Heated Driver Side Seat-CX 9 2008
How can i trouble shoot heated driver seat? Passenger side working good.
Perhaps check to see that the switch lights up, check fuse is good, check there is power at unplugged seat connector for heat with a multimeter, and check that connector makes good contact when plugged in. If all those things are ok, then the heating element itself is likely bad.
Hope this helps. This would probably be my approach.
ZoomFive
