Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: 100K miles, and stuff needs done...here's what!
  1. #1
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    6,986
    Took my CX5 in for the oil change at 102,XXXmi, and they suggested:
    -Replace accessory belt "in the near future, say, next oil change-ish" (they showed me the cracks in it, I agree with their opinion.). $160 including tax
    -Replace valve cover gasket later on, monitor for now. (They showed me some seepage/weeping/humidity looking stuff, and I concur, in another 15-20K miles, it may be "a thing".) $130ish
    -Change brake fluid, 3% humidity (agree, meant to do it before). $130ish
    -Change air filter, is dirty (I forget when I did it last, not more than 25K miles ago, but hey, it was dirty looking) I don't recall cost.
    -Change plugs (First time mentioned to me, I did it already though). $300ish...WTF!?
    -Fuel System cleaning (no rationale, I view this as a useless "upcharge", and they did not push it at all, just had it on the sheet.). $160ish
    Today I opted to do the brake fluid, air filter, and will do the acc. belt next oil change (7500mi), and the valve cover gasket at around 115-125K miles. I remember on my G20, I had to do this, too, as it was weeping.
    All-in-all, I found the things "going bad" on my vehicle to be pretty "it's a machine, man..." type stuff and am not at all put off by it thus far. Also, the dealer recommendations were very sound and free of BS, and noone had any issue showing me the things mentioned, all except the fuel system cleaning, which they did not push and the mechanic did not speak to me about.
    I do not know how difficult it is to change the acc. belt on this thing, but I will look into it. Even if you paid the dealership costs, it's still super cheap to have owned for 102K miles. My Jeep required $150 in diff servicing every 15K miles, and the Transfer case $120ish ever 25-30K miles.
  2. #2
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Yea thatís all pretty normal stuff to see on a car of that mileage imo. Definitely not anything I would find alarming.
    The plugs have a 100k mile interval I believe so if you did it yourself they might just be recommending based on mileage if they didnít know it was done.
    I plan to do brake fluid about every 3 years.
  3. #3
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,775
    OR you could have traded it in for $9500 and just got a enw one?!?!
    Dude...
    hahaha
  4. #4
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Quote Originally Posted by 7eregrine View Post
    Dude...
    hahaha
    And gained like 65 hp!
  5. #5
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,268
    Arrow 100K miles, and stuff needs done...here's what!
    Quote Originally Posted by Unobtanium View Post
    My Mazda dealer would suggest ATF drain-and-fill at 100K miles.
    Not surprised on $300ish charge for spark plug replacement as the OEM plug costs $32.27 each. Maintenance schedule for spark plugs on NA 2.5L is 75K miles. For 2.5T itís 40K miles.
    There are 2 drive belts for 2.5L. Make sure your dealer is replacing both, not just serpentine belt. Ask them to check tensioner too.
    Another maintenance item soon willp be due is the engine coolant: at 120K miles.
  6. #6
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    2,892
    Imho: Change your cracked belt if they recommend (wow thats a cheap price they quoted?!) and brake fluid. Have them do it.
    +1 on belt tensioner.
    Spark plugs I'm pretty sure you can do yourself. You merely need to buy a Ford spark plug removal tool (or right sized one) if I recall. Otherwise negotiate on service pricing at dealership. Check for online dealership service coupons.
    Valve cover gasket having some weepage at that mileage is normal for a lot of cars. imho bypass this for now. Simply wipe clean all edges of cover gasket and track every oil change. If it simply weeps a little bit every oil change then its normal. If its to the point its dripping then change. I believe it does not require a lot of technical expertise to do so.
  7. #7
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Itís not a bad idea to replace the tensioner too when you get the belts replaced. If you do the replacement belts will probably last as long as the first set.
    Not sure if that tensioner will go to 200k. Then again if youíre only planning to keep the car another year or so......
  8. #8
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,377
    Agreed on Tensioner. Had to replace it earlier this year, and went ahead and had a new serpentine belt put on at the same time.
    2014 CX-5 Touring AWD | Jet Black Mica - 79k miles
    01/2013 build | 4/20/2013 delivery
  9. #9
    Registered Member gova's Avatar
    '14.5 CX-5 Touring AWD, Soul Red | '14 CX-5 Touring AWD White
    Join Date
    Jul 2012
    Location
    IL
    Posts
    511
    How difficult is it to replace both belts and tensioner?
  10. #10
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,377
    Quote Originally Posted by gova View Post
    Personally, I didn't have the right tools and didn't want to mess with it, so I paid and got it done at a shop. Didn't seem to take them long as I was there for maybe an hour?
    I think there are some folks on here who did it themselves though who could chime in.
  11. #11
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    150
    Doesnít look difficult for the 2.0L. Iíll probably do it on my own when the time comes. Donít know how hard the tensioner is to replace though, havenít found that tutorial yet.
    http://www.mcx5.org/drive_belt_remov...2_0_-1644.html
  12. #12
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,731
    Blog Entries
    6
    Quote Originally Posted by CX-5um View Post
    Hopefully not just a turkey baster replacement of fluid in master cylinder... as paranoid as I can be I'd post check the work and pop the rubber protector cap off a sample bleeder to make sure they actually did it.
    '15 CX-5 GT 2.5L w/tech package - 49K Miles / '07 Infiniti G35x / '12 Lexus GX 460 / '00 Wrangler TJ 4.0L
  13. #13
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    6,986
    Quote Originally Posted by Kedis82ZE8 View Post
    I trust 'em. They do good work. My brakes felt amazing afterward, too. Much firmer pedal!
  14. #14
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,331
    I can remember when you were quite cynical about your CX5 Unob*. I think you*ve warmed to it and it certainly hasn*t hampered any of the work you*ve done on the ranch. I wish I could be so disciplined about wasting money on new cars.
  15. #15
    Registered Member
    2017 CX-5
    Join Date
    Jul 2017
    Location
    Omaha
    Posts
    1,907
    Quote Originally Posted by Anchorman View Post
    Heís cool now that they make one thatís not slow.
Similar Threads
  1. 96 MX-3 GS with 100k miles - how to set a price?
    By num6 in forum Other Mazdas
    Last Post: 05-14-2015, 12:37 PM
  2. 100K miles!
    By MD5 in forum Mazda5 Lounge
    Last Post: 06-21-2010, 03:38 PM
  3. 100k miles
    By mzdspd6 in forum Mazda6 Lounge
    Last Post: 04-10-2010, 06:57 PM
  4. 100k miles
    By bigdaddy in forum Mazdaspeed3
    Last Post: 01-06-2010, 11:49 PM
  5. Anyone hit a 100k miles yet?
    By 5zoom in forum Mazda5 Lounge
    Last Post: 12-22-2009, 10:39 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
