Results 1 to 4 of 4
Thread: 2018 Cx5 GT lack of power very weird issue!
  1. #1
    Registered Member
    2018 cx5 GT
    Join Date
    Feb 2019
    Location
    BC Canada
    Posts
    52
    Today when I went onto the highway to go uptown about a 15 min drive. I went to floor it to pass someone and the car bearly accelerated it felt like it was down about 100 hp it just seemed to rev up so slow also no check engine lite on either. When I go to a stop sign I floored it again to see and it went so slow and when it shifted it jerked ahead pretty hard. Just seemed to labour bad. Went to my appointment and same thing on the way home.
    When I went out about half hour later to go shopping it was perfect again thing pushed me back into the seat like normal. Anyone had this problem or if there is any tsbs? Iíll tell the dealer when I go in next week also to get my new motor mount replaced from freezing up and see if they find anything.
    Thanks
  2. #2
    Registered Member
    2018 cx5 GT
    Join Date
    Feb 2019
    Location
    BC Canada
    Posts
    52
    Seems ok today again. Maybe they will find some codes ? Possibly a pcm update will see.
  3. #3
    Registered Member
    2018 CX-5 Touring
    Join Date
    Feb 2010
    Location
    CT
    Posts
    182
    Replied in lounge. Will watch here instead.
  4. #4
    Registered Member
    2018 cx5 GT
    Join Date
    Feb 2019
    Location
    BC Canada
    Posts
    52
    Ya it was weird it just felt like the car was missing about 100 hp. Going up a medium grade up to my appointment on the highway. Punched it at 90km and it took about a minute before it got to 100 just reved away and not much happened. normally it takes about 5 seconds on the same stretch. It was weird way down on power. Mind you it*s been very cold and my engine was vibrating from the frozen motor mount which I*m getting replaced Tuesday. Maybe the knock sensor was affected and pulled power? When I went back out it was smoother and warmer out mount must have thawed out and power was back to normal. Vibration was for about a week and a half very cold here. First time I punched it was yesterday so who knows. I*ll get them to check codes and tsbs when I*m in also.
Similar Threads
  1. 626 V6 lack of power
    By andrew626 in forum Other Mazdas
    Last Post: 02-19-2011, 10:07 PM
  2. Premacy 2.0 TD 16V PD Lack of Power
    By ikrasniq in forum Mazda5 Engine & Transmission
    Last Post: 10-15-2009, 08:03 PM
  3. Lack of Power TSB without warranty
    By alias747 in forum Mazda6 Engine & Transmission
    Last Post: 11-07-2008, 08:09 PM
  4. Lack of Power?
    By Rikatomika in forum Mazdaspeed Protege
    Last Post: 01-22-2007, 04:31 PM
  5. Lack of power
    By jayka in forum Protege5
    Last Post: 08-18-2003, 04:47 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
