Results 1 to 9 of 9
Thread: AWD Logic
  1. #1
    Registered Member
    Join Date
    Feb 2018
    Location
    WV
    Posts
    3
    AWD Logic
    My wife has a 2016.5 CX5 Touring. AWD is an absolute must for us here in WV and the road to our home can be quite gnarly when it snows. A few weeks ago we had a significant snowfall here, 10"+. The CX5 could not make it to our home even with General Altimax Arctics at all four corners. The AWD light would flash and the system would disengage the rear differential resulting in total loss of forward progress. Has this software logic been changed in newer CX5's? Her previous Jeep Patriot navigated deep snow with ease. We were very disappointed in the performance of the Mazda system the very first time it was tested.
  2. #2
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,827
    Is this a used car, new to you?
  3. #3
    Registered Member
    Join Date
    Feb 2018
    Location
    WV
    Posts
    3
    It's a lease. We are in our 2nd year with the vehicle.
  4. #4
    Guest2019C20
    Guest
    The AWD light blinks to indicate overheating of the diff clutch.. Excess slippage at the tires. Too much throttle for conditions, maybe. It's not a rock-crawler, it's not intended to be driven in deep, heavy snow, where the bottom drags.
    You need to drive fast enough to avoid bogging down, and should have tires intended for deep snow, like Blizzaks.
  5. #5
    Registered Member
    Join Date
    Feb 2018
    Location
    WV
    Posts
    3
    Have you seen Altimax Arctics? More aggressive than any Blizzak. I understand what the light means but I feel the system "protection" is too intrusive too soon. It's not like I was sending 12' white rooster tails in the air. I'm comparing the vehicle's performance to previously owned vehicles equipped with the same tires on the same road in nearly identical conditions. This will be the deciding factor whether we lease another Mazda or go with another manufacturer. So, is this still the operational logic in the current MY CX5?
  6. #6
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,757
    Blog Entries
    6
    OP: That is not normal.
    I have never seen my AWD light come on before and have taken my CX-5 in lots of snow. That indicates temp issue or other fault. I would check to make sure it doesn't have a low fill of rear diff fluid. Mine stock was low.
    You can view rear diff temps with the Forscan App
    https://www.forscan.org/home.html
    '15 CX-5 GT 2.5L w/tech package - 49K Miles / '07 Infiniti G35x / '12 Lexus GX 460 / '00 Wrangler TJ 4.0L
  7. #7
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    887
    Quote Originally Posted by Kedis82ZE8 View Post
    I second this. It seems that Mazda felt that they didn't need to fill the differential to capacity. Most everyone who has checked has found that the rear differential wasn't filled to capacity.
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
  8. #8
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,710
    Agreed. I have likewise driven mine through deep snow, and with proper tires, it was a tank. I have never had the AWD light come on in mine. Only time I've ever slipped and slide was when I needed new tires.
    I'll echo what others have stated and have your rear differential checked, OP. What you describe does not sound normal to me at all.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 81k miles
    01/2013 build | 4/20/2013 delivery
  9. #9
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,448
    Quote Originally Posted by toyotechwv View Post
    I have the same vehicle, and have never seen the AWD light on or flash for that matter. It does not sound like there is a problem with the logic, it seems as if there is a fault in your system. Most likely with the electromagnetic coupler-clutch assembly.
Similar Threads
  1. Q Logic 2 10" sub box
    By neoturner in forum Global
    Last Post: 05-03-2006, 11:50 PM
  2. FS: Rockford 12' Sub and Q-Logic BP Box
    By Protege52003 in forum NEMOC
    Last Post: 04-07-2005, 08:06 AM
  3. Pretzel-logic
    By SpicyMchaggis in forum Lounge
    Last Post: 01-01-2005, 12:41 AM
  4. FS: 12' Logic BP box w/RF Z sub
    Last Post: 08-23-2004, 07:36 PM
  5. How is using a Q-logic pre-fab box for a JL W6 v2?
    By LazerBlueP5 in forum Mazda How-To
    Last Post: 12-26-2002, 11:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
