Results 1 to 5 of 5
Thread: 16+ CX9 Snow chains/snow cables
  1. #1
    Apex? Where?! deepfriedsushi's Avatar
    95 Miata, 14 CX5 Touring FWD, 18 CX9 GT FWD
    Join Date
    Jun 2005
    Location
    San Diego, Ca
    Posts
    399
    Has anybody tried putting snow chains/cables on their 2nd gen CX9?
    Peerless says the super Z sz441 is the size to get.
    https://www.peerlesschain.com/tire-c...tirechains/675
    I've tried a set of super Z's on my CX5. They fit the wheel really well, but the inner loop interfered with the suspension, so they couldn't be used. I'm wondering if I would run into the same problem with the CX9.
    Thanks!
  2. #2
    Registered Member
    Mazda CX-9 Signature
    Join Date
    May 2017
    Location
    SoCal
    Posts
    147
    I can confirm stock wheels will yield the same result as your CX-5 with not enough clearance with the suspension.
  3. #3
    Join Date
    Jun 2005
    Location
    San Diego, Ca
    Posts
    399
    Would you happen to have any pictures? Where was it interfering?
    With the CX5, the inner loop would touch the top of the flanges of the strut where connects to the hub/spindle. If the inner loop was just half an inch further away, it would have been fine to run. The cable just barely touched....but interference is interference...not worth damaging and compromising the chains.
  4. #4
    Join Date
    Jun 2005
    Location
    San Diego, Ca
    Posts
    399
    So I was able to find a brand new set of these chains for $20 and did a quick test fit on the CX9. A neighbor bought them for his 4runner, but switched to a larger tire size before he ever used the chains. I brought along a floor jack to lift up a wheel and was able to spin the wheel to look for interference.
    The cables don't touch any hard point of the suspension like the CX5 did. However, there is a rubber damper on the strut that ever so slightly grazes with the inside loop of the cables. This rubber damper is flexible and doesn't seem like it would interfere much with the cables installed. It was barely enough interference to make it seem like it would be a big issue, so I bought the chains. The damper is just a big rubber block that is mounted to the strut in such a way that the block can move and give way when being touched. The cables barely touch the side of the block, and if it were to touch anymore, the rubber block would just shift out of the way. I don't think the cables could ever catch onto the block hard enough to cause any problems.
    When I have time, I'll reinstall the chain, take my time to do a test fit again and get an even closer look and try to get some pics/video. I want to truly verify this before actually having to use them.
  5. #5
    Registered Member
    Join Date
    May 2017
    Location
    SoCal
    Posts
    147
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    This was the one I got. The bump stop would be the interfering component and IIRC it was welded to the strut itself. Only way I would recommend is to at least put 10-15mm spacer or you'll just be snapping the chain or worst damage the strut.
Similar Threads
  1. AWD vs FWD w/chains in the snow
    By L7D4R in forum CX-5 Wheels, Tires, Brakes & Suspension
    Last Post: 07-31-2014, 02:00 PM
  2. Snow chains/cables
    By USAFVMI08 in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 03-16-2011, 10:48 AM
  3. Snow chains/cables?
    By bearymore in forum Mazda5 Lounge
    Last Post: 12-27-2010, 10:47 PM
  4. Snow chains or cables on MS3?
    By vinkalmann in forum Mazdaspeed3
    Last Post: 12-07-2009, 04:13 PM
  5. Replies: 21
    Last Post: 12-29-2008, 01:58 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
