Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Android Auto / Apple Carplay tips and tricks
  1. #1
    Registered Member
    2018 CX5
    Join Date
    Nov 2018
    Location
    CO
    Posts
    35
    Ok, so now that I've had it installed for a few days I thought it would be a good idea for us all to post tips as we muddle through it. Yes there are quick start guides and the 2019 owners manual has very brief instructions but let's go further as we figure things out.
    If you're just starting out and you know nothing about AA/ACP here are Mazdas quick start guides (also, the next post down Studum has a lot of great info for beginners:
    Quick Start Guides
    Android Auto Quick Start Guide
    https://mazda.custhelp.com/ci/fattac...tart+Guide.pdf
    Android Auto Full User Guide
    https://mazda.custhelp.com/ci/fattac...User+Guide.pdf
    Apple CarPlay Quick Start Guide
    Apple CarPlay Full User Guide
    TIP - How to listen to car radio and use AA navigation:
    - Bring up AA maps (e.g., Waze)
    - Long press the Home button to return to Mazda
    - Bring up Radio
    - Now simply long press Home button to switch between AA maps and car radio.
    Note - this is especially helpful to adjust sound levels if you're listening to a music app in AA. While on your music app, long press Home button, go to settings, sound in the Mazda system. Adjust bass, etc... Long press Home again and your back to your music app. Now you can simply long press Home to switch between your music app and Sound settings.
    (Just noticed Studum posted something similar to this description below so I'll make this a duel reference)
    TIP - If an app is not working or functioning properly:
    You may need to open the app first on your phone and getting to the right screen, then starting the car and connecting to AA. Example is Slacker Radio. If I connect to AA alone it doesn't work right. But, if I open the app on my phone first, go to a music station and hit play, then turn on the car and connect AA it works perfectly. Most apps do not require this but if your favorite app is acting strange in AA do this. Also I've heard this is the case for Waze with Apple Car Play.
    TIP - I have yet to figure it out, in AA google map, how does one select the alternative route?!!:
    1. When you select your destination but before you begin the route scroll to the two upward arrows next to the time duration that look like a fork in the road, then choose which alternate route you'd like.
    2. If already navigating, click the single upward arrow next to the time/miles, then click the show routes (same two upward arrows from above).
    3. "You can also pick alternate or dynamic routes while navigating by zooming out in the map, centering the target circle over the alternate route (or the "6 minutes faster" tag), and pressing down on the knob to select.
    This is a function where I would be faster if using my phone with its multitouch screen but it's only a few more seconds extra with the current AA method." - dc16
    PROBLEM - Phone won't connect or won't connect any longer when it did previously to the car.
    Fixes:
    1. "I then read a reddit post that recommended a restart of the Mazda system (back button, nav, volume pressed simultaneously) might help." - maxpower0
    2. Go into the AA app on your phone (when not connected to your car) and go into settings (three bar menu button from the home screen, settings) and make sure your Mazda is on the connected car list - I also have auto launch set to the Mazda as well. You could also uninstall the AA app and reinstall, then connect to the car.
    PROBLEM - Is there a way to adjust the brightness of Maps in Android Auto aside from just adjusting the screen brightness in Mazda Connect for all apps?
    Is there a way to get Maps into night mode like you can do on the phone, so the background is dark?
    Fixes:
    1. Not that I know of in Google maps. If you use Waze (I do), you can set it up in the settings of Waze on your phone. Open Waze on your phone only through the app (do not connect to your car), click on settings, navigation, select Night Night (instead of Auto).
    If this is a big deal to have night mode and you do not use Waze, I would suggest switching. Waze is far superior in my opinion for many reasons (being more customizable for one).
    2. "I believe the dark mode in Maps when AA is connected is tied to car headlights. It goes dark when the lights turn on, on the dashboard. This is my experience, or at least the timing is very close. You can try turning headlights or parking lights on manually if you prefer as a workaround." - Studum
    3. "You can change the display brightness in Android Auto Developer Mode Settings. Explained here...https://www.makeuseof.com/tag/android-auto-tweaks/. The options are to have it controlled by your car, your phone (which goes off of sunrise/sunset times), always day, or always night." - MountainCruzin
  2. #2
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    313
    I posted this in another thread, but good to keep in 1 spot.
    What I've gathered from the HMI / AA interface as a seasoned Android auto user. And what I think Mazda did very well.
    ---the HMI shortcuts revert to Android Auto functions when they're in use.
    ---Using google maps for Nav? Hit the Nav button, you'll go to Maps and not the OEM Nav.
    ---Using Mazda radio while Maps for Nav with Maps displayed? Need to see the radio? Hit the audio shortcut and you go to the radio. Nav shortcut returns you to google maps.
    ---Using an android auto app for audio? The audio shortcut key takes you there from any other menu.
