Compare auto reliability with reliable results at TrueDelta.com!
Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 284
Thread: Slow NA Pro5 build
  1. #31
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    547
    Hey man, if I was to hazard a guess, I'd say that you could link up a 626 throttle body to a P5's IM, since the 626 IM can bolt right in. However, I don't know if it's hydraulic or cable-driven, and the 626 IM is a single piece as opposed to our cars having two pieces.
    Now, this sounds crazy, but if you want a NA project that'll really stand out, investigate Toyota AE101 ITBs. Apparently, all you need is 800cc injectors, an "adapter plate", and that's it. All the sensors work nicely, supposedly.
    I first learned about this on a Protege facebook group, where someone sold the aforementioned ITBs along with the adapter plate.
    Check it out:
    https://www.mazdas247.com/forum/show...rogress-Thread
    (broken pictures)
    http://www.astinagt.com/forums/showthread.php?t=11224
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ■ AWR Trailing Arms ■ Eibach Lowering Springs
    ______________________________
  2. #32
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Man those were some crazy threads, who woulda thought of throwing blacktop 20v ITBs on an FS? I've kinda looked around at ITBs but I'm looking at spending so much in other departments [emoji22] and 800cc injectors on a NA build seems a bit much right? I'm planning on running 400cc and I hear even those might be to big for my applications. Anyways keep it coming guys I love these build threads, they're like online time capsules[emoji23]
    Sunburst 02 pro5 200k+ miles
    Mystery 4-1 header, mystery short ram, moog control arms, moog front endlinks, moog tie rods, moog trailing links, tein lowering springs, gutted interior
    All about them stickers, crumpled panels, and mismatched paint yo
  3. #33
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Pulled the vtcs today that's about it lol. Still have to plug the holes n such, but I did I bit more research on ITBs and now I really want them. I kinda wanna make a custom set, I read a couple threads where they would chop the stock intake mani a couple inches above where it connects to the header and then welding on an adapter plate to bolt the throttle body itself on. I still don't know a lot about them but man they sound mean and look rad
  4. #34
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Did some more research and found some info deep in the threads apparently a group made an ITB set for FS 1.8 and 2.0 engines. They were called AAI Motorsport AKA Buddy Club. The only link I've found set me to a site with barely any English so that wasn't too helpful, these threads were from 2005. Does anyone have anymore info on these?
  5. #35
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Well nothing really happening right now, I'm just waiting for a solid week of work to get bills back on track. Right now I've been filling time with lightly porting the intake mani., removing the VTCS, and hopefully painting.
  6. #36
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,593
    Someone on here, or used to be, did up a motor using ITB's...........age prevents me from recollecting the username tho. Do remember some thread about it..............
  7. #37
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    I've found a couple threads where people use the blacktop 20v ITBs from a AE101 motor but it looks to be too much money and custom work for now
  8. #38
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Well allot of work went in to Ole Yeller this weekend, I started sanding the floorboards as there was a good amount of rust creeping in on the seams. Started thurs. finished today and started painting. I'm broke af so I'm using flex seal on all the seams and rustoleum primer and paint. This was a rushed project as this is my daily and I need to drive occasionally for work so it's not too pretty, but as long as the rust stays away I'm happy. Next up im cutting some thin toolbox carpet to put on and using double sided tape, apologies for my crappy camera
  9. #39
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,421
    I had holes rusted right through my floorboards.
    I fiberglassed them with epoxy then spread some homemade goo on it made with roofing tar and grease.
    The Diagram Dude
  10. #40
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Thats looks hella clean man, that'll come in handy if my cheap preventative maintenance fails lol
  11. #41
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,421
    It was actually pretty messy but I wanted something oily to soak into the rust and help repel water.
    50% roofing tar and 50% grease. Heat it on the stove to stir together and thin it out then spread it on with a paintbrush.
  12. #42
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,421
    Here's a link to a thread of mine about my battle with rust.
    https://www.mazdas247.com/forum/show...ing&highlight=
    Interestingly, Photobucket appears to have given me my pictures back ??
    They wanted us to start paying up to $300 a year for was was free for years.
  13. #43
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Sweet thanks man this will make for some good reading, and really 300$ a year??
  14. #44
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,421
    Yea, a lot of great build threads were lost.
    People didn't want to pay.
    I managed to download most of my pictures back from them before I was denied access but they were hard to replace back into the threads.
  15. #45
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    387
    Finished the 'interior' woohoo!! The carpet is kinda messy looking but was as good as I could get it, i ended up using spray adhesive for the carpet. Way easier and I didn't even know it existed until today. Really weird having carpet again after so long, but it makes me appreciate it all the more [emoji23]
Similar Threads
  1. Another Slow MSP College Budget Build
    By mica.msp in forum Pics & Builds
    Last Post: 03-08-2015, 10:28 PM
  2. My slow Mazda 2 build
    By jdm2 in forum Mazda2 General
    Last Post: 02-24-2015, 08:23 AM
  3. Aw_MP5 - Build Thread - Slow Build
    By Aw_MP5 in forum Protege5 Builds
    Last Post: 05-13-2014, 12:45 AM
  4. My extremely slow, broke build.
    By Messyswindler in forum Other Mazdas
    Last Post: 12-19-2012, 12:55 PM
  5. Filthaypinoy206's low n slow build
    By Filthaypinoy206 in forum Mazda3 Accessories & Appearance
    Last Post: 04-14-2012, 09:45 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
