Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: Brake Flush @ 53k miles
  1. #31
    Registered Member
    17 CX-5 GT 14 CX-5 GT (sold)
    Join Date
    Aug 2015
    Location
    Texas
    Posts
    540
    Quote Originally Posted by Kedis82ZE8 View Post
    I will post if I hear about it before someone else.
    Makes process so clean, convenient and easy to do by one person.
    I'm swapping my front brake pads and hardware tomorrow so flush will finish this maintenance task for a while.
    What about Motive's 1199 custom adapter? https://www.motiveproducts.com/colle...nd-us-your-cap
    It says they will take a customer supplied brake fluid reservoir cap and modify it for use with their tanks for $25.
    I already have the Motive tank and catch bottles, so I am thinking of ordering an extra cap for my CX5 and sending it to them.
  2. #32
    Registered Member thomaspanton's Avatar
    Join Date
    Jul 2019
    Location
    Blythewood, SC
    Posts
    8
    How can we understand that it is original brake fluid?
  3. #33
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    362
    Quote Originally Posted by thomaspanton View Post
    Do you mean on a used car that you purchased how do you determine if its original? It wouldn't necessarily matter IMO. If you've owned your car 2-3 years and you haven't changed the brake fluid, its likely due to for a change even if it were replaced just before you purchased it. You can get a brake fluid tester on Amazon. The reliability of these testers is arguable but my $8 tester seems to work fine. Tests 0% on new fluid and is testing 1% on 1-2 year old fluid.
    If you want to get one and test yours and the water level tests at 2% or greater" change the fluid regardless of whether or not its original. If you've owned the car for 3 or more years without a brake fluid flush just go ahead and get it changed without testing it. It's likely already got too much water in it.
  4. #34
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,252
    What kind of beer is this?
  5. #35
    Registered Member ralf11's Avatar
    Join Date
    Jun 2019
    Posts
    159
    on a used car, one should replace all fluids just to be safe
    also, check the date codes of the tires and replace if older than 6 years, no matter how much tread is left
    - if the vehicle is older than 15-20 years, replace all rubber brake hoses with new rubber; and replace all rubber fuel hoses with new rubber one that rated for Ethanol mixes (10-15% depending on your gas)
    Motive's device is simply a more costly version of something you can easily build from a garden sprayer for about $15 or less
Similar Threads
  1. Original Transmission Fluid at 117K Miles - Drain, Flush, or Leave Alone?
    By CX-9 Owner MD in forum CX-9 Engine & Transmission
    Last Post: 07-31-2015, 04:22 AM
  2. Brake/Clutch Fluid Flush & Radiator Flush
    By MacAttack7 in forum Mazda3 General
    Last Post: 09-16-2014, 11:25 PM
  3. Replies: 9
    Last Post: 11-06-2012, 01:51 PM
  4. brake fluid flush
    By joe944 in forum Protege5
    Last Post: 10-10-2012, 07:56 PM
  5. Transmission Oil Flush every 30,000 miles $180
    By fatlard in forum Mazda CX-7
    Last Post: 07-03-2007, 12:49 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
