Page 2 of 9 FirstFirst 1234 ... LastLast
Results 16 to 30 of 121
Thread: 2018 CX 5 Low Speed Transmission Hesitation/ Jerk / Lurch
  1. #16
    Registered Member ceric's Avatar
    2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,331
    Could it be the cylinder deactivation on light load?
    My '17 does not do that.
    Only '18 has the CD.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  2. #17
    Registered Member
    Donated: $5
    CX-5 GT
    Join Date
    Aug 2014
    Location
    Ontario
    Posts
    531
    Our '15 never does this. Perhaps, they have modified the torque converter lock disengagement criteria to make it even more strict. Remember, SkyActiv transmission is much closer to the manual unit then to your average slush box. It unlocks torque converter very reluctantly in any gear, making it a direct drive. And it locks in any gear almost instantly. May be you are experiencing the enhanced direct - drive algorithms that give you benefits of fuel savings at the expense of low-speed, low-torque hesitation. Could be very normal.
  3. #18
    Registered Member
    2018 CX5
    Join Date
    Nov 2018
    Location
    CO
    Posts
    66
    Mine does this. Check out my post in second gear fixed mode. Almost eliminates the problem.
  4. #19
    Registered Member
    2018 Mazda CX-5 GT AWD w/Prem
    Join Date
    Jan 2018
    Location
    Fishers, IN
    Posts
    20
    My 2018 does this as well. I've found that it happens at 4 and 5 mph, so I either go 3 mph or 6 mph+, or just endure it.
    This is a car that (unfortunately) takes some practice to drive smoothly. After a full 12 months I am still trying to work it all out.
  5. #20
    Registered Member
    2018, Mazda, CX-5, Snowflake Pearl, Grand Touring
    Join Date
    Aug 2018
    Location
    Southern Arizona (40 Miles south of Tucson)
    Posts
    136
    Quote Originally Posted by sskali View Post
    Hello Everyone. I have been experiencing unusual transmission behavior at slow speeds in my 2018 CX 5 AWD. In situations where I am slowing down and almost coming to a halt, when I press the gas pedal the car slightly jerks/lurches back and forth. This behavior is especially present when I slow down to make turns or in stop and go traffic. Also at slow speeds, when I lift my foot off the throttle the car slightly lurches. I can hear some kind of knocking or clicking sound when the transmission behaves like this. Could anyone advise me if this behavior is common or something unexpected? I have taken the car to my local Mazda dealer and they say that this kind of behavior is normal for this generation of the CX 5. I would greatly appreciate if anyone could explain this behavior or share their experiences. Thank you very much.
    I've had my 18, CX-5 in the shop for this problem. Mechanic said this is normal due to a "Highly efficient Torque Converter" in the 18+ models.
    I will learn to live with it.
    2018 CX-5 Grand Touring Snowflake White Pearl----2016 MX-5 GT Soft Top Ceramic White Metallic.
  6. #21
    Registered Member
    Mazda CX 5 2019
    Join Date
    Feb 2019
    Location
    Raleigh, NC
    Posts
    2
    So happy that this thread exists! Noticed the exact same thing the second day driving around my new 2019 GTR. I'll probably still take it in to have it looked at, but feeling more relieved that this is a common problem.
  7. #22
    Registered Member
    was 175ps Mazda CX-5 Auto AWD Sport Nav, now 190ps DSG Tiguan 4M
    Join Date
    Oct 2012
    Location
    worksop Great Britain
    Posts
    2,315
    Well my 2015 cx-5 had no jerking, sounds like bull shit from the dealer to me.
  8. #23
    Registered Member
    2018 CX5 SE-L Nav+ 2WD 2.2D 150hp Auto
    Join Date
    Sep 2013
    Location
    Derby UK
    Posts
    412
    Quote Originally Posted by xtrailman View Post
    Hi Xtrailman. You had diesel versions and I had/have diesel versions with no jerking problems. Perhaps the common denominator as all the NA versions will obviously be petrol?
  9. #24
    Registered Member
    2018 CX-5 Touring
    Join Date
    Feb 2010
    Location
    CT
    Posts
    184
    If I had to sum up my 2018 CX-5 transmission I would say, compared to the 2015 it replaced, I am much more aware of the shifting. This includes both accelerating and decelerating. The 2015 was smoother.
