Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 6 of 6
Thread: Oil loss, possible burning oil.
  1. #1
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    103
    I seem to be losing oil. As I've noticed my exhaust at times looks smokey (usually seen from my rear view window as I accelerate) I think perhaps the car is burning oil. Last time I had oil changed they mechanic said he didn't see any leaks. I see on the internet it's recommended checking the PCV valve and a cheap easy fix. Just looking for input on what to do next, what I should be looking at. I'm hoping not to spend a lot of money having a full inspection done at the auto mechanic, though it may turn out I have to. Engine has 200K on it.
    Oh and can I check the PCV vlave myself, any caution or concerns in doing that? I think a replacement is like $5-$10.
  2. #2
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,369
    Quote Originally Posted by Holiday View Post
    You can check and replace the PCV valve, however I hate to say it, but you are most likely looking at stuck piston rings. Very common high mileage issue on these motors. There are many threads here on the issue, and on the internet.
    Hopefully others here will chime in with other ideas...
    Mazda's I have owned over the years. (boom07)
    80' Mazda GLC SPORT MT - sold
    81' Mazda 626 DX MT - sold
    81' Mazda 626 LX AT - sold
    82' Mazda 626 DX MT - sold
    82' Mazda 626 LX AT - sold
    85' Mazda 626 LX MT - sold
    87' Mazda 626 GT Turbo MT - sold
    85' Mazda RX-7 GSL-SE MT- sold
    87' Mazda RX-7 Turbo 2 MT - sold
    91' Mazda Protege LX MT - sold
    92' Mazda MX-5 Miata MT - sold
    93' Mazda MX-3 GS-V6 Special Edition MT - sold
    00' Mazda 626 LX-V6 MT - sold
    02.5' Mazda Protege5 MT - sold
    06' Mazda 5 Touring AT - sold
    13' Mazda CX-5 Touring AT - sold
    14' Mazda 3i Grand Touring MT - sold
    15' Mazda CX-5 Touring AWD AT - sold
    03' Mazda Protege5 AT - sold
    16.5' Mazda CX-5 Touring AWD AT - current
    09' Mazda Mazdaspeed3 GT - current
  3. #3
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    Here's a thread with lots of info...
    Don't forget to check the links in the thread.
    https://www.mazdas247.com/forum/show...oke+on+startup
    This post describes the problem...
    https://www.mazdas247.com/forum/show...ld-start/page2
    The Diagram Dude
  4. #4
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    459
    Try putting seafoam in the oil, I believe it*s one tablespoon per quart. Buy two cans and put some in your gas, oil and brake booster line. Some people like to put it in the brake booster and let it sit overnight.
    Maybe that will help clean out any gunk built up from over the years and or cheap oils used.
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    This guy managed to fix his oil burning...
    Quote Originally Posted by n2stox View Post
    I was also burning a quart or so per month...dealer had no idea (compression was fine and all the plugs looked normal) and a 2nd mechanic had no idea except he said there is a lot of gunk in there.
    So, I ran an engine flush detergent (liquimoly) in a warm engine at idle for 15 mins before changing the oil. Smoke in startup was down about 90%. And I had serious spy vs spy smokescreen before...I could fog half the neighborhood. 2 weeks later I did it again....smoke is gone and that was 3 weeks ago.
  6. #6
    Registered Member
    Protege 5
    Join Date
    Nov 2017
    Location
    Canada
    Posts
    103
    Thanks. There are no leaks, PCV valve is good. A mechanic said he saw some oil around a sensor that was wearing out. I forget the name of the sensor, oil pressure sensor I think. The engine has a large degree of what I was told "blowback" so it was suggested it was an internal engine problem (warn piston rings etc.) that would cost more than the price of my car to fix, even to replace the engine. I'll look into Sea foam.
Similar Threads
  1. burning oil... i think
    By lauxrox in forum Mazdaspeed Protege
    Last Post: 09-27-2010, 08:41 AM
  2. burning 2 much gas
    By ONDA82 in forum Mazda Protege
    Last Post: 01-27-2009, 02:14 PM
  3. Replies: 5
    Last Post: 02-13-2008, 10:38 PM
  4. A burning question...About Oil Burning
    By Mazdamia in forum Protege5
    Last Post: 12-20-2006, 05:47 PM
  5. Help with CD burning
    By Matthew in forum Lounge
    Last Post: 08-26-2004, 08:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
