18x8 ET42, which tire size should I use? 215/45/18 or 225/40 or 225/45?
Mazda 5
I just bought a fender roller just in case nasty rubbing, but what will be the best setup? The car is lowered with TEIN Street Advance coilover
Currently it is running stock rim + 225 / 45 / 17, no rubbing issue.
I heard 215/45/18 should be the best fitting with ET40/42, any experience?
I used 225/45/18 for 3 years. Only rubbing with 6 people and roof box
This time when I needed new tires I went with 215/45/18. No rubbing, but I miss the width ..
going to paint them white
I ran 225/50-17, but that was at +52 offset, not +40 to +42. You're 10mm to 12mm closer to the fender. Based on my measurements though, you shouldn't have any problems fitting the 225/45-18. 215/45-18 will be a safer fit, but I'd go ahead and run big. :)
