Results 1 to 15 of 15
Thread: 2013 Mazda CX5 Touring Wont Start
  1. #1
    Registered Member
    2013 Mazda CX-5 Touring
    Join Date
    Oct 2014
    Location
    New York,NY
    Posts
    44
    I own a 2013 Mazda CX-5 with close to 72,000 miles on it. I have tried to turn my car on, but to no avail. When I depress the brake pedal the start button lights up green so it is recognizing the key, but only turns the car to the on position where all of the electronics seem to be operating at a norm. The first 2 times that I try to turn the car on there seems to be a short crank, but then stops and after 3 times there is no cranking at all. Could this be a starter issue because I also tried attaching a battery to help jump start the car, but that did nothing either. Since the key is being recognized by the car and all of the electronics work such as the power windows, radio, lights, and locking the vehicle I suspect it is a faulty starter. Would anyone be able to give some insight to this issue?
    Thank You!
  2. #2
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    54
    could be faulty starter, could also be the sensor in the break pedal. This comes to my mind at first glance.
  3. #3
    Underutilized Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    Southern Oregon
    Posts
    1,523
    How old is the battery? Original? You could run a load test on it. Might have enough juice to wake up but not enough to crank.
  4. #4
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,367
    Quote Originally Posted by shadonoz View Post
    what shadonoz said...
    Starter is very unlikely. If your START/STOP light goes green when you press the brake pedal, that means brake switch is working.
    Make certain transmission is in PARK while you are attempting to start.
    If the PARK safety switch is faulty, it can prevent the car from starting too. You can try to press forward or down, or wiggle on the transmission lever while it is in PARK, all the while attempting to start by pressing the START/STOP button.
    INSPECT BATTERY TERMINALS, and Load Test battery.
  5. #5
    Registered Member Anchorman's Avatar
    2018 CX-5 SportNav 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,262
    There was an issue with the inhibitor switch by the bottom of the gearstick.
  6. #6
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,228
    Check the battery first, regardless of the unsuccessful jump.
  7. #7
    Registered Member
    Join Date
    Oct 2014
    Location
    New York,NY
    Posts
    44
    In the video I have given an update on the situation. I am waiting to get a battery tester to determine if this is the culprit to the issue. I am also in a bind because I live in NYC and had parked the car in a tight parking spot and am not sure how a tow truck would go about towing the vehicle to a shop if needed.
  8. #8
    Registered Member
    2013 CX-5 Touring FWD; 2013 BMW Z4 35i
    Join Date
    Mar 2012
    Location
    Santa Rosa, CA
    Posts
    3,357
    You haven't answered the most important question. Is it the original battery? If so, don't wast your time testing the damn thing, just replace it. It probably wouldn't start with a jump because it's got a direct short in one or more of the cells. Six years is all you can expect from an OE battery. Yours has all the symptoms of battery failure. An yes, dash lights and accessories will often work with a bad battery, but there's not enough life left to provide adequate power to the starter.
  9. #9
    Registered Member
    2014 Mazda CX-5 GT AWD w/Tech
    Join Date
    Aug 2013
    Location
    Bloomington, Minnesota, USA
    Posts
    541
    +1 ^
  10. #10
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    4,008
    Quote Originally Posted by paris1 View Post
    Just replaced my 6 year old OE battery. It was definitely time. Can pick one up for $75 at Costco.
    2014 CX-5 Touring AWD | Jet Black Mica - 77k miles
    01/2013 build | 4/20/2013 buy
  11. #11
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,557
    6 years, that is a very long life, for an oem battery. My Costco battery, is already two years old and I'm only, at 48k miles.
  12. #12
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    4,008
    Quote Originally Posted by tibimakai View Post
    Having any issues with it?
  13. #13
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    54
    Assuming car battery is ok-ish. (Check this).
    I see your button flashes amber.
    This is from the manual doc. Two different procedures. The second is if the batt inside the key is low/dead.
    (Forced engine starting method)
    If the KEY warning light (red) illuminates,
    or the push button start indicator light
    (amber) flashes, this could indicate that the
    engine may not start using the usual
    starting method. Have your vehicle
    inspected at an Authorized Mazda Dealer
    as soon as possible. If this occurs, the
    engine can be force-started. Press and hold
    the push button start until the engine starts.
    Other procedures necessary for starting the
    engine such as having the key in the cabin,
    and depressing the clutch pedal (manual
    transaxle) or the brake pedal (automatic
    transaxle) are required.
    l When the engine is force-started, the KEY
    warning light (red) remains illuminated and
    (amber) remains flashing.
    Note:
    When the shift lever is in the neutral (N)
    position, the KEY indicator light (green)
    and the push button start indicator light
    (green) do not illuminate.
    If the engine cannot be started due to a
    dead key battery, the engine can be started
    using the following procedure:
    1. Depress the brake pedal (automatic
    transaxle) or fully depress the clutch
    pedal (manual transaxle).
    2.Verify that the push button start
    indicator light (green) flashes.
    3. Touch the push button start using the
    backside of the key (as shown) while
    (green) flashes.
    4. After the push button start indicator
    light (green) changes to full
    illumination, press the push button start
    with your finger.
    - If there is a malfunction with the push
    button start function, the push button start
    indicator light (amber) flashes. In this case,
    the engine may start, however, have the
    vehicle checked at an Authorized Mazda
    Dealer as soon as possible.
    - If the push button start indicator light
    (green) does not illuminate, perform the
    operation from the beginning again. If it
    does not illuminate, have the vehicle
    checked at an Authorized Mazda Dealer.
  14. #14
    Join Date
    May 2013
    Location
    Posts
    2,557
    Quote Originally Posted by ColoradoDriver View Post
    The original battery, died very fast, 3 years (!). The Costco one works great.
  15. #15
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colorado
    Posts
    4,008
    Awesome! Having just picked up the Costco one, glad to hear it!
Similar Threads
  1. 2013 Touring no-start... First time
    By snotrod in forum CX-5 Lounge
    Last Post: 10-30-2015, 04:40 PM
  2. mazda protege5 wont start but electronics turn on
    By jenn10 in forum Mazda Protege
    Last Post: 11-21-2013, 05:07 PM
  3. 99 Mazda Protege lost Vref, wont Start
    By arami99 in forum Mazda Protege
    Last Post: 12-05-2005, 09:55 AM
  4. 99 Mazda Protege lost Vref, wont Start
    Last Post: 11-16-2005, 12:46 PM
  5. 99 Mazda Protege lost Vref, wont Start
    Last Post: 11-14-2005, 07:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
