CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 9 of 9
Thread: Blown head gasket - need new head - Protege same as P5?
  1. #1
    Registered Member
    Mazda Protege5 2002
    Join Date
    Feb 2019
    Location
    Portland, OR
    Posts
    4
    Hey All, blown head gasket on my P5 from a prior radiator torque and leak. It took a year to blow after I tested the head gasket for leakage hot, warm and cold and got a negative leak test until she did a hard blow. There's no antifreeze in the crankcase, but I'm preparing to replace the head with one from pickn'pull. They've only got Protege and no P5's - are these heads the same across the '02 - '03 spectrum? It looks like they are 2.0L across all models from '02 - '03.
    Any pitfalls to look out for? I see engine mounts as one potential and will buy new head bolts. somebody mentioned block warpage in an earlier thread, but that doesn't seem like that would be very common.
    I've changed an engine and a tranny and have done 3 heads in Toyota Corolla's, so understand about getting the cams lined up properly, ist's just been a few years.
    Thanks for the feedback!
  2. #2
    Registered Member
    Mazda Protege5 2002
    Join Date
    Feb 2019
    Location
    Portland, OR
    Posts
    4
    Read another post where someone said Mazda thermostats are crap. Is this the location? Or the quality? Options? The thermostat didn't really register initially that the engine was hot until it was quite dry due to the torque in the radiator.
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    The temperature gauge in our P5 is a dummy gauge.
    It is controlled by the ECU and doesn't start to move above the halfway mark until the engine temperature is really hot.
    Almost to the the point of there being engine damage before it starts to move.
    The Diagram Dude
  4. #4
    Registered Member
    Mazda Protege5 2002
    Join Date
    Feb 2019
    Location
    Portland, OR
    Posts
    4
    Quote Originally Posted by pcb View Post
    Almost to the the point of their being engine damage before it starts to move.
    Is there an under dash fix for that in an unused sensor hole? This blow out pushed out most of the coolant. The radiator was new, don't know if I should buy another?
    Suggestions?
    Thanks
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    You could install a separate temperature gauge and sensor on your car.
    A bunch of guys have done it and there's lots of ways a to install the gauge.
    You could even install a cellphone or iPad along with the torque app and an Elm 327 reader and it will show you everything all your sensors are reading, including accurate engine Temp info.
    Your radiator should be fine because the coolant would have blown past the rad cap to keep the pressure down. (the rad cap is rated for 13.5-17.7 psi) although I don't know what you mean by "torque in the radiator" ??
  6. #6
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    If by "torque in the rad" you mean that your engine is bouncing around so hard that it's pulling on then rad hoses, the you could have damaged your input and output connections on the rad.
    Did your car overheat first and blow through the overflow tank or did you spring a leak somewhere first then overheat ?
    You could pressure test your rad to see if it's holding proper pressure.
    Replacing your rad hoses may be a smart idea.
    Replacing your engine mounts will help relieve the stress on the rad connections and hoses.
    The front and two side engine mounts are easy to replace. The bottom mount is a PITA. You would probably be good enough with just the three easy ones being replaced.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Quote Originally Posted by RedRunner View Post
    ... it was quite dry due to the torque in the radiator.
    I was thinking someone put torque in your rad... lol
  8. #8
    Registered Member
    BJII Astina SP20
    Join Date
    Apr 2016
    Location
    Australia
    Posts
    205
    Does the US have the 1.8 FP Protégé?
    If so then I have read the 1.8 FP head is a bolt on fit on the FS 2.0's, which will give a slightly higher compression, which results in mo powa!!
    The US FS 2.0 had a very low compression ratio to begin with when compared to the Euro/Jap/Australian FS 2.0.
  9. #9
    Registered Member
    Mazda Protege5 2002
    Join Date
    Feb 2019
    Location
    Portland, OR
    Posts
    4
    [QUOTE=pcb;6631671]I was thinking someone put torque in your rad... lol
    No, I rear ended a MB SUV and all it took out was my hood and the upper tie bar. The adjuster said he wouldn't be surprised if the radiator blew somewhere down the line because of the torsional offset to the radiator. I didn't believe him, but kept my eye on it for a few months with no issues, but then it went slowly enough that I didn't notice the leak further down the road. It ended up being two quarts low and I did the leak test for the radiator, but it didn't show a blown head gasket cool, warm or hot - the head was good for another 6 months, then blew.
    Thanks!
Similar Threads
  1. Blown radiator, head, head gasket
    By Jayeb123 in forum CX-5 Engine & Transmission
    Last Post: 02-12-2016, 09:13 AM
  2. blown head gasket
    By patricklcm in forum Protege5
    Last Post: 10-16-2011, 04:28 AM
  3. just hit 20,000 mi! blown head gasket :(
    By NYXphil13 in forum Mazdaspeed3
    Last Post: 05-18-2011, 10:38 AM
  4. Blown Head Gasket in my GTX?
    By mathblaster in forum Other Mazdas
    Last Post: 06-09-2008, 10:57 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
