heyitsrain
- Protege5
So I have a water leak coming from my passenger side floor. After being not busy anymore I decided to investigate the water leak. Before I could investigate, I did some research and found these threads that helped me locate where my leak was coming from.
https://www.mazdas247.com/forum/showthread.php?123803203-Passenger-side-water-leak
https://www.mazdas247.com/forum/showthread.php?123723897-BIG-Water-Problem
https://www.mazdas247.com/forum/showthread.php?123827490-firewall-cabin-water-leaks
So I decided to test the roof rack since the previous owner took off the roof rack, but no luck. Tested the door if it was leaking, again no luck. But when I tested the wipercowl basing from the links above, long and behold it did leak. As I was observing the wiper cowl, it was only leaking when the water is kind of overflowing and going into where the outside air is coming inside the cabin. With that being said, I concentrated the water in full blast where the outside air is coming from and this happens:
Yup, its pretty bad. Also, I saw some rusts around where I was putting water into, I cant see it clearly becuase its on a tight spot and i cant even fit my hand to reach it, so I do not know the condition of that rust. Question is, (I know this is a stupid one, forgive me) can water really go where the outside air is coming from? Or theres some big ass hole around the vent? Thanks!