    ---Pushing the home key returns you to the home menu for the system you're in (either car or android auto, depending where you are when you push it). Holding the home key switches between Mazda infotainment and android auto. This is the next-best thing to having a dedicated android auto button on the console.
    ---When in an android auto app screen, the right direction on the knob is a shortcut to the google assistant. The left direction on the knob opens that apps menu (this took me a while to find). The down direction takes the selector to the android auto menu bar.
    ---When in an app its a simple turn and click of the knob to highlight the "button" you want and select it. Super simple once you learn how your apps work with the knob.
    ---Google assistant works quite well for me as voice input for android auto systems: "navigate to (say address)", "call (say person's name, home / mobile etc", "Play this podcast", "What's the weather tomorrow", "What was the score in the (insert favorite team's name here" game, etc, etc
    I had previously read another user say, as well as myself, that you can't adjust audio settings while using an android auto audio source. YOU CAN. You just can't access the audio settings from the Mazda audio screen because you're using the AA interface. When in the android auto audio screen:
    - hold home to get to the car's menu
    - select settings and enter
    - tab over to audio
    - adjust as necessary while using AA as the source
    I found the above workaround when I realized the audio settings are not build into Mazda's audio screen. The audio settings button in the Mazda audio screen is simply a shortcut to the tab in the settings app.
    Hope this helps someone
  3. #3
    Registered Member
    2018 AWD GT Premium Red/Black
    Join Date
    Feb 2017
    Location
    WA
    Posts
    534
  4. #4
    Registered Member
    2018 CX5
    Join Date
    Nov 2018
    Location
    CO
    Posts
    35
  5. #5
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    313
  6. #6
    Registered Member
    2018 CX5
    Join Date
    Nov 2018
    Location
    CO
    Posts
    35
    I've consolidated quite a bit of info from knowledge I've gained and from others' posts into the original post of this thread. I'll continue to do so and let me know anything else you want to add by posting in this thread.
  7. #7
    Registered Member
    Mazda 2018 CX-5 GT Tech
    Join Date
    May 2015
    Location
    Vancouver BC
    Posts
    62
    Might be a stupid question but I have yet to figure it out, in AA google map, how does one select the alternative route?!! Ive tried all buttons and no avail, please help!
  8. #8
    Registered Member
    CX-5 Touring
    Join Date
    Oct 2017
    Location
    San Jose
    Posts
    150
    Quote Originally Posted by murky View Post
    You know that button you use to reset the trip in your car? Twist it like a dial, it will adjust the screen brightness.
  9. #9
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    313
    Quote Originally Posted by eniahal View Post
    This I haven't figured out yet.
  10. #10
    Registered Member
    2018 CX5
    Join Date
    Nov 2018
    Location
    CO
    Posts
    35
    Quote Originally Posted by sjtilney View Post
    There are two ways:
  11. #11
    Registered Member
    '17 3 & CX-5
    Join Date
    May 2017
    Location
    Canada
    Posts
    313
    Quote Originally Posted by Colorado_2018 View Post
    There are two ways:
    I assume this is to check alternate routes and not adjust brightness as quoted? This is great and I will check it out, thanks!
  12. #12
    Registered Member
    2018 CX5
    Join Date
    Nov 2018
    Location
    CO
    Posts
    35
    Ha - yeah that's right. Looks like I quoted the wrong quote. Who knows what I was doing. But yes, in reference to the alternate routes in Google Maps.
  13. #13
    Registered Member
    2017 CX-5 GT AWD
    Join Date
    Feb 2017
    Location
    NYC
    Posts
    208
  14. #14
    Registered Member
    MAZDA CX-5 Touring
    Join Date
    Nov 2018
    Location
    CA
    Posts
    1
  15. #15
    Registered Member
    2016 Mazda CX-5 GT AWD + Tech
    Join Date
    Apr 2016
    Location
    Ohio
    Posts
    18
    On Apple Carplay, if you have trouble with Spotify not wanting to launch, unlock your phone and try again. For some reason the Spotify app never seems to launch on my phone/car unless the screen is unlocked. Once it is launched, I can lock the phone again.
Similar Threads
  1. CX-5 Android Auto / Apple CarPlay
    By Antoine in forum CX-5 Infotainment
    Last Post: 01-14-2019, 10:32 PM
  2. Apple CarPlay and Android Auto
    By mifanning in forum CX-9 Infotainment
    Last Post: 01-10-2019, 11:54 AM
  3. Replies: 10
    Last Post: 12-30-2018, 12:03 PM
  4. Apple Carplay and Android Auto
    By MPCX in forum CX-9 Infotainment
    Last Post: 03-28-2018, 10:57 PM
  5. Replies: 7
    Last Post: 01-01-2018, 04:41 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
