Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: Fumoto Valve Question
  1. #1
    Registered Member
    2018 Mazda CX-5 GT
    Join Date
    Jan 2019
    Location
    Chicago Suburbs
    Posts
    29
    New (year-end 2018) CX-5 owner here..... Not my first Mazda, but my first Mazda SUV, and I've picked up a lot of good info on the forum.
    I have used Fumoto valves on several vehicles and plan on installing a F106S (plus snap-off tubing adapter) on the CX-5. I have searched the forum but can't seem to find a definitive statement on whether the Fumoto extension is required on the 2.5L. The Fumoto website only indicates that the extension may be required. Hoping to avoid any surprises when it comes time for the first oil change...
    Thanks!
  2. #2
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,258
    Arrow Fumoto Valve Question
    Quote Originally Posted by eaedstrom View Post
    Thanks!
    Just FYI the Fumoto valve will prevent a complete drain of the old oil when you do the oil change. By looking at the thread length of the Fumoto valve itís longer than the drain hole thread length and will stick out above the bottom of the oil pan.
    Quote Originally Posted by SK77X View Post
    Hey guys, I came across a review on Amazon that brings up an issue with this valve. Below is the key part of the review:
    A few months later, I went to replace the oil pan gasket so I drained the oil using this valve and removed the bolts around the pan. I noticed that when I tilted the pan, more oil drained even though the drain is located at the very lowest point in the pan. Then when the pan was removed, I saw why this was happening. It did not drain all of the oil. The valve extends into the pan.
    The drain valve threads into the hole in the bottom of the pan, but it also extends through the hole, in my case by about 3/16". So when you open the valve, all but the last 3/16" of oil is drained, not ALL of the oil. Also, any thing heavy (carbon chips, metal chips) stays in the pan instead of draining out with the oil.
    http://www.amazon.com/review/R1NPAGP...ore=automotive
    I was going to get this valve for the convenience factor, but not sure that's more important than getting all the old oil and fragments out. Your thoughts?
    Quote Originally Posted by KnurledNut View Post
    F-106 w/o adapter
  3. #3
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,728
    Blog Entries
    6
    '15 CX-5 GT 2.5L w/tech package - 48K Miles / '07 Infiniti G35x / '12 Lexus GX 460 / '00 Wrangler TJ 4.0L
  4. #4
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,258
    No, it won't. See the post above. If the memory serves me correctly, Chris_Top_Her had also found there's plenty of oil left when he took his oil pan down with a Fumoto valve.
  5. #5
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    The WEST Region of USA close to RENO and San Francisco
    Posts
    146
    Quote Originally Posted by yrwei52 View Post
    ^^^^^^^^^more looking on the internet for you experience and no-ledge (knowledge) to post my freind?
    I have often wondered why some members on various forums are so quick to give advise on parts they personally never tried or physically held one and examined it?
    I just ordered one for shits and giggles so I can maybe see what its all about and if I can improve it? And more importantly actually have the product to make real world experience comments about it!
    OMFG CA ..I guess I need to wear gloves to handle the part..ROLMAO
    Proposition 65 Warning for California Consumers
    WARNING: Cancer and Reproductive Harm - www.P65Warnings
    Looks like mine will arrive this week.Guaranteed delivery date: Jan. 10, 2019
    Hmm I may have to do an early oil change just to try it out. The only thought is I use a DIMPLE DRAIN plug in my MAZDA oil Pan and really don't want to replace it with anything else. But I may install the new valve/drain plug add 1 quart of oil and then drain it and measure the volume?
    Yes I have a technique when needed to remove all oil out of most any oil pan, so I will be able to measure exactly how much oil is left from my test.
    Dimple drain Plugs...product recommendation:
    https://www.drainplugmagnets.com/
  6. #6
    Registered Member
    2018 Mazda CX-5 GT
    Join Date
    Jan 2019
    Location
    Chicago Suburbs
    Posts
    29
    Thanks for everyone's input. I'm a ways off until my first oil change - I'm only at 1K - but am planning on installing the valve, and then possibly removing it at the second change (after draining) to see how much residual oil we're really talking about. It sounds like Grendel65 will beat me to it - I'd be interested in hearing the results.
  7. #7
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    thanks for everyone's input. I'm a ways off until my first oil change - i'm only at 1k - but am planning on installing the valve, and then possibly removing it at the second change (after draining) to see how much residual oil we're really talking about. It sounds like grendel65 will beat me to it - i'd be interested in hearing the results.
    pm sent
  8. #8
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,323
    I guess you could tilt the car at a 45 degree angle to squeeze more out...
  9. #9
    Registered Member
    2017 Mazda 6 Sport
    Join Date
    Feb 2018
    Location
    TX
    Posts
    139
    The oil plug is on the side of the pan so a couple of 16ths of thread extending into the pan shouldn't really affect how much comes out
  10. #10
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,364
    Quote Originally Posted by dunhillmc View Post
    Yeah, wondered about that. I've left the car for quite a while draining oil and still come back to drip, drip, drip. Don't think you can get it all. Valve installed or not.
    2014 CX-5 Touring AWD | Jet Black Mica - 79k miles
    01/2013 build | 4/20/2013 delivery
  11. #11
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,728
    Blog Entries
    6
    I normally put mine up on some Rhino ramps on front when I change mine. I like having some room to work. Sure wish I had a house that could accommodate a lift. Not enough space in garage.
  12. #12
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,364
    Quote Originally Posted by Kedis82ZE8 View Post
    A lift would be amazing. I have a very tiny detached garage for my condo. I use ramps as well. Still trying to figure out a good spot to do my brakes as side to side I'd have no room to work in my garage, and can't do it in our parking lot.
    I'm kind of envious of my uncle (out of state, sadly), they built a new house and with it a gigantic workshop and he has lifts and the whole 9 yards. Pretty sure his workshop is as big as their old house was lol.
  13. #13
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Quote Originally Posted by ColoradoDriver View Post
    actually there is something even better about that old oil dripping.....I will PM you
    Inexpensive easy to use very handy and stores as easy as a couple of bicycles. QUICK JACK
  14. #14
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    Southern Oregon
    Posts
    1,682
    Good excuse for a ROAD TRIP!
  15. #15
    Banned
    2018 Mazda
    Join Date
    Dec 2018
    Location
    Posts
    146
    Very true... I have mine hanging on the wall in garage.
    NICE! ^^^^^^^^^^^^^^^^^^^^^
    https://www.youtube.com/watch?v=pk7OVYPGMow
Similar Threads
  1. Oil change/fumoto valve
    By cccx9 in forum CX-9 Engine & Transmission
    Last Post: 03-16-2016, 03:06 PM
  2. Fumoto Valve
    By DBLXX in forum CX-5 Lounge
    Last Post: 07-29-2015, 09:53 PM
  3. Fumoto F106SW Valve
    By ブレイク in forum Mazda5 Engine & Transmission
    Last Post: 04-13-2015, 12:31 PM
  4. Fumoto Valve?
    By badself in forum Mazda6 Accessories & Appearance
    Last Post: 09-03-2013, 08:35 PM
  5. Fumoto Valve Installed
    By 2cam16 in forum Mazda5 Engine & Transmission
    Last Post: 01-16-2007, 10:38 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
