VersaTuner - tuning software for Mazdas
Results 1 to 14 of 14
Thread: Question
  1. #1
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    459
    Question
    I'm about to do the valve cover swap, but Ive got mixed answers about the gasket. It's a rubber gasket someone told me not to put sealant on it just some oil. Others stated to put rtv or some sort of sealant on. Which is it? What would you guys recommend, also the inch pounds to torque the bolts down to ?
    Thanks guys.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    I've got this..
    Be careful not to over tighten your valve cover bolts.
    I've got one snapped off of my car and two snapped off of my parts car.
    And this, you'll need this.
    The Diagram Dude
  3. #3
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    459
    Ok last three questions haha
    First sealant in those 4 locations but is it just a dot ?
    Second I have these two gasket sealant, I will be using the black sealant I'm sure is the same. https://photos.app.goo.gl/ngex12SKuLeMyx6L6
    Third is it only those three bolts I have to torque or is it all? And why such a 20 inch gap in torque specs?
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Yes it's just a dot of silicone in those four spots.
    The gasket has four "corners" (90 bends) in those spots and it's hard to get a good seal around a corner.
    Your sealant is fine.
    Black has better oil resistance and blue, red and copper are for higher heat ranges but may not be as oil resistant.
    The black is well within it's heat range on the valve cover. (I put copper RTV on my exhaust. It's good to 700 F)
    The torque specs for the valve cover bolts are all the same. It's just showing three.
    There are three different lengths of bolts on the valve cover. Be careful not to mix them up.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Don't forget to follow the bolt tightening pattern.
    Go around once and just snug them up (finger tight) then go around again and torque them to spec.
    The bolt tightening torques have a "tolerance" and it gives a range where it should be.
    Aim for the middle of the specs.
  6. #6
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    459
    Finished it up, I don't see leaks around the valve cover. I'm hoping I put the right amount of sealant around the belts. Started right up first time. Can't wait to drive it tomorrow.
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Quote Originally Posted by NaturalFlavored View Post
    ... I'm hoping I put the right amount of sealant around the belts.
    I only put sealant on the valve cover gasket.
    I didn't put any on the belts.
    Let me know how that works out for you. lol.
  8. #8
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    328
    That's some good info...
    This whole time, I thought I put black RTV on all four corners of the valve cover gasket. Definitely good to know, as I intend on painting my VC someday.
    What about those weird ziptie bolts holding down the wires, though? Know where to get more of those?
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX Short Shifter ■ OBX 4-1 Headers
    ______________________________
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Quote Originally Posted by Riot_Polizei View Post
    What about these...
    They say they work for Mazda.
  10. #10
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    328
    Oh, so they can just pop out then? Didn't realize they were clips in the first place...
    I'm going to get some of those before I accidentally destroy them
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Oh, so they can just pop out then? ...
    Yea but they're 17 years old now and will probably break when you remove them.
    A clip remover may help.
  12. #12
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    459
    Sorry not directly on the belts themselves, but the 90 curves. I put a line across.
    Good idle, I like it.
  13. #13
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    459
  14. #14
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,549
    Looks good......I used gray rtv when I did mine.
Similar Threads
  1. tire question, possibly a noob question
    By Chaddy in forum Mazdaspeed3
    Last Post: 03-11-2011, 12:35 PM
  2. Rotor question & axles question
    By blazinrola80 in forum Mazdaspeed Protege
    Last Post: 11-09-2010, 12:42 AM
  3. Spoiler and window visor question Question
    By liljon in forum Mazdaspeed Protege
    Last Post: 12-31-2009, 11:07 PM
  4. Rear view mirror question help?? Install question
    By stanley_cup in forum Mazdaspeed3
    Last Post: 02-23-2008, 02:25 AM
  5. wastegate question/o2 clamp question
    By zinx in forum Mazda How-To
    Last Post: 04-01-2006, 07:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
