2017~2024 using 2010 Mazda 5 17' wheels on 2018 cx-5 Touring
cx5
Hi,
Question from a new owner of 2018 cx-5 Touring. I was a 2010 Mazda 5 owner and have a set of extra 17' wheels for 2010 Mazda 5. Plan to put on snow tires and use on 2018 cx-5 touring to replace the 19' wheel. Are they compatible? I know the tire on 17' wheel should be 225/65 R17. thanks!
They'll physically bolt on, but no clue as to whether they'll clear the calipers or not. Your stock wheels are 17x7 with a +45mm offset; the MZ5 wheels are 17x6.5 +52.5. Same hub bore. Your MZ5 wheels will sit inboard 7.5mm more but on a thinner wheel so wheel well clearance probably won't be a problem at all. You'll just have to test fit them yourself to see if the spoke pattern clears all your CX-5's suspension and brakes. Let us know!
I run the original 17" from my 2010 Mazda 3 GT without issues. If I recall correctly the Mazda 5 17's were the same specs as the 3, just .5" narrower wheel (I also had Mazda 5 wheels on my Mazda 3), but that may have just been the design I had.
As mentioned above do a quick test fit for caliper clearance. If the calipers clear you should be fine.
