Results 1 to 2 of 2
Thread: Spot the place to run the cable through firewall
  1. #1
    Registered Member
    Cx9
    Join Date
    Jan 2019
    Location
    KSA
    Posts
    1
    Need giidance to pass through the cable from inside the cabin till front grill. This is required to install a front camera.
  2. #2
    Registered Member
    2016 CX-9 GT
    Join Date
    Dec 2016
    Location
    NC
    Posts
    139
    Under the steering column to the left is the grommet where all wires run into the car. You will have to pull the sound insulation away a little bit.
    The rubber grommet has some nipples on the periphery which can be punctured to run additional cables through.
Similar Threads
  1. Bulkhead firewall cable routing for a permanent live feed.
    By dreadly in forum CX-5 Infotainment
    Last Post: 03-13-2014, 11:18 PM
  2. Replies: 4
    Last Post: 04-28-2013, 11:30 AM
  3. Where is the best place to run wires through the firewall
    By this n00b again in forum CX-9 Infotainment
    Last Post: 01-01-2013, 10:22 PM
  4. Best place to go throught the firewall?
    By azntuner8 in forum Mazda3 Infotainment
    Last Post: 04-14-2009, 03:23 PM
  5. Replies: 1
    Last Post: 04-09-2007, 06:36 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
