CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 2 of 2
Thread: 2013 Mazda 6 check engine codes P2243 and P0134
  1. #1
    Registered Member
    2013 MaZDA 6
    Join Date
    Dec 2018
    Location
    Auburn ny 13021
    Posts
    1
    Hi,
    Two Fridays ago we had a very rainy and raw day here in New York. On my way back to work from lunch, my check engine light came on. When I got back to work, I took the gas cap off and put it back on. Four hours later when I went to work, the light was off. About a week later, we had another rainy day and after driving through a puddle the light came on again. I took it to AutoZone to be scanned. They gave me codes P2243 and P0134. They cleared the codes and the light came on again on a wet day.
    AutoZone said the codes mean both O2 sensors need replacing. Is this true, or should just the upper one be changed?
    Please advise...I an 99% sure I can change the upper one as it's right on the top of the engine. I'm not so sure about the one by the catalytic converter though.
    Thank you in advance.
    Dave
  2. #2
    Registered Member
    2014 Mazda 6 GT with MRCC
    Join Date
    Dec 2013
    Location
    Pennsylvania
    Posts
    144
    Yes it sounds like the O2 sensor is dead. You just need to change the pre-cat one and I suspect you're over 100,000 miles by now on a 2013? Average O2 sensor makes 120-150k miles max. Any O2 sensor after the cat is only to determine there is a cat converter present and can be ignored.
    2014 Mazda6 Grand Touring with MRCC - Soul Red with Almond interior
    2018 Mazda CX-5 Touring with Preferred Package - Snowflake White with Charcoal interior
Similar Threads
  1. Replies: 2
    Last Post: 01-19-2018, 02:24 PM
  2. First Check Engine light! P2243
    By Olde English 5 in forum Mazda5 Engine & Transmission
    Last Post: 07-04-2017, 04:08 PM
  3. Could use some help with check engine codes!
    By nelvolks in forum Protege5
    Last Post: 05-04-2017, 01:14 AM
  4. check engine light >>> P0134 01/02 with P0131 02/02
    By callphy in forum Mazdaspeed Protege
    Last Post: 09-01-2013, 11:28 AM
  5. check engine codes
    By jdmdikk in forum Protege5
    Last Post: 03-12-2010, 01:34 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
