Results 1 to 9 of 9
Thread: I'm actually grateful for my TOMS not showing me individual tire pressure
  1. #1
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,892
    This is simply annoying as shit. The other one is at 32. Why isn't it "low"? Same in the second picture. Why isn't the other one "low" at 33. At one point 3 tires had the same pressure. Only the front driver's side is "low". Stupid yellow light constantly on.
  2. #2
    Registered Member Moonlighter's Avatar
    CX5 Akera 2.2 Diesel
    Join Date
    Nov 2016
    Location
    Redlands, Qld, Australia
    Posts
    433
    It appears that all 4 are low, because it states to inflate to 36. I would put *em up to 38/40. But thats here in summer temps.
    Probably the front left reached the threshold of 2psi lower than any other or 32 first, and thus triggered the warning light? One way or another, the system has got your attention hey!
    Regardless, they should all be pumped up to at least 36.
    What does the manual say?
  3. #3
    Registered Member
    2018 CX5
    Join Date
    Jul 2018
    Location
    United States
    Posts
    114
    Where do I find individual tire pressures in my 2018 CX-5?
    But to answer your question, it likely highlights the first one that came up low as low.
    What I always do is keep the tires 2 psi above the recommended level. That gives you some cushion if the temps drop, improves MPG since it lowers rolling resistance, and improves handling!!
  4. #4
    Registered Member
    2019 Mazda CX-5 Signature; 2017 Mazda MX-5 RF/GT/LE
    Join Date
    Jun 2016
    Location
    Austin, TX
    Posts
    358
    Quote Originally Posted by CX5Nut View Post
    Individual tire pressures are NOT displayed in the '17 -- '19 CX-5.
    Since the picture is of a different vehicle display that is unfamiliar to me; my guess about the single "low" warning is similar to the one you offered.
    2019 Soul Red Crystal Metallic CX-5 Signature
    2017 Machine Gray Metallic MX-5 Miata RF/GT/MT Launch Edition
    2019 Racing Orange MX-5 Miata RF/MT 30th Anniversary Edition on order
    27 Mazdas since 1974
  5. #5
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,892
    A) The Mazda gets my attention just fine as well. I don't need specifics.
    B) Its going up to 45 today. 50 on Monday. There's no way I'm filling these to 36. There were only that low because it was 14.
    2016: Cherokee
  6. #6
    Registered Member
    2018 AWD GT Premium Red/Black
    Join Date
    Feb 2017
    Location
    WA
    Posts
    639
    That is a crap interface but I still want to know the individual pressures. Either is fine to detect a reduction in pressure that occurred slowly. There's a big difference between being at 28 and being at 15 psi. The former I will go about my business until it is convenient to change unless I see it visibly going lower. The latter I will try to take immediate action.
  7. #7
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,892
    And, of course, all warnings went away when the temps came up.
  8. #8
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson
    Posts
    1,827
    Cherokee complains at 33, only 3 psi low? Harsh!
  9. #9
    Registered Member
    2017 CX-5 GT AWD
    Join Date
    Dec 2017
    Location
    OH
    Posts
    835
    Some cars have higher tire pressure on front wheels then rear as required.
    But remember the TPMS is still a dumb system - whatever you set the tire pressures too when you train the system or set the baseline, is what it will alert on. You could set all tires to different numbers and make the baseline, and when any one deviates by some built in amount, the alert will occur.
    The car doesn't know anything about the sticker on the door. You could make 10psi your baseline all the way around if you wanted too.
    EDIT - I should add, that not all are like this, but most TPMS I have run across allow to retrain at whatever pressures you like.
Similar Threads
  1. 215/35/18 on RX8's Tire pressure
    By livetoride in forum Mazda Protege
    Last Post: 04-12-2010, 10:07 PM
  2. Tire Rack showing the protege some love
    By darkane23 in forum Mazda Protege
    Last Post: 10-27-2008, 04:41 PM
  3. Tire Pressure?
    By Sliver5 in forum Protege5
    Last Post: 06-02-2007, 02:24 PM
  4. Tire/tire pressure setups for Auto-X???
    By FrozenMazda in forum Mazdaspeed Protege
    Last Post: 06-20-2005, 02:17 PM
  5. Tire Pressure
    By TurboMan in forum Mazda Protege
    Last Post: 10-06-2003, 10:04 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
