Results 1 to 10 of 10
Thread: Can't get service icon to turn off 2017 CX-5 GT
  1. #1
    Registered Member
    2017 CX-5 GT
    Join Date
    Jan 2018
    Location
    ON
    Posts
    31
    So for the second time since we've owned it, the service "wrench" icon turned on in our CX-5 for no apparent reason, and I can't get it to shut off. I have all the maintenance reminders (tires, oil, etc) set to off. I even went and turned them all back on, reset them, and then off again with no luck. Any thoughts?
  2. #2
    Registered Member
    2017 Mazda CX-5 Grand Touring
    Join Date
    Jul 2017
    Location
    Wisconsin
    Posts
    268
    Quote Originally Posted by Maximum_Effort View Post
    Did you check the manual? Otherwise, give Mazda service a call and ask them.
  3. #3
    Registered Member maz5188's Avatar
    2017 CX-5 AWD GT with TECH package
    Join Date
    Oct 2018
    Location
    Canada
    Posts
    16
    i have my service reminder disabled from settings...but, after you went to service at dealer, they turn it back on again, so i turn it back off.
    good luck.
    or you can make the date or Km higher than it set there...
  4. #4
    Registered Member
    2017 CX-5 GT
    Join Date
    Jan 2018
    Location
    ON
    Posts
    31
    Finally figured it out.
    To make the service wrench icon go away, get in the car but do not turn it on. Press and hold the dash light brightness controller (as if you're resetting the Trip A/Trip B ODO to 0). While still holding the dash light brightness controller, hit the start button twice without your foot on the brake (do not start the car). Keep holding the brightness controller until the wrench icon starts flashing, then let go. At this point, repeat the Cyrillic alphabet backwards. The next step requires a chicken and a good knowledge of Santeria. Get a plastic drop sheet; it gets messy.
    For the record, I had reset AND turned off all the service reminders via the so-called touch screen which did nothing to make the icon go away. You have to go through this obscure song and dance to get the icon to turn off. Left hand, meet right hand...
  5. #5
    Registered Member
    2018 Mazda CX-5 GT
    Join Date
    Jan 2019
    Location
    Chicago Suburbs
    Posts
    20
    See your dealer - there's a TSB on this (TSB NUMBER: 09-037/18) for the 2017-2018 Canadian spec CX-5s. There's a software update to correct the problem - sounds like the fix also allows future resets to be done using only the Maintenance Monitor.
  6. #6
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    325
    happened to mine too once and I had to do the same reset procedure. I don't know if I had anything reprogrammed but I haven't had to do it in a while.
    It's caused by a disconnect between the gauges and the CMU. The process you outlined resets the gauge cluster side of it.
  7. #7
    Registered Member gdluke's Avatar
    2018 Mazda CX-5
    Join Date
    Mar 2018
    Location
    Sacramento, CA
    Posts
    78
    Same here last time I did my 2018. It was bugging me because resetting in the maintenance settings screen did nothing, but I see eaestrom mention that after a software update the maintenance screen reset works. I wonder if he's referring to the NA_70.00.021x firmware update for android auto/carplay
  8. #8
    Registered Member
    2018 AWD GT Premium Red/Black
    Join Date
    Feb 2017
    Location
    WA
    Posts
    564
    Quote Originally Posted by gdluke View Post
    I have the Android Auto update. I did my first oil change (2nd for the car) and reset everything in Mazda Connect. Now periodically when I start the car I get a "Service Overdue" message that stays up for 10 or 20 seconds and then goes away. I've reset and then disabled service reminders in Mazda Connect. After the overdue message goes away the display shows the appropriate miles to oil change and such.
  9. #9
    Registered Member
    2007 Mazda 3 5-door
    Join Date
    Dec 2018
    Location
    Western US
    Posts
    63
    Hmm, brand new 2019 GTR here and I am getting “maintenance due soon” on the screen every time I start up. I mean WTF, it’s 6 weeks old with 700 miles on it. Maintence due, really? Gotta be a bug.
    Is this reset procedure real and will it mess up my *real* maintenance schedule?
  10. #10
    Registered Member
    2018 Mazda CX-5 GT
    Join Date
    Jan 2019
    Location
    Chicago Suburbs
    Posts
    20
    The OP lives in Canada. The TSB applies to 2107-2018 Canadian spec vehicles:
Similar Threads
  1. 2017 CX-5 GS - Can you really not turn entertainment off?
    By The Guardian in forum CX-5 Infotainment
    Last Post: 04-07-2018, 04:50 PM
  2. Turn Signals on 2017
    By Pipemajor in forum CX-5 Lounge
    Last Post: 02-08-2018, 10:44 PM
  3. How to turn radio off in 2017 CX-5 GT Premium?
    By Lynn in forum CX-5 Infotainment
    Last Post: 09-07-2017, 02:18 AM
  4. How to turn screen off on 2017 CX 5
    By junamuan in forum CX-5 Lounge
    Last Post: 08-25-2017, 07:18 PM
  5. [2016 Probably 2017] Turn engine off only
    By 7eregrine in forum CX-5 Lounge
    Last Post: 07-07-2017, 04:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
