít notice it on the 16.5.
    What Iím describing in my earlier post above almost makes it feel like the transmission is slipping. Iím also wondering if what Iím expericing is he transmission actually jumping to 3rd instead of 2nd like I thought. If I put it in manual mode, this is not an issue.
  7. #52
    Registered Member
    Cx 5 GT AWD
    Join Date
    Mar 2018
    Location
    So Cal
    Posts
    14
    Exactly what you mentioned in your earlier post..
  8. #53
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,703
    Arrow 2018 CX 5 Low Speed Transmission Hesitation/ Jerk / Lurch
    Yes, cylinder deactivation is only featured on naturally aspirated SkyActiv-G 2.5L since 2018 MY. 2.5T does not have CD. So far every such complaint including OP is from 2018 / 2019 CX-5 2.5L NA with CD.
  9. #54
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,703
    Quote Originally Posted by jmhumr View Post
    But all complaints weíve seen here are from 2018+ MY CX-5 non-turbo 2.5L Touring and GT. So your assumption is irrelevant.
  10. #55
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,703
    Quote Originally Posted by jvar10 View Post
    Youíre the first out of many active 2.5T owners here is having such complaint. You could be experiencing something different like jmhumr described above.
  11. #56
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,703
    Quote Originally Posted by shadonoz View Post
    Based on official Mazda document I posted earlier, Mazda added a fulcrum inside the 6-speed SkyActiv-Drive transmission to fight against the vibration from cylinder deactivation.
    So yes, the transmissions are different between 2.5L NA with CD and 2.5T in addition to different gear ratios and other reinforcements.
  12. #57
    Registered Member PatrickGSR94's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    Aug 2016
    Location
    Memphis TN area
    Posts
    480
    nope, 2014 Touring here. I can feel jerkiness/lurching after backing out of the driveway after a cold start, putting it in Drive and even just pressing the accelerator slightly.
    1994 Acura Integra GSR - 368K miles, a few mods
    2014 Mazda CX-5 Touring - 88K miles, the family hauler!
  13. #58
    Registered Member
    2018 CX-5 GT awd with PP
    Join Date
    Jan 2019
    Location
    CA
    Posts
    12
    2018 GT AWD here. After reversing then going into drive, there is a jerk. Seems to have only started up this winter (cold weather but northern California cold), and from what I remember only on start up after sitting for a while. It doesn't feel like the tranny is slipping, as it engages immediately. It just seems to send too much power as soon as you press the accelerator, then it backs off and behaves regularly. Or maybe there's lock up due to cold. Not sure.
    I haven't had any other tranny issues described in this thread. Except maybe i think this tranny is a bit rough between lower gear changes. But i think that's just the nature of this Mazda tranny, and not indicative of a problem. Simply put, it's not smooth in lower gears as other cars I've driven.
  14. #59
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    81
    I also have a 2.5t wih what appears to be a similar issue. However, I donít have any of the clicking/popping noises.
    Today it happened without lifting off the throttle.
    I was at a stop sign at the bottom of a hill. Light to medium throttle as I accelerated from a stop - when it shifted into 2nd the RPMs jumped a bit before dropping back down and locking into 2nd. This does not seem nornal. Shifts into 3rd and up are crisp.
  15. #60
    Registered Member
    2014 mazda cx-5 touring FWD
    Join Date
    Dec 2015
    Location
    midwest
    Posts
    113
    My 2014 touring has that jerk when cold.It's had it so long I figure it's normal with a cold transmission and the fact that this transmission is programmed (and does) to upshift as much as possible,that it's just upshifting under power when pulling out.My experience is that the torque converter locks up very early and produces a firmer shift than other trannies that have longer converter "slip". Jmaz
Similar Threads
  1. Erratic Transmission jerk
    By Madmazda5 in forum Mazda5 Engine & Transmission
    Last Post: 11-18-2016, 12:29 PM
  2. Auto transmission slip/hesitation in overdrive
    By Beaker99 in forum Mazda5 Engine & Transmission
    Last Post: 07-26-2016, 06:09 PM
  3. Transmission hesitation (?)
    By AZCX9 in forum CX-9 Engine & Transmission
    Last Post: 08-05-2010, 03:56 PM
  4. transmission hesitation
    By hollar1211 in forum Mazda CX-7
    Last Post: 03-12-2010, 12:25 PM
  5. jerk/hesitation when boosting
    By speedprotege_18 in forum Mazdaspeed Protege
    Last Post: 02-19-2010, 08:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
