2011 fwd clunking when off gass Motor mtns?
raid
2011 CX-9 GT FWD RES
At low speeds when I accelerate slowly and take your foot off the gas on the front driver side theres a small mechanical clunking thats ever so subtle. I can feel the clunking coming through the brake pedal and the steering wheel I suspect its a engine mount and maybe when I decelerate the engine dragging is causing the engine to tilt and clunk.
About two years ago the dealer replace the engine mounts on the warranty but they only replace two out of the three I dont know which one they left in there at that time I noticed engine mounts because when shifting from reverse to drive theres a huge engine clunk sound.
How do I check to narrow down whats causing this mechanical clunking sound?
And are there any instructions online somewhere on how to replace the engine mounts on a 2011 CX ?
Solved, replaced the bottom motor mount and reinforced with polyeurathane roof caulk
Solved, purchased a cheap new lower motor mount, figure I replace cheapest option and move up from there. The new lower mount was reinforced with polyurathane roof caulk filling in the voids like cupcake icing on bothsides. Took over 2 days to dry.
Swap was relatively easy, 17mm, 19mm , and 12mm bolts, needed to remove the 19mm bolts for the brack so 17mm bolt can clear the exhaust. No more clicking on deceleration or when letting off the gas.
Latest posts
