Made in USA and Free Shipping on all orders shipped inside the US.
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: iddle issue
  1. #16
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    You could put some loctite on the nuts and bolts if you're worried about them vibrating loose.
    The Diagram Dude
  2. #17
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    I only use a torque wrench for my lug nuts.
    But I have a tendency to tighten the hell outta things.
    I don't know what 80 inch/pounds feels like but I'm sure I wouldn't think it's enough.
  3. #18
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    Quote Originally Posted by Pmazda5 View Post
    Thank you Paul
    You're welcome.
    I'd rather do this than work on my own car.
    It's cold out and it's all covered in snow.
  4. #19
    Registered Member Pmazda5's Avatar
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Richmond Hill,ON,Canada
    Posts
    129
    you need to get the hammer out and build a little garage your car is starting to look like mine, white ,thanks for clarifying the torque numbers ,I was thinking that my torque wrench was in in-lbf but its in ft-lbf so my nuts were tight enough but I upped the poundage a bit see if it would help but nothing changed ,if I coud only get brakes to firm up I would take it for a good run but these brakes are a pain to get pressure ,I read a number of threads and everyone seems to not be able to bleed them.looks like I will have to break down and get mazda dealer to help
  5. #20
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    I remember one guy that said you can remove the bolts from the bracket that holds the caliper and rotate the whole caliper to the top of the rotors, the bleeder screw is at the very top and you can get every last air bubble out.
    His rear brakes were soft and he couldn't bleed them properly.
  6. #21
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    ya , I saw that thread, the problem is that my MC was totally drained so suspect air in there not sure how to bleed yet ,when bleeding front the pedal firms up but just slowly sinks to bottom of range , when bleeding and holding the pedal and opening the screw theres not much pressure normally when pump brakes and hold there is a good amount of pressure at bleed screw and will shoot fluid out and squirt under high pressure .not so now
  7. #22
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    IIRC,.. you have to "bench bleed" your master cylinder if it runs dry.
    You may have wrecked your seals when you ran it dry.
    Does your brake pedal hold pressure or does it slowly push to the floor ?
  8. #23
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    That sounds like bad seals in your master cylinder.
    An air bubble will compress but hold pressure. (but it will feel all spongy)
    Leaking internal seals will slowly push to the floor.
    You probably need a master cylinder rebuild kit or this.
  9. #24
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    slowly goes to floor ,yahoo, can seals be replaced
  10. #25
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    If your brake pedal is slowly pushing to the floor but no fluid is leaking out then the fluid is leaking past the seals and seeping back into your reservoir.
  11. #26
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    ... can seals be replaced
    I think so but rock auto doesn't seem to have them.
    They might be a dealer item.
  12. #27
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    thanks
  13. #28
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,831
    They might not be too keen on selling rebuild kits because if you mess it up, you've got no brakes at all.
    It's probably better to replace your master cylinder.
  14. #29
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    good point
Similar Threads
  1. need help with iddle issues
    By menaspeed in forum Mazda6 Engine & Transmission
    Last Post: 11-15-2009, 07:53 PM
  2. Uneven iddle
    By davidleg in forum CX-9 Engine & Transmission
    Last Post: 11-09-2009, 05:28 PM
  3. Iddle RPM
    By JasonBourne in forum Mazdaspeed Protege
    Last Post: 04-10-2009, 11:45 PM
  4. iddle issues
    By MSPLIFE in forum Mazdaspeed Protege
    Last Post: 11-28-2008, 07:23 AM
  5. iddle speed adjustment
    By nele in forum Global
    Last Post: 04-27-2005, 06:26 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
