Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: No Chatter About The G-vectoring Upgrade
  1. #1
    Registered Member gdluke's Avatar
    2018 Mazda CX-5
    Join Date
    Mar 2018
    Location
    Sacramento, CA
    Posts
    78
    So, I’ve seen a lot of chatter about the new 2.5T engine and how nice the added power makes the car. I do feel like the base engine lags before you actually get a slight power jolt. I however haven’t seem much talk about the new 2019 G-vectoring system upgrade. Any thoughts or inputs about the new suspension for those that have it? On the 2018 the suspension feels fine and sporty, but you definitely feel the pull around turns if you get on it.
  2. #2
    US Specs in Europe boandlkramer's Avatar
    '17 CX-5 GT AWD; '18 BMW X3
    Join Date
    Apr 2015
    Location
    Bayern, Deutschland
    Posts
    1,146
    Hasn’t g-vector been on them since 2017??
    -2017 Mazda CX-5 Grand Touring Soul Red Premium
    -2018 BMW X3 xDrive30i Phytonic Blue - ZCV, ZDA, ZPK, ZPP
  3. #3
    2018 Mazda CX-5
    Join Date
    Mar 2018
    Location
    Sacramento, CA
    Posts
    78
    It has not, 2018 and older are plain G-vectoring. Apparently there was an upgrade to the suspension, and it is now called G-vectoring Control Plus.
  4. #4
    Join Date
    Apr 2015
    Location
    Bayern, Deutschland
    Posts
    1,146
    ok. Well I don’t even notice “basic” g-vector.
    Is there a notable difference?
  5. #5
    Registered Member Lbear's Avatar
    2017 CX5 AWD Touring
    Join Date
    Oct 2008
    Posts
    906
    Quote Originally Posted by boandlkramer View Post
    That's the point. It is designed so it is NOT NOTICEABLE. Is was engineered to be unnoticeable.
    Only way would be to test the cornering and see what times and G's you can pull
  6. #6
    Work in Progress sm1ke's Avatar
    Donated: $25
    2018 Mazda CX-9 Signature
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    848
    From here: http://www2.mazda.com/en/publicity/r...0/181011c.html
    "The original G-Vectoring Control, the first technology in the SKYACTIV-Vehicle Dynamics series, was the world's first control system to vary engine torque in response to steering inputs in order to provide integrated control of lateral and longitudinal acceleration forces and optimize the vertical load on each wheel for smooth and efficient vehicle motion.
    GVC Plus uses the brakes to add direct yaw moment control for further enhanced handling stability. As the driver steers out of a corner by returning the steering wheel to the center position, GVC Plus applies a light braking force to the outer wheels, providing a stabilizing moment that helps restore the vehicle to straight line running. The system realizes consistently smooth transitions between yaw, roll and pitch even under high cornering forces, improving the vehicle's ability to accurately track sudden steering inputs and crisply exit corners. In addition to improving handling in emergency collision avoidance maneuvers, GVC Plus offers a reassuring feeling of control when changing lanes on the highway and when driving on snow or other slippery road surfaces."
  7. #7
    Join Date
    Apr 2015
    Location
    Bayern, Deutschland
    Posts
    1,146
    Quote Originally Posted by Lbear View Post
    Pass
  8. #8
    Registered Member Jedi54's Avatar
    2005 RX-8, Grand Touring
    Join Date
    Nov 2010
    Location
    SoCal, CA
    Posts
    378
    so in lamens terms
    • Basic G Vectoring = torque adjustments based on steering input.
    • G Vectoring plus = torque adjustments AND slight braking.
    p.s. I think it's funny we're referring to it as "basic"
  9. #9
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    848
    Quote Originally Posted by Jedi54 View Post
    so in lamens terms
    Just a friendly FYI, the correct term is "layman's terms".
    I'm surprised at how well GVC works. I've tested it on road trips using my 2018 and a loaner 2017 that doesn't have GVC, and you can definitely notice the difference when entering and exiting an on/off ramp. Not that there's anything wrong with the 2017, it's just that the car feels like it handles the turn a little better with GVC.
  10. #10
    Registered Member
    2017 CX-5 GT AWD + Tech
    Join Date
    May 2017
    Location
    Vancouver
    Posts
    68
    Quote Originally Posted by sm1ke View Post
    GVC was standard for 2017 cx-5.
    The GVC would have been the same in those two vehicles you mention.
  11. #11
    Registered Member
    2017 Mazda CX-5 GT Snowflake White Pearl
    Join Date
    Sep 2018
    Location
    SD
    Posts
    66
    It's subtle, and as you point out it is designed to be, but I noticed the effect on my initial test drive. That moment in most cars when you suddenly realize you need to make a mid-corner steering correction just doesn't happen in the new Mazdas, and I could sense a little bit mechanically what the car was doing to make that happen. It literally made the salesman's day. He was so excited to meet a customer who not only knew about the G-Vectoring before being told but also appreciated what it was supposed to do.
  12. #12
    Registered Member ceric's Avatar
    2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,238
    I cross drive '17CX5 and '16Mazda6. I can feel the difference from G-Vectoring.
    It makes the drive less exciting, but smoother. I don't see it as a negative, though.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  13. #13
    Donated: $25
    Join Date
    Dec 2016
    Location
    MB, Canada
    Posts
    848
    Quote Originally Posted by Sideswipe View Post
    Sorry, forgot to mention that I was comparing CX-9s, not CX-5s. 2018 was the first year that it was implemented on the CX-9.
  14. #14
    Registered Member
    2017 CX-5 GS AWD
    Join Date
    Mar 2012
    Location
    UNION CITY, TN
    Posts
    79
    gvc = 2017 , 2018
    gvc+ = 2019
  15. #15
    Registered Member
    2019 CX-5 GT Reserve Soul Red
    Join Date
    Feb 2018
    Location
    28115
    Posts
    77
    I had a 2018 GT and upgraded to a 2019 GTR for the engine. Handling wise I do not notice a difference. I do however notice the 2019 has much more of a rake to it. The front is definitely higher than the back and the car is not level. Most people think I'm crazy but I notice it.
Similar Threads
  1. G-Vectoring Control Plus Retrofit on 2018 CX-5
    By rocking.eagle in forum CX-5 Engine & Transmission
    Last Post: 01-25-2019, 06:48 PM
  2. Replies: 9
    Last Post: 11-30-2018, 12:36 PM
  3. G Vectoring Engineering deep dive
    By GAXIBM in forum CX-5 Lounge
    Last Post: 08-05-2016, 04:51 PM
  4. Replies: 22
    Last Post: 06-12-2016, 08:25 PM
  5. BMW to get new torque vectoring rear-axle
    By mikeyb in forum Lounge
    Last Post: 12-07-2007, 10:15 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
