CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Just my MAZDA project stuff
  1. #1
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    The WEST Region of USA close to RENO and San Francisco
    Posts
    146
    As a disclaimer I make NO claims to anything I engineer and design that I share on this thread. It is only one members DIY project and nothing more. If there are similarities with other works it may only be by coincidence and not meant as coping another designs. I do ask that unless someone has made what I picture and have tested using tools or equipment capable of showing information and results that we all keep this thread as intend for entertainment only and not technical. Thank you.
    Well not that I look recently but at least last summer no vendor offered a Throttle body spacer direct application for my 2.5 Skyactive engine and at the time it was a royal PIA to try to confirm any other spacer available that might fit from even our forums vendors CS and JBR to which I have talked to both of them many times regarding this and few other projects.
    I needed a spacer primarily for my water /meth system and also to have an extra threaded port to monitor another area of IAT's. Oh and one more item to mount but I will save that for another time to talk about.
    So I also wanted to clean up my TB and thought I would check out what was already available performance applicated for my 2018 2.5 SA engine. However with again no luck finding any vendor offering one I purchased a recycled TB and dissembled it and begun porting enlarging the TB which included making a custom new and very complicated throttle plate. I installed it and the engine fired right up and idled perfect. The ECU acted like nothing had been changed. I also did a base line and a repeat DYNO test before and after I installed it. I won't say that I was jumping up and down but my effort was not neutral by any means, just nothing to really mention.
    Here are a couple of pictures of the TB spacer progress. Almost done just need to round up the corners and do some cosmetic cleaning for appearance sake and it will be ready to install. Oh for the sharper and observant members I won't be using the stock intake system and designed my own.
    Enjoy the pictures.
    When I can find my file on both these projects I will post more pictures.
  2. #2
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Here is the used TB I purchased for the project
    These are only a quick measurement to see more about how much can be safely machined on the stock casting.
    Here is my finished TB...
  3. #3
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    I really hate the storage area in front of my MAZDA. Nothing seems to fit correctly and my cell phone rattles around. Not to mention if I use the *input plugs I hate the cable anywhere near my shifter and the console. I fly and have always liked gauges so this area seemed to be a perfect place to custom make a gauge panel. Don't pre-judge the project until you see the completion.
    The other gauge slot will be a Cobalt Transmission Temperature gauge with multiple senders for the transmission cooler I am adding to my MAZDA.
    *I did an upgrade or custom unit for them. Pictures later when I can find them.
  4. #4
    Registered Member
    2016 CX-5
    Join Date
    Dec 2016
    Location
    Mazdaland, Philippines
    Posts
    77
    so cool. whats the diameter you end up with compared to TB stock?
  5. #5
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Quote Originally Posted by Driver 1 View Post
    Thank you.
    Well that is a hard one to answer. Most TB have several area's and not just one that gets changed. The unfortunate part from vendor that supply larger TB is they find the largest measurement to talk about or advertise. It is really more about or the question should be ."what was the percentage of flow increase over a stock TB"?. And that I don't know yet and will explain later. Gotta go to work right now..
  6. #6
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Quote Originally Posted by Grendel65 View Post
    Thank you.
    Trying not to be technical here is a short explanation why I dont give out size numbers.
    I build BWD's for a few distributors and they also ask me about the size of the bore instead of the flow increases comparing a stock intake part vs a ported or modified for increase flow. Simple pressure sampling at the air intake or air exhaust tunnels taking the observed numbers and simple basic math to get the estimated flow percentages comparing a the baseline stock to modified within about 1-2 % accuracy when I have tested using the shops actual flow bench. The flow bench designed for heads is a PIA to set up for other things. So it is easier to do it with a pressure Meter.
    I have not tested my TB for my MAZDA yet.
    The Meter I use for measure air pressure.
  7. #7
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
  8. #8
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    For charging devises.
    Nice and neat and sorta factory looking sorta?? I now have extra USB ports a conventional charging port and a power activation switch for my rear window camera. There are also my sub-amplifier control and a master stereo sound switch.
  9. #9
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    I like "BLING" as well as functional things as well.
    I removed all the factory material and installed a little better quality stuff!
    I removed the MAZDA emblem and made a mounting plate for another emblem which I will post at a later time. It goes with the theme of the total fun project.
  10. #10
    Registered Member
    2016 CX-5
    Join Date
    Dec 2016
    Location
    Posts
    77
    Quote Originally Posted by grendel65 View Post
    trying not to be technical here is a short explanation why i dont give out size numbers.
    I build bwd's for a few distributors and they also ask me about the size of the bore instead of the flow increases comparing a stock intake part vs a ported or modified for increase flow. Simple pressure sampling at the air intake or air exhaust tunnels taking the observed numbers and simple basic math to get the estimated flow percentages comparing a the baseline stock to modified within about 1-2 % accuracy when i have tested using the shops actual flow bench. The flow bench designed for heads is a pia to set up for other things. So it is easier to do it with a pressure meter.
    I have not tested my tb for my mazda yet.
    The meter i use for measure air pressure.
    k
  11. #11
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    k
    I just noticed your signature. My wife is from Davao.
    Magkaroon ka ng magandang araw
  12. #12
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Getting closer....
    doing the wire harness build today for this project. About a 2 hour task.
  13. #13
    Registered Member
    2016 CX-5
    Join Date
    Dec 2016
    Location
    Posts
    77
    Nice! Kababayan! Kain tayo lechon
  14. #14
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    generally i change my cabin filter at least every 2 months but with the CA Paradise fire just up the road from me My cabin filter needed to be changed twice in one month. So I invested in a K&N Cabin Filter. I should have done this a year ago.
  15. #15
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    I have this *RB muffler that I have not finished adding my wrap and a couple other things. I got it because the specification for CFM are exceed the 2.5 and it will not raise the sound level very much from the stock muffler. The sound was an important factor in me choosing this because i have spent hundreds of hours now installing sound dreading materiel all over my MAZDA.
    I will at some point do another DYNO test to check what the results are from doing the muffler install. I did a base line at 500 miles and again at 5k and 12k which I determined was the break in of the new engine and the most out put with output any changes it would have. Along with with a DYNO test I also did a full weight check with a full tank of gas and also a 4 corner weighing for future reference of any suspension changes I may make?
    * http://www.racingbeat.com/Mazda-3/Ca...-Exhausts.html
Similar Threads
  1. My new mazda project!
    By JITB in forum Pics & Builds
    Last Post: 08-22-2011, 12:01 PM
  2. Replies: 26
    Last Post: 07-06-2011, 12:38 PM
  3. Mazda MX-5 Miata project car
    By trev0006 in forum Pics & Builds
    Last Post: 03-05-2009, 05:07 PM
  4. Project Mazda R.D
    By unwritten-dinas in forum Pics & Builds
    Last Post: 04-17-2007, 01:10 AM
  5. Mazda 6 Project Car
    By STI_vs_EVO in forum Mazda6 Lounge
    Last Post: 08-22-2003, 08:14 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
