Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: $300 for plugs - really??
  1. #1
    Registered Member
    2013 CX-5 GX MT
    Join Date
    Jul 2012
    Location
    BC, Canada
    Posts
    10
    My 2013 (May 2012) CX-5 is at 110,000km and plugs are due at 120. The dealer said $300 (Canada) to change them. Is it really that big a deal? I know the plugs are a little spendy, but that still seems like a lot in labour. How long does it really take? I no longer have a built in mechanic. My dealership has always been good to me, and I've never done anything to my car besides regular maintenance. My brakes are down to 3mm all round, and that will apparently be $650 plus tax, which hurts when I'm used to just paying for parts, but seems reasonable. I've always preferred OEM parts on my vehicles, but am thinking of buying the OEM parts and finding someone else to do the plugs. I did my own many moons ago on my B2200, but I no longer have access to tools or somewhere to work.
    thanx :-)
  2. #2
    Registered Member
    16.5 CX-5 GT AWD w/Tech BRMica
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    1,948
    $300 is highway robbery, RUN!
    It*s a 10 min job for me, 30 min or less lolly gagging around and shooting the Pooh.
    $650 on brakes is ridiculous too. Especially if all they*re doing is changing pads and turning rotors.
  3. #3
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    97
    thats about 225 usd. not that bad.
    spark plugs are around 130usd MSRP for 4 in US dealers (not counting discounts). They are iridium sparkplugs. usually denso and cost more than your usual 2000-s car sparkplugs.
    95usd for labour is not that bad. Assuming there is tax also included in total.
    p.s
    you can change yourself if you want or buy them discounted and find a shop to only change... or may be ask dealer to price match internet prices of online mazda dealers on the sparkplugs.
    do note you have driven 100km and 6 years with only basic maintenance.it is normal for these things to come up now.
  4. #4
    Registered Member
    CX5 2.5L AWD
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    6,627
    Quote Originally Posted by riffraff View Post
    thanx :-)
    I did my own plugs. $120 usd from the dealer.
    I had the dealer do my brakes. $650ish for all 4, parts and labor included, including replacing all 4 rotors completely with new. From 3mm to 1mm took another nearly 20k miles, as I recall...
    My plugs looked new regarding gap, and changing them resulted in zero change to mpg or driveability, dont at around 80k something miles or so.
    Changing plugs took me about 10 to 15 minutes and was easy and self explanatory. That is the first time I had the engine cover off. $95usd for that is a damn robbery.
  5. #5
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    325
    My guess is you're somewhere in the range of $40-$50 / plug plus $~100-$120 / hr for labor. Probably an hr or a min shop charge coming in to play for the plugs.
    Sounds about right for dealer sourced OEM parts and dealer labor.
    If you're out of warranty you have the option of buying the parts elsewhere and doing them yourself. Or having a non dealer mechanic do them with non-OEM plugs. Or... if it's still running fine let them go a bit longer.
  6. #6
    Registered Member
    2014 Mazda CX-5 GT AWD w/Tech
    Join Date
    Aug 2013
    Location
    Bloomington, Minnesota, USA
    Posts
    547
    This has all been hashed out before on this thread: https://www.mazdas247.com/forum/show...ighlight=plugs
    It boils down to 2 camps: those who insist that the OEM Mazda plug is the ONLY plug to use and those who believe that the NKG and the Denso plugs are exactly the same as what Mazda uses but without the Mazda logo on the plug.
    I am in the second category and here is what I bought: https://www.amazon.com/NGK-94124-ILK...r=1-1-fkmrnull
    They were simple to put in. You only need a socket wrench, two sockets and a 10-12" extension: one socket to remove the coil to get at the plug and then a spark plug socket to remove/replace the plug. The spark plug socket however is different than most and will probably require a purchase.
    Take your time and it should only take 30 minutes max. The plugs are pre-gapped and unless you drop one you can just install them right out of the box. You only need access to work under the hood to change them - no need for a big work area.
    The ones I installed have the exact same markings as the Mazda plug and have been flawless, the same as the ones I took out.
    It boils down to how much you value your time and money. It's a simple task to perform, but it's up to you.
  7. #7
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    120
    ^I agree. It was super simple. I even used some old rubber tube about 12Ē long to help thread the new plugs in. Pop some thick rubber tube of appropriate width over the stem of the plug. Spin the tube gently to get the plugs started to prevent stripping the engine threads. Pull the tube off and out and finish with the appropriate socket. Deep socket was the only thing I had to buy for the job as I had all of the other tools mentioned.
    I used Denso plugs. Car runs fine with them. My gas mileage might have dropped a mile or two per gallon, but I think winter gas is true cause. I happened to install the new plugs literally the same week winter gas made it here. Iíll hold final judgement until this summer. If I donít see my gas mileage creep back up to what Iím accustomed to, Iíll swap them for NGK plugs and call the $28 I spent on the Denso plugs an experimental loss, lol.
  8. #8
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    4,157
    Get the NGK plugs (the OEM plugs I ordered from Med Center Mazda for $100 had the NGK model numbers on it!) for $50. Take 30 minutes and do it yourself.
    Problem solved.
    2014 CX-5 Touring AWD | Jet Black Mica - 78k miles
    01/2013 build | 4/20/2013 buy
  9. #9
    Registered Member jmhumr's Avatar
    2017 BMW X1
    Join Date
    Oct 2006
    Location
    Reston, VA
    Posts
    456
    Quote Originally Posted by ColoradoDriver View Post
    Problem solved.
    Yep, a novice can change spark plugs and save a lot of money. If you can change a light bulb, you can change your plugs. Just need a socket set with an extender, which is cheap. I'm sure there's a Youtube how-to for the CX-5.
  10. #10
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,274
    Quote Originally Posted by jmhumr View Post
    ...and a torque wrench.
  11. #11
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,139
    Arrow $300 for plugs - really??
    Problem solved.
    On OEM spark plugs you got, is there "Mazda" imprint on it with part number, other than NGK part number?
  12. #12
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    4,157
    Quote Originally Posted by yrwei52 View Post
    Yes of course...which added $50 to the price.
  13. #13
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,139
    $50 additional for 4 plugs with *Mazda* name only, or *Mazda* name and Mazda part number?
  14. #14
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    4,157
    I'll have to go dig up the pictures I posted in that spark plugs thread.
    If I recall, it had the Mazda logo and part #, but also had the NGK part #.
    As far as I could therefore tell, it was NGK plugs that Mazda printed their name and part number on and jacked the price up $50 (for 4).
  15. #15
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,139
    Our manual listed two OEM spark plugs, PE5R-18-110 and PE5S-18-110, for SA-G 2.5L. Anchorman once posted a parts document from Mazda which clearly stated OEM spark plug PE5R-18-110 is NGK plug and PE5S-18-110 is Denso.
    Although I always use OEM parts, but for this one I may consider NGK to save $50!
Similar Threads
  1. F2 Balance shaft delete & Ngk plugs Plugs
    By Darksun280 in forum Completed Transactions
    Last Post: 03-30-2009, 08:07 PM
  2. Replies: 0
    Last Post: 12-11-2008, 01:46 PM
  3. F/s Ngk Plugs
    By uncletime in forum Completed Transactions
    Last Post: 11-04-2008, 10:22 AM
  4. Plugs and oil...
    By bumpin_p5 in forum Protege5
    Last Post: 12-07-2006, 08:09 PM
  5. These Are The Right Plugs Right?
    By carter1551 in forum Protege5
    Last Post: 09-03-2006, 01:49 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
