Page 4 of 16 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 230
Thread: Turbo: nobody home?
  1. #46
    Registered Member
    2017 Mazda CX-5 GT Snowflake White Pearl
    Join Date
    Sep 2018
    Location
    SD
    Posts
    92
    There must be a certain set of low temperature and high humidity conditions that cause the Mazda ECU to pull timing really aggressively. Now this is only partially relevant since I have the NA engine not the turbo, but the other day I needed to accelerate around a semi on the interstate on the way to work that was only doing 55 and the engine was just completely limp. I was fresh off the on-ramp so I needed to build speed from 55 to 75 as I was moving around this semi. I kept digging into the throttle and getting nothing and finally just floored it. I've never felt the car behave in such a way before, I was literally picking up 1 mph of speed around every 2 or 3 seconds with the throttle wide open and the engine at high revs in the lowest gear it could occupy. It felt like I had at best 100 horsepower total that morning.
    It was very cold and very humid with an almost frozen vapor in the air. The skyactiv engines have a lot of sensors, not just knock but also atmospheric sensors so this particular set of conditions must be bad for the engine and sends it into what almost feels like a limp mode.
  2. #47
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    Southern Oregon
    Posts
    1,686
    I think it's quite relevant since it would explain what people are seeing. And if it IS timing, there will be a wide range of values. If it happens in the turbo, it would just be even more noticeable. And there would be even more reason to build such a response into the turbo.
    Thanks for adding your anecdote. With enough of those we might begin to see a pattern.
  3. #48
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    48
    Cold and humid conditions could mean the roads are slick. Which goes with my theory of pulling power to prevent traction loss before it even happens.
  4. #49
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Seems plausible
  5. #50
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    6,986
    Quote Originally Posted by shadonoz View Post
    How does one build a response inside a turbo?
  6. #51
    Registered Member
    2006 Mazda 6
    Join Date
    Oct 2017
    Location
    East Coast
    Posts
    27
    Savagegeese has mentioned in previous videos that turbos lose some of their punch with repeated short term use. It's been too long since he mentioned it to remember which review it was but he was very specific about it being a general problem with turbocharged engines. It was not directed at Mazda turbos but to all turbos.
    It's not that surprising. My 2006 6s, with no turbo, will bog down a bit on hot summer days. Between the heat and having the air conditioner running there's a real loss of power. It doesn't do the same thing in the spring or fall when the air is on.
  7. #52
    Registered Member
    None
    Join Date
    Mar 2017
    Location
    Chicago, IL
    Posts
    40
    Long time turbo car owner (not a Mazda) here. I have experienced a situation in which there was no turbo boost when there should have been turbo boost. It was caused by an engine oil leak and the turbo had seized up. I didnít watch the video (computer problem) but there are two easy ways to know if a turbo is working: (1) a dashboard turbo boost gauge and (2) a high pitched whistle.
    Did Mazda place a turbo boost gauge on the dash of 2019 CX-5 turbo models? Donít tell me Mazda didnít! I donít know because I havenít driven any CX-5 Turbo models. If not, maybe theyíll add it as a future enhancement. My car has one and turbo boost gauges are indispensable. He could have looked at the turbo boost gauge when he thought there was no turbo boost but there should have been and he would have known for sure. Even if the CX-5 doesnít have a built-in dash turbo boost gauge, a master vacuum gauge can be attached to the intake manifold with the hose snaking out the hood and through the driverís side window.
    Thereís a high pitched whistle coming from the turbo during turbo boost. He might not have heard it if the windows were all the way up (especially during the winter months) and the stereo volume turned up loud.
    Intermittent problems like his are harder to track down.
  8. #53
    Registered Member
    Mazda CX-5 Signature
    Join Date
    Dec 2018
    Location
    IL
    Posts
    209
    Quote Originally Posted by Caligula View Post
    Did Mazda place a turbo boost gauge on the dash of 2019 CX-5 turbo models? Don*t tell me Mazda didn*t!
    No. ...Oh wait, never mind..
  9. #54
    Registered Member Lbear's Avatar
    2017 CX5 AWD Touring
    Join Date
    Oct 2008
    Posts
    909
    One can always get a OBD II live data reader. It would show boost and other data.
  10. #55
    Registered Member
    2007 Mazda 3 5-door
    Join Date
    Dec 2018
    Location
    Western US
    Posts
    63
    There is no turbo indicator anywhere and there is a turbo whistle but itís very quiet and hard to hear.
  11. #56
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    48
    After driving a GT-R for a few weeks now, I know exactly what Savage Geese is talking about. Sometimes I get on it and the throttle response is there but it just feels like itís lacking power.
    Today I noticed it on the way into work. After 8 miles at 75 I got off the highway and had to stop for a red light at the end of the exit. Light turned green and I stomped on it expecting the 310 ft pounds to thrust me to 40 in no time. Not quite what happened. It got me there just didnít push me into the seat like it should have. Shifted at about 4K into second in auto non sport mode.
    I was only stopped at the light for a few seconds and itís 10 degrees, so heat soaking shouldnít be the issue.
  12. #57
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    6,986
    Quote Originally Posted by 2001birdowner View Post
    After driving a GT-R for a few weeks now, I know exactly what Savage Geese is talking about. Sometimes I get on it and the throttle response is there but it just feels like it*s lacking power.
    Today I noticed it on the way into work. After 8 miles at 75 I got off the highway and had to stop for a red light at the end of the exit. Light turned green and I stomped on it expecting the 310 ft pounds to thrust me to 40 in no time. Not quite what happened. It got me there just didn*t push me into the seat like it should have. Shifted at about 4K into second in auto non sport mode.
    I was only stopped at the light for a few seconds and it*s 10 degrees, so heat soaking shouldn*t be the issue.
    Could have very aggressive traction control response.
  13. #58
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Quote Originally Posted by Unobtanium View Post
    At that temperature this seems likely. AS tires are pretty hard at that point.
  14. #59
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    6,986
    Quote Originally Posted by jthj View Post
    My Z06 F1:G2 tires gave up around 50*F, my 370Z's Pilot Super Sports hung on until around 30*F, but I have found each tire has a temperature at which it becomes absolutely worthless.
    Possible reasons this is occurring:
    -You are running a strong 87 that actually tests out higher, and sometimes timing is advanced, sometimes it's not.
    -The butterfly valves are restricting turbo intake flow due to a design flaw/quirk.
    -Traction control of some nature is cutting power.
    -You're imagining things.
    This is the only list of things I can come up with.
  15. #60
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Turbo: nobody home?
    Octane compensation had occurred to me also but if heís bellow 4k I dunno.
    Or just a tuning quirk.
Similar Threads
  1. Leaving Home feature for CX-9 ( we already have Coming Home )
    By dxbcx-9 in forum CX-9 Accessories & Appearance
    Last Post: 01-17-2013, 09:36 AM
  2. first time home buyer - condo vs home
    By jred321 in forum Lounge
    Last Post: 03-03-2009, 06:34 PM
  3. Matt's home built z5 turbo thread.
    By 98b/w pro in forum Mazda Protege
    Last Post: 07-28-2006, 12:18 AM
  4. home made turbo kit?
    By Pro Fiz in forum Mazda How-To
    Last Post: 04-27-2003, 09:06 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
