Results 1 to 7 of 7
Thread: Heater coolant flow direction, inlet/outlet?
  1. #1
    Registered Member
    CX-5 2,2 Aut
    Join Date
    Nov 2018
    Location
    Denmark
    Posts
    3
    Hello everyone
    I'm about to install a heater with an electrical in line pump in my CX-5 2.2D. Would anybody know the coolant flow direction to the heater? Which hose at the firewall is inlet/outlet? Thank you
  2. #2
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,274
    Quote Originally Posted by tagetoft View Post
    Hello everyone
    If you have a good feel of touch the inlet is going to be the hotter one, outlet should feel cooler.
  3. #3
    Registered Member
    CX-5 2,2 Aut
    Join Date
    Nov 2018
    Location
    Denmark
    Posts
    3
    Top is inlet. Heater mount job done.
  4. #4
    Registered Member
    CX-5 AWD, 2017
    Join Date
    Aug 2017
    Location
    Sweden
    Posts
    196
    Hi Tagetoft,
    Nice job and just as winter sets in. It would be nice if you could write a diy on how you installed the engine Heater/ coolant heater and what make did you use so that we who live in Sweden and Canada could use your experience.
  5. #5
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,990
    That's useful because I was having a hard time deciding which line to daisy chain into the turbo set up I prototyping.
  6. #6
    Registered Member
    CX-5 2,2 Aut
    Join Date
    Nov 2018
    Location
    Denmark
    Posts
    3
    Sorry for my late reply * I was off-line *
    Sure: The case is that I dislike the start of ice-cold diesel engines. I usually have a Webasto heater in my cars. Very convenient! I usually install it myself. But it*s an 8-hour job to install the heater. I don*t have the time (or the garage) now. So I was looking for a simple solution to warm the engine.
    A found this one. It has an in line circulation pump. Very simple and a 90 minutes install job. The install is just to cut the hose to cabin heater, mount the heater and arrange the cable to the front bumper. If you put clamps on the hoses you don*t have to drain the coolant fluid.
    9 out 10 times when I want it heated the car is in the drive way next to a power outlet. I have a phone/timer-controlled switch on the outlet. 60-90 minutes of heating makes a nice warm engine to start. A couple of minutes after start the car it*s fully defrosted. I*m pretty happy with it for now.
    Also cheaper with a couple of Kwh instead of 0,4 l fuel to run the Webasto for 30 min *
  7. #7
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,990
    Neat, have not seen a system like this before.
Similar Threads
  1. Dealer Installed Block Heater...or Coolant Heater?
    By buyingconstant7 in forum CX-5 Lounge
    Last Post: 02-07-2017, 03:29 PM
  2. Inlet and Outlet Size
    By 08BlkMS3 in forum Mazdaspeed3
    Last Post: 03-10-2009, 03:37 PM
  3. coolant flow direction?
    By tiwing in forum Mazdaspeed Protege
    Last Post: 12-16-2008, 10:49 PM
  4. Turbo Inlet and Outlet Gaskets
    By Mazdarulez in forum Mazdaspeed Protege
    Last Post: 04-13-2006, 04:38 PM
  5. BPV Inlet-Outlet ID
    By servoeyes in forum Mazdaspeed Protege
    Last Post: 07-22-2003, 01:47 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
