VersaTuner - tuning software for Mazdas
Page 18 of 18 FirstFirst ... 8161718
Results 256 to 266 of 266
Thread: Slow NA Pro5 build
  1. #256
    Registered Member STudMUffin1177's Avatar
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    Still looking for an mp3 ecu or someone to flash mine, I'm using part numbers
    FS9N-18-881
    FS9N-18-881B
    FS9N-18-881C
    But nothing is popping up damnit, all I get is the sedan ecus and the pro5 ecu, or rx7 and miata computers for some reason
    Sunburst 02 pro5 200k+ miles
    Mystery 4-1 header, mystery short ram, moog control arms, moog front endlinks, moog tie rods, moog trailing links, tein lowering springs, gutted interior
    All about them stickers, crumpled panels, and mismatched paint yo
  2. #257
    Comp Engineering Student Riot_Polizei's Avatar
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    516
    Damn, 300 bucks shipped to you? Must be nice to have that luck and have the space! I would love both lol
    Have you checked any of the facebook groups for an MP3 ECU? It seemed like after I got mine, there was an explosion of availability for that thing.
    And it's a smart move to want to learn how to drive your car under hard performance settings stock--too many people forget that's how your develop real skills. However, if you ever find yourself wanting for some turn-in and roll reduction, hit me up. I got a spare Racing Bear rear swaybar asking for some use! Although, I might paint it first. Looks a little rough.
    2002 Mazda Protege5
    ■ Sunburst Yellow ■ Black Rear Valence ■ Injen Cold Air Intake ■ Racing Beat Catback Exhaust ■ Moog Front Endlinks
    ■ Megan Racing Rear Strut Tower Bar ■ Racing Beat Rear Sway Bar ■ Mazda6 Front Big Brakes ■ Foglight Deletes
    ■ OBX 4-1 Headers ■ MP3 ECU ■ VTCS-less Intake Manifold ■ Mishimoto Aluminum Racing Radiator + Fan Shroud
    ■ AWR Trailing Arms
    ______________________________
  3. #258
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    Super lucky, but I dont really have space, I'm just gunna stip it in my driveway and have someone tow it off when I'm done. My garage is gunna be packed full but hopefully I'll still be able to walk around it. I've gone through facebook a couple times and I cant find anything, it's also been about 3 years since I've been on there so I might have missed some search settings or something. I would love to get that sway bar off you but with my parts list and the donor car coming in, paired with the baby I'm a bit strapped for cash for probably the next 6 months. I'll let you know if I get some spare cash for it.
  4. #259
    2002 Mazda Protege5
    Join Date
    Jan 2018
    Location
    Colorado
    Posts
    516
    Quote Originally Posted by STudMUffin1177 View Post
    Sure thing man, I'll keep an ear out. Good luck with the kid on the way! With that parts P5 stripped, that kid of yours will plenty of toys to play with lol
  5. #260
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    Quote Originally Posted by Riot_Polizei View Post
    If he can make it through the maze! I'm kinda thinking of swapping all the blue doors and the bumpers and hatch on yeller, not sure how ricy that would look. Kinda going for a rally inspired look to it, yellow and blue are some classic schemes in the early rally cars, lol especially Subarus.
  6. #261
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    Well lots of small updates, I have a pretty big leak in my rear hatch, bottomed out twice, and bent a trailing arm. Had a puddle in my spare tire so I pulled the rubber caps for some drainage, still gotta find the leak though. Bottomed out at the jobsite it the rocks and then again in tacoma doing 40. I think the latter did the damage, now I have a nice bounce and it's probably a wheel bearing. My right rear trailing arm I just installed is bent out and up as the back passenger side sits half an inch higher. Good stuff, hopefully the parts car has a decent one. Gotta get a new jack and check the bearings and tires, last time it bounced like this there was a bubble in my tire. Well no time to fix as the work truck is down with a bad fuel pump, we are stuck on broken bed bolt tabs. Bout ready to cut em haha damn fords
  7. #262
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,343
    .. I have a pretty big leak in my rear hatch, ... Had a puddle in my spare tire so I pulled the rubber caps for some drainage, ..
    I just cut a little notch in the caps for drainage, I didn't want dust blowing in.
    I don't care where the water is coming in as long as it goes away. Lol
    Check your left and right wheel well areas where your jack is.
    I had water in there too.
    I just drilled holes to drain the water, then when they rusted out, I stuffed an oil-soaked rag n the hole. Lol
    ..., now I have a nice bounce and it's probably a wheel bearing..... Gotta get a new jack and check the bearings and tires.
    Hopefully, it's the rear bearings if it is bearings. They're a lot easier to replace.
    The Diagram Dude
  8. #263
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    I'ma have the girlfriend run water over the back while I sit inside to watch, I'm gunna drill holes if i cant get it to stop. My hatch might be tweaked a bit after that guardrail lol
  9. #264
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,343
    Check your tail light seals and bolts.
    https://www.mazdas247.com/forum/show...pare-tire-area
  10. #265
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    I know my passenger side is screwed because the 3rd stud doenst line up, but the puddle is mostly in between my strut tower bar favoring the right side a little. Either way I'll know tonight..... if I remember lol
  11. #266
    Mazda protege5
    Join Date
    Jan 2016
    Location
    Graham, WA
    Posts
    372
    Well found the leak, it's coming from my poorly fit tailight lol. Also got the ranger going again so yeller can rest for a bit.then
    Beauty shot lol
Similar Threads
  1. Another Slow MSP College Budget Build
    By mica.msp in forum Pics & Builds
    Last Post: 03-08-2015, 10:28 PM
  2. My slow Mazda 2 build
    By jdm2 in forum Mazda2 General
    Last Post: 02-24-2015, 08:23 AM
  3. Aw_MP5 - Build Thread - Slow Build
    By Aw_MP5 in forum Protege5 Builds
    Last Post: 05-13-2014, 12:45 AM
  4. My extremely slow, broke build.
    By Messyswindler in forum Other Mazdas
    Last Post: 12-19-2012, 12:55 PM
  5. Filthaypinoy206's low n slow build
    By Filthaypinoy206 in forum Mazda3 Accessories & Appearance
    Last Post: 04-14-2012, 09:45 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
