Hi,
Can anyone tell me if the front differential and transfer case are the same thing on an awd model? Meaning that if I change the oil on the transfer case and rear differential then I*m covered or do I need to change those and the front differental?
Thanks!
So if you get a transmission fluid flush, does that mean the front transfer case/front differential case has been changed as a result? Thanks.
Technically the automatic transmission in CX-5 is a transaxle unit which combines the functionality of the transmission and front differential into one integrated assembly. And ATF is used for lubrication for the entire transaxle unit.So if you get a transmission fluid flush, does that mean the front transfer case/front differential case has been changed as a result? Thanks.
