Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: power folding mirrors
  1. #1
    Registered Member
    2018 CX 5 TOURING
    Join Date
    Sep 2018
    Location
    Colorado
    Posts
    82
    Now that power folding mirrors are finally available on the '19 cx 5, do you think they will be made available as a retrofit for older models?
    Hope so; my garage is a bit tight.
  2. #2
    Registered Member
    2017 CX5 GT AWD w/ PP & 2016.5 CX5 GT AWD w/ Tech and Nav
    Join Date
    Dec 2017
    Location
    New Jersey
    Posts
    126
    I would love that as well, but my suspicion is no. Like the preferred package, it would have to be a factory install. (Fingers crossed I am wrong!)
  3. #3
    Registered Member ceric's Avatar
    2017 Mazda CX-5 GT, 2016 Mazda6 iGT, 2014 Mazda3 sGT hatchback
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,486
    When I got my '16 Mazda6 GT, I called a Mazda dealership in a country where their Mazdas have power-folding side mirrors as standard equipment.
    The mechanic told me that it takes lots of works/$$$ to make it possible.
    1) new mirrors
    2) new switch panel (on the inside)
    3) software update
    So, I gave it up.
    Mazda is making this power-folding mirrors standard on high end models of '19 CX9, and '19 CX5.
    It should be on the '19 Mazda6 also (next April).
    Not sure if the Mazda3 will have it. Extra cost, you know.
    BTW, I said this before.
    There is a plastic gear in this power-folding mechanism.
    It tends to fail under resistance (such as dirts in the gaps).
    Also, tend to fail if water gets into the electronics/motor, etc. (such as auto carwash)
    Be aware of these problems that owners in other countries have experienced.
    2016 Mazda6 iGT + Tech Pkg
    ....Sonic Silver Mica / Parchment
    ....Soul Red Metallic / Almond
  4. #4
    Registered Member
    None
    Join Date
    Mar 2017
    Location
    Chicago, IL
    Posts
    49
    No. Auto makers donít usually make features found on current production models available as a retrofit to older models. And even if they did, it would be very expensive.
    I read somewhere that auto makers sometime in the near future will do away with outside mirrors completely. Cameras and interior monitor screens will replace outside mirrors. Back up cameras in cars currently in production already work like this. If an outside mirror camera fails, until it gets fixed, will cause you a sore neck from turning around to see whatís behind you.
    Read this: https://asia.nikkei.com/Business/Com...s-in-new-model
  5. #5
    Join Date
    Jan 2008
    Location
    Northern California
    Posts
    4,486
    Well, look at the size of that side camera(?).
    You will need auto-folding.... and more so since it becomes even more expensive....
    BTW, 2019 Lexus ES (JDM) will carry this side camera.
    US? No. It does not comply with vehicular codes.
    Codes need to be changed first. Japan updated the codes last year.
  6. #6
    Registered Member ijaen's Avatar
    2016 Touring CX-5 w/ 2.0 engine
    Join Date
    Apr 2016
    Location
    Panama city, Panama
    Posts
    122
    Quote Originally Posted by ceric View Post
    1) new mirrors
    3) software update
    So, I gave it up.
    Dealer just replaced mine because of a noise. Never had any issues and sure the system was working fine but since the cars will be out of warranty soon the service advisor told be they would replace both sides under warranty. No noise now.
  7. #7
    Registered Member
    2019 cx-5 gt T
    Join Date
    Jan 2019
    Location
    Ontario Canada
    Posts
    20
    Hate to start a new thread or maybe my searching technique sucks lol.
    Does anyone know how to shut this function off on a Canadian 19 GT T or signature? Terrified the weather will possibly break it (unlocking when frozen, freezing rain, etc). I went through the menus but couldn*t find it. Last resort is covering with bags on snowy nights lol.
  8. #8
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    341
    wasnt there an auto button and manual below it?
  9. #9
    Registered Member
    2019 cx-5 gt T
    Join Date
    Jan 2019
    Location
    Ontario Canada
    Posts
    20
    I tried a three button technique briefly tonight but gave up as it never worked (acc on). I donít think there is a manual / auto button, Iíll check in the morning tho. I hope itís that easy and Iím just dumb. Lol. As a temp fix I covered with plastic bags and a elastic band. Itís snowing here and Iím not taking any chances.
