Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 45
Thread: Fumoto Valve Question
  1. #16
    Registered Member
    Mazda CX-5 Signature
    Join Date
    Dec 2018
    Location
    IL
    Posts
    344
    Quote Originally Posted by Grendel65 View Post
    Inexpensive easy to use very handy and stores as easy as a couple of bicycles. QUICK JACK
    So, is this the same that they sell at Costco for $1k? LINK
    If it is, does it work as advertised?
  2. #17
    Registered Member
    2014 Mazda 6 GT with MRCC
    Join Date
    Dec 2013
    Location
    Pennsylvania
    Posts
    144
    I've had no leaks or issues with Fumoto vales on either Mazda - and I previously used one on the Subaru Impreza I owned for 120,000 miles. I think they're great and make the oil change simpler and cleaner, and you don't have to bother with a crush washer. I am satisfied with the amount of oil I get out each change.
    2014 Mazda6 Grand Touring with MRCC - Soul Red with Almond interior
    2018 Mazda CX-5 Touring with Preferred Package - Snowflake White with Charcoal interior
  3. #18
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    The WEST Region of USA close to RENO and San Francisco
    Posts
    146
    Quote Originally Posted by Sig cx-5 View Post
    yes.. PM sent.
  4. #19
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    I have often wondered why some members on various forums are so quick to give advise on parts they personally never tried or physically held one and examined it?
    I just ordered one for shits and giggles so I can maybe see what its all about and if I can improve it? And more importantly actually have the product to make real world experience comments about it!
    well well look what I got today!
  5. #20
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    986
    I took a file and notched the thread side that is opposite the valve handle (as I wanted the handle to be up out of the way of road hazards) so that it would minimize the restriction to oil flow on mine before I installed it.
  6. #21
    Registered Member
    2014 Mazda CX-5 GT AWD w/Tech
    Join Date
    Aug 2013
    Location
    Bloomington, Minnesota, USA
    Posts
    569
    Installed mine at roughly 15K miles. Now at 65K. Never a leak - works perfectly. Always change oil when my CX-5 is on ramps. Satisfied with how much oil drains. No spills either except from the filter change.
  7. #22
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Quote Originally Posted by GAXIBM View Post
    VERY NICE RESPONSE GAXIBM!!!!!!! ^^^^^^^^^^^^^^^^^^^^^^^^^^
    BINGO! And that was the modification to do. You must be an old time JC Whitney customer. I say that because these type of drain valve have been around since the mid 1970's. We all machined or "notched" the threads fo rbetter and more complete oil draining. Another thing depending on the pan you can index the position of the notch with special hardened indexing washers. I also would use loctite blue on the threads for added sealing and security.
    Here I had a picture all ready and was setting up my drill press this afternoon... LOL
  8. #23
    Registered Member TANKGUNNER's Avatar
    2018 CX5
    Join Date
    Nov 2018
    Location
    Florida
    Posts
    72
    A little O.C.D. on this subject....as long as you change your engine oil when you are supposed too that little bit left inside the engine WILL NOT HARM IT. If you are that concerned...install a magnet to collect any metal debris. Fumoto valves are great to use.
  9. #24
    Registered Member
    19 CX-5 Signature
    Join Date
    Mar 2017
    Location
    PA
    Posts
    118
    Still gotta crawl under and deal with the filter. In the end how much time and trouble are you really saving over the oem plug? And now you gotta notch it too? Meh.
    19 CX-5 Signature
    Snowflake White Pearl (aka “white”)
  10. #25
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,792
    Arrow Fumoto Valve Question
    Quote Originally Posted by kone View Post
    Exactly. With Fumoto valve you may gain 50 seconds to open the drain, but it takes longer time to actually drain the old oil as the diameter of drain hole on Fumoto valve is much smaller. Your hand may be easier to keep it clean to open a valve, but it still get dirty easily while you’re taking the oil filter down.
    How difficult to loose a factory drain plug as long as you have a 8mm Allen hex socket?
    Preventing a complete drain aside, more important issue IMO is with Fumoto valve extending through the drain hole, which is in 45° in angle by the way, any heavier metal shavings stays in the pan instead of draining out smoothly with the oil.
    As I mentioned before, there’re members here who had taken the oil pan down with Fumoto valve, and was surprised to see how much oil left in the pan.
  11. #26
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,810
    Blog Entries
    6
    I drain on ramps so what little is left in there I am fine with. Draining directly into my transport container is also quicker and easier. Much easier and cleaner to obtain oil samples as well. A couple less tools I need to pull out for oil change and no need to worry about torquing oil drain bolt every time and replace crush washer. For me... too many plusses at this point. For better or worse...nothing compelling I have seen that is going to make me remove them at this point. :-)
    '15 CX-5 GT 2.5L w/tech package - 50K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  12. #27
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,792
    Quote Originally Posted by Kedis82ZE8 View Post
    ⋯ no need to worry about torquing oil drain bolt every time and replace crush washer.
    Totally forgot about drain plug washer. Definitely a drawback without a Fumoto valve.
  13. #28
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Well that was easy enough. About 20 minutes worth of work, enlarged the drain hole , chamfer the edges, chased the thread and slotted the side for a little more draining capability and replaced the fiber gasket with a aluminum (not really necessary) washer, and then added a creature comfort rubber valve cap.
    A little tip when using this type of oil pan valve, to speed up the oil draining remove the oil fill cap prior to opening the valve and drain the oil when it is hot or at least warm.
  14. #29
    Registered Member BlkDakDave's Avatar
    Mazda CX-5 Touring 2016.5
    Join Date
    Jul 2018
    Location
    TX
    Posts
    35
    Quote Originally Posted by eaedstrom View Post
    New (year-end 2018) CX-5 owner here..... Not my first Mazda, but my first Mazda SUV, and I've picked up a lot of good info on the forum.
    I have used Fumoto valves on several vehicles and plan on installing a F106S (plus snap-off tubing adapter) on the CX-5. I have searched the forum but can't seem to find a definitive statement on whether the Fumoto extension is required on the 2.5L. The Fumoto website only indicates that the extension may be required. Hoping to avoid any surprises when it comes time for the first oil change...
    Thanks!
    Going through this thread and I never saw a definitve answer to your question about if the extension is required for the 2.5L. What did you end up getting? I'm wanting to get a Fumoto for my wife's CX-5.
    Thanks in advance!
    NEVER FORGET!
  15. #30
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,810
    Blog Entries
    6
    Extension not needed.
    I am using the F106N
    https://www.fumotooildrainvalve.com/f106n.html
Similar Threads
  1. Oil change/fumoto valve
    By cccx9 in forum CX-9 Engine & Transmission
    Last Post: 03-16-2016, 03:06 PM
  2. Fumoto Valve
    By DBLXX in forum CX-5 Lounge
    Last Post: 07-29-2015, 09:53 PM
  3. Fumoto F106SW Valve
    By FukuokaKid in forum Mazda5 Engine & Transmission
    Last Post: 04-13-2015, 12:31 PM
  4. Fumoto Valve?
    By badself in forum Mazda6 Accessories & Appearance
    Last Post: 09-03-2013, 08:35 PM
  5. Fumoto Valve Installed
    By 2cam16 in forum Mazda5 Engine & Transmission
    Last Post: 01-16-2007, 10:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
