VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: iddle issue
  1. #1
    Registered Member Pmazda5's Avatar
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Richmond Hill,ON,Canada
    Posts
    129
    iddle issue
    Hi, The problem is that after taking apart everything to get to the manifold to take it off ,I ended up not removing it so put everything back together for some reason the car doesn't idle properly and dies ,any ideas where to start should I scan with OB11 scanner ,would that show anything .Thanks Alex
    Better tell you that the manifold was loosened but did not take completely off ,just tightened up nuts with old gasket,,, would I have had to replace it. Thanks ,,,,,,, Gasket that is
  2. #2
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    342
    Check vacuum lines?
  3. #3
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    ok thanks
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Spray around with carb cleaner to find a vacuum leak.
    The car needs to relearn how to idle the car after an ECU reset (disconnected battery).
    My car almost stalls but not quite.
    The Diagram Dude
  5. #5
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    will give a try, thanks
  6. #6
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    sorry but nothing happened with the spay around ,the last time I started the engine it idled somewhat longer but still cutting out,Ill try to drive it but battery giving probs and brakes also so have to do some work ,never ends it seems
  7. #7
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    I takes about 100 miles of driving for the ECU to relearn how to idle the car.
    It takes different amounts of time for each car depending on how far it's drifted from original factory specifications.
  8. #8
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    Thank you ,will drive it when brakes ok
  9. #9
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    need to know the intake torque{ in- lbf} for some reason it doesn't give me the info in my service manual that I downloaded from e manual site. Unless I'm not seeing something
  10. #10
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
  11. #11
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    It doesn't show the torque in-lbs for the intake manifold,I'm somewhat baffled,I think 16 in-lbf may be low for it.So I'm thinking that I'll'tighten it as much as I think it should be . If you look at the air ntake black piece it says 80in-lbf I would think that the Mani would be more than that Thanks
  12. #12
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    You just multiply the 16 foot pounds by 12 to get inch pounds.
    So 192 inch pounds.
    It's all in foot pounds unless otherwise noted.
  13. #13
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    Quote Originally Posted by Pmazda5 View Post
    ... If you look at the air intake black piece it says 80in-lbf I would think that the Mani would be more than that Thanks
    The "80" is Kg/cm or 69.5 - 95.4 inch pounds.
  14. #14
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,663
    ...If you look at the air intake black piece it says 80in-lbf...
    If your talking about the fresh air duct (part #1), it's a plastic piece so you don't want too much torque or you would squash the plastic.
    So about 80 inch/pounds is about right.
  15. #15
    2003 protege 5
    Join Date
    Jun 2008
    Location
    Posts
    129
    Thank you Paul
Similar Threads
  1. need help with iddle issues
    By menaspeed in forum Mazda6 Engine & Transmission
    Last Post: 11-15-2009, 07:53 PM
  2. Uneven iddle
    By davidleg in forum CX-9 Engine & Transmission
    Last Post: 11-09-2009, 05:28 PM
  3. Iddle RPM
    By JasonBourne in forum Mazdaspeed Protege
    Last Post: 04-10-2009, 11:45 PM
  4. iddle issues
    By MSPLIFE in forum Mazdaspeed Protege
    Last Post: 11-28-2008, 07:23 AM
  5. iddle speed adjustment
    By nele in forum Global
    Last Post: 04-27-2005, 06:26 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
