Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 6 of 6
Thread: removing the lower side skirt mouldings
  1. #1
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    63
    Is there an easy way to remove the side skirt moldings? I want to clean up and inspect the metal underneath for rust. they're held on by clips but i already broke one trying to pull it off. do they have to come off a certain way? and once i get it off how would I get it back on? seems like the clips are covered by the side skirt itself so you can't get a tool in between there without the risk of breaking something.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,534
    I remember taking mine off,... It was kinda tricky but the diagram helped.
    I kinda think the clips hooked in and needed to slide forward or back to unhook,.. But it was along time ago.
    The Diagram Dude
  3. #3
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    290
    Before you do it, go to the dealer and buy new clips. The car is 15 years old, which means the plastic clips have been in the weather and elements for 15 years. You will undoubtedly break at least half of them even if you are careful. I would just order all new clips, and not worry about it. Break them all if you want and reinstall with new ones.
    Even the ones you don't break probably won't seat as tightly as it does now just due to deformation during removal. So you'll end up with loose fitting, gaps, etc.
  4. #4
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,549
    I may has a bag of those laying around since road debris slapped one of mine and had to reattach......a long time ago so that might turn into a search mission in garage at this point. ^^^^^^ what he said above tho..................
  5. #5
    Registered Member
    '02 Mazda Protege5
    Join Date
    Apr 2017
    Location
    Mount Kisco NY
    Posts
    63
    Quote Originally Posted by pb4ugotobed View Post
    thanks. is there a part number or do I just say I need clips for the side skirts?
  6. #6
    Registered Member
    Protege5
    Join Date
    Jan 2015
    Location
    Springfield, MO Area
    Posts
    975
    If I remember correctly these are the clips.
    https://www.ebay.com/itm/Set-of-25-M...lGpn:rk:2:pf:0
    You will break some, best to have them on hand before you try to remove the skirts.
    2002 Protege5 5 Speed, Pure White, FSZE Swap, Konig Incident 17's
    2006 Chevy Silverado 1500 4x4 5.3
Similar Threads
  1. removing side mouldings....
    By Silver Bull3t in forum Mazdaspeed3
    Last Post: 10-10-2010, 05:03 AM
  2. FS: Protege5 springs and side mouldings (everything or best offer)
    By Matt V in forum Completed Transactions
    Last Post: 11-13-2009, 12:19 AM
  3. Replies: 0
    Last Post: 09-30-2009, 08:16 PM
  4. Removing Side Skirt
    By kbach in forum Mazdaspeed3
    Last Post: 01-01-2008, 02:46 PM
  5. should i remove side mouldings?
    By Stealth5 in forum Mazda Protege
    Last Post: 11-07-2003, 02:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
