Made in USA and Free Shipping on all orders shipped inside the US.
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: It happened
  1. #1
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    It happened
    Blew my head gasket some how.
    I took a trip up a mountain to stay in a cabin, there was no overheating or loss of power. I heard a rattling from the exhaust so I turned the car off looked around and didn't see anything. Then I started the car back up, no rattling. Coming down it was smoking profusely.
    I'm going to go back and look at it since I'm home, waiting for it to cool off.
    Also I haven't seen smoke since coming down the mountain. Drove it for an hour no smoke, just checked the oil it doesn't seem to have coolant in it.
  2. #2
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    Quote Originally Posted by NaturalFlavored View Post
    ...Coming down it was smoking profusely.
    .. I haven't seen smoke since coming down the mountain. Drove it for an hour no smoke,...
    Make sure it was coolant you saw.
    You may have been burning oil... Our cars live to do that.
    The Diagram Dude
  3. #3
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    How would I do that? I was still above half on oil and radiator was full as well.
  4. #4
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    This...
    Wouldn't going down a mountain create increased vacuum ??
    "The compression rings are a whole different story, and they are doing their job pretty good.
    To make things worse, oil rings have sooooo weak initial tension, compared to the compression rings, that it is almost natural to have such a result.
    take a look in this picture. Look at the gap between ends of the compression rings, and compare to the gap between oil rings... You will get the idea...
    https://www.horsepowerparts.com/imag...WSC/8550xx.jpg
    Ok, so why does it only smoke on cold starts...
    well, here's why:
    Once you start up the cold engine, there is increased idle rpm, creating a huge vaccum in the intake manifold, as well as in the cylinders, as the pistons are trying to suck the gases in, but the throttle fully closed prevent thet from happening..."
    https://www.mazdas247.com/forum/show...ld-start/page2
  5. #5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    You could have been sucking in enough oil for a smoke show but not enough to use up all your oil.
    Some guys burn a quart every 500 miles.
    I say just drive it for a bit and see how it behaves if the smoking stops put in some seafoam (or equivalent) and stay off the mountains.
  6. #6
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    Ok, that picture to the site doesn't work but I get it.
    Will buy the tester and see what it might be.
  7. #7
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    I drove it off the mountain stopped got lunch, then drove it again nothing. Then stopped for a bit (2 hours ish) and seen just the slightest bit when I slowed down and sped back up.
  8. #8
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    I don't think a blown head gasket kinda comes and goes (but it can if you've got a cracked head that only leaks when hot or cold)
    You need to find out if that's oil or coolant coming out your exhaust.
    The tester will test for coolant in the exhaust. (I don't know about oil)
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    ... Will buy the tester and see what it might be.
    Apparently, they have it as a "loan a tool" at your local parts store.. You just buy the crystals or whatever.
  10. #10
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    OK, so I tried this with the car warmed up, tested from the radiator cap location and the overflow hose location. Tested while the car was on, was pumping for about a minute at each location.
    https://photos.app.goo.gl/Ah4hSmC7QGX4Ao8U9
    This is the outcome. I did not change the fluid to make sure it was getting a better reading on whether it was a head gasket.
  11. #11
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    I've never used that tester before. Does the blue color mean there's exhaust in the coolant ??
    A compression test or a leak down test might be your next step.
    You'd hate to replace your head gasket then find out it was your oil rings.
    Does your car burn any oil ?? Do you ever need to add oil ??
  12. #12
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    Me either so I watched video's of it last night to see. Haha. The tester actually is blue, you put it in your radiator and if it turns yellow/green it means bad head gasket. My car does burn oil but not enough to be noticeable like it was the other day.
  13. #13
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    It freaked me out due to my car has never smoked so much that I wouldn't think it was condensation.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,603
    ...My car does burn oil but not enough to be noticeable like it was the other day.
    I'm thinking your oil rings are starting to seize and coming down the mountain using engine braking just sucked the oil past the oil rings.
  15. #15
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    462
    Might be it was also 35 and driving at 40mph so around 12 is what the engine was feeling and higher elevated.
Similar Threads
  1. what just happened?
    By riccitelli in forum Mazdaspeed3
    Last Post: 04-13-2008, 02:47 PM
  2. WTF really happened??
    By chaosProtege in forum Pics & Builds
    Last Post: 07-21-2005, 03:46 PM
  3. What happened to ION?
    By evilmonkeyMSP in forum Lounge
    Last Post: 07-11-2005, 06:39 PM
  4. Has this happened to anyone else?
    By Speedplease in forum Mazdaspeed Protege
    Last Post: 12-11-2004, 10:56 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