  10. #10
    Registered Member
    2019 Mazda CX-5 Signature; 2019 Mazda MX-5 30 AE, RF, #150/3000
    Join Date
    Jun 2016
    Location
    Austin, TX
    Posts
    408
    I*ve successfully turned mine off.
    The instructions ARE in the owner*s manual.
    Not near the manual at the moment, but IIRC the ignition has to be in the on (not acc) position and window lock button depressed (windows disabled).
    On the driver*s door, simultaneously press the passenger-side and both rear window buttons in the window down direction.
    Hold for three or more seconds and then release.
    There*s no beep or other signal to confirm the change, but the mirrors not folding when the ignition turns off indicates success.
    2019 Soul Red Crystal Metallic CX-5 Signature
    2019 Racing Orange MX-5 Miata RF/MT 30th Anniversary Edition (9th Miata)
    29 Mazdas since 1974
  11. #11
    Registered Member
    2019 cx-5 gt T
    Join Date
    Jan 2019
    Location
    Ontario Canada
    Posts
    20
    Thanks turbo. I tried doing that procedure in the middle of the night here while the snow was falling and couldnít get it to work. Iím going to use a blow dryer at a safe distance to make sure nothing is frozen inside before unlocking my vehicle today. I plan on bringing it to my dads shop later today and hopefully can figure out the disabling method. I was prolly screwing something up...
  12. #12
    Registered Member
    2019 CX-5 GT-PP
    Join Date
    Jan 2019
    Location
    Massachusetts
    Posts
    35
    I used the 3 button technique successfully on my new 19 GT+PP (US). I followed the instructions almost exactly. First make sure the window lock is on, then turn on the ignition, then immediately hold down the three window buttons simultaneously while counting three seconds slowly.
    Iím undecided about leaving it on or off. We have a garage and I work at home, so I can usually avoid driving in freezing rain or heavy snow conditions. On the other hand, in suburbia Iím not sure thereís any value to automatic folding and itís easy enough to turn the knob to manually trigger the folding.
  13. #13
    Registered Member
    2019 CX-5 GT-PP
    Join Date
    Jan 2019
    Location
    Massachusetts
    Posts
    35
    Quote Originally Posted by Turborascal View Post
    On mine, the mirrors fold when I lock the door, not when I turn off the ignition. They unfold when I unlock the door. I*m not sure if this is connected to some other setting. I*m not even sure if it was different before the first time I disabled the automatic folding (since reenabled).
  14. #14
    Registered Member
    19 CX-5 Signature
    Join Date
    Mar 2017
    Location
    PA
    Posts
    118
    Quote Originally Posted by GaryMx View Post
    I*m undecided about leaving it on or off. We have a garage and I work at home, so I can usually avoid driving in freezing rain or heavy snow conditions. On the other hand, in suburbia I*m not sure there*s any value to automatic folding and it*s easy enough to turn the knob to manually trigger the folding.
    My thoughts too. For now *we* have them on auto (mostly because my wife thinks it*s better to have them retracted when parked and it*s her car so...yes dear). If it were my choice, and it*s not, I*d disable the auto. I do like manual via switch power folding mirrors overall though. Really wish my F150 had them..
    19 CX-5 Signature
    Snowflake White Pearl (aka ďwhiteĒ)
  15. #15
    Registered Member
    Join Date
    Jun 2016
    Location
    Austin, TX
    Posts
    408
    Here's the manual page that describes the deactivation process:
    Worked perfectly for me on the first try.
Similar Threads
  1. ooh power folding mirrors
    By jeremy irons in forum Mazdaspeed Protege
    Last Post: 07-20-2014, 09:54 PM
  2. power folding mirrors?
    By jeffietoon in forum Protege5
    Last Post: 06-30-2013, 07:57 PM
  3. JDM Power Folding Mirrors
    By Cyntax in forum Global
    Last Post: 03-17-2012, 06:02 PM
  4. power folding mirrors
    By wwpms6 in forum Mazda6 Accessories & Appearance
    Last Post: 07-27-2008, 10:44 AM
  5. Power folding mirrors
    By Shock in forum Mazdaspeed Protege
    Last Post: 03-02-2008, 04:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