  10. #25
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,924
    Any 19 drivers seeing this? Turbo or NA.
    So far it seems to be almost exclusively 18s.
  11. #26
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    81
    I have a 16.5 GT and a 19 GT-R. I find itís more noticeable on the 19 but itís also there on the 16.5.
    Something that Iím noticing on the 19, that I donít really find on the 16.5 that is more annoying(and concerning) is that it seems confused when going into second under some scenarios.
    Scenario 1:
    light acceleration from a stop, lift off the throttle slightly as it goes into 2nd, then get back on the throttle- the RPMs jump for a second then drop down as it engages into 2nd.
    Scenario 2:
    Slowing down to make a right turn with no stop sign, lift off the throttle, make the turn, get back on the throttle, the RPMs jump for a second then drop down as it engages into 2nd.
    When the RPMs jump, itís around 500 over where it engages.
    If I donít lift of the throttle, the RPMs donít jump. However, it seems like itís a softer shift into second than the rear of the gears.
  12. #27
    Registered Member
    Mazda 2017 CX 5 GT
    Join Date
    Jul 2017
    Location
    Baltimore, USA
    Posts
    62
    My 2017 GT two years old and does that jerking thing all the time in the lower gears. When I had only 1500 miles on the car I have addressed this issue with the Mazda dealer. At the time the dealer installed recording device under my dash of my car that records engine and transmission behavior (error codes). Dealer told me to drive with device for 3 weeks, then it was removed by dealer and sent for inspection to Mazda top engineers (Per Dealer). After all inspections the reply from dealer was that *everything in this vehicle performs as designed that includes transmission. Well long story short the car is still lurching/jerking at lower speeds and Mazda not willing to admit that there is a problem and with my luck the transition will break when the car warranty runs out.
  13. #28
    Registered Member
    2014 Mazda 6
    Join Date
    Mar 2016
    Location
    South Florida
    Posts
    46
    2018 CX 5 Low Speed Transmission Hesitation/ Jerk/ Lurch
    Hey just saying ďme tooĒ.... haha. My wifeís 2018 Touring does this as well. My 2014 6 doesnít. I notice it more when I drive. She never noticed it until I was driving her car, so maybe it has something to do with our driving styles as well.
  14. #29
    Registered Member
    Cx 5 GT AWD
    Join Date
    Mar 2018
    Location
    So Cal
    Posts
    14
    Hey guys. To find out more about this issue, I was looking to test drive a similar CX 5 to mine. Luckily, a dealer had a used '18 CX5 AWD on their lot. When I drove the car, I could hear the same noise when slowing down and accelerating especially at 90 degree turns. The transmission/ torque convertor makes the same clicking noise. In a way, I am relieved that its not just my car doing this. My CX3 doesn't have this issue at all. Hopefully, there is a fix for this issue.
  15. #30
    Registered Member PatrickGSR94's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    Aug 2016
    Location
    Memphis TN area
    Posts
    501
    Our 2014 does something like this, when backing out of the driveway and then putting it into Drive when everything is still cold. I try to be as gentle as possible and only touch the pedal after the car starts moving forward.
    1994 Acura Integra GSR - 368K miles, a few mods
    2014 Mazda CX-5 Touring - 88K miles, the family hauler!
Similar Threads
  1. Erratic Transmission jerk
    By Madmazda5 in forum Mazda5 Engine & Transmission
    Last Post: 11-18-2016, 12:29 PM
  2. Auto transmission slip/hesitation in overdrive
    By Beaker99 in forum Mazda5 Engine & Transmission
    Last Post: 07-26-2016, 06:09 PM
  3. Transmission hesitation (?)
    By AZCX9 in forum CX-9 Engine & Transmission
    Last Post: 08-05-2010, 03:56 PM
  4. transmission hesitation
    By hollar1211 in forum Mazda CX-7
    Last Post: 03-12-2010, 12:25 PM
  5. jerk/hesitation when boosting
    By speedprotege_18 in forum Mazdaspeed Protege
    Last Post: 02-19-2010, 08:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
