- RDX Aspec Adv.
I am not sure what some do for a living but reading comprehension should be something some people may think about to improve on?
To be exact on my post I said change the "PAN" fluid!
The percentages in the above posting are inaccurate. No one took in account or considered the dilution factor when this type of service is done regarding an ATX. Even using a specialized automatic transmission service fluid machines the manufactures of these HIGH QUALITY transmission service systems will not post any percentage values that I am aware of?
Some members may want to fully and more carefully read that Blackstone Lab report that was used in the above posting as an example of support information a little closer as well the information posted by the member starting the thread.
Most materials I refereed to in my responses float or better wording held in suspension circulating through the transmission and are mostly caught in the filter. That is why I said "FILTER" in my response recommendation earlier.
I wonder what anyone really calls minimal contamination? I would think anything that is not suppose to be in motor oil or transmission fluid is a contaminate and DOES NOT BELONG THERE!!!
Adding a cooler, my comment was for the most part generalized but yes you can add a functional auxiliary cooler to these transmissions. Even a larger sump capacity. A project, I have already ordered the necessary parts to accomplish adding a transmission cooler and temperature gauge to my 2018 MAZDA ATX.
If anyone is worried about the environment GET AN ELECTRIC CAR, TAKE PUBLIC TRANSPORTATION ,WALK or RIDE A BICYCLE . ROLMAO!!!
MY USED MOTOR AND TRANSMISSION OIL ARE "recycled" PICKED UP MONTHLY(55 gallon drum)AND TAKEN TO A COMPANY THE CLEANS AND RE-MARKETS THE OILS USE IN THE INDUSTRY.
By the time a properly designed automatic transmission fails secondary to fluid, the engine will be done as well. My Dad's work van, for example, has close to 1/2 a million miles on the OEM transmission and OEM transmission original fluid fill. It is a GM 4L65E, I believe. More damage to be done changing fluids than leaving it alone.
