VersaTuner - tuning software for Mazdas
Results 1 to 11 of 11
Thread: Stuck Front Rotor
  1. #1
    Registered Member
    Protege5
    Join Date
    Sep 2018
    Location
    Ontario
    Posts
    7
    Stuck Front Rotor
    Like the title says, im having trouble with my 2 front rotors being really stuck. I replaced all four calipers and did all my breaks except for my front rotors. All i did was hammer the rotor but it wont even slightly bulge and spray it with pb blaster. What is the size of a bolt that I can put in the hole on the front rotor? (circled on the picture below). And is there another way to try to break it free?
  2. #2
    Registered Member Corphish's Avatar
    83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    350
    I have a snapon dead blow I use to break these suckers free but the trick is to hit the hat between the lug studs. See if you have a bigger hammer? I hope you’re not using a claw hammer.
  3. #3
    Registered Member
    Protege5
    Join Date
    Sep 2018
    Location
    Ontario
    Posts
    7
    Well been hammering it for quite sometime now, i dont want to buy a bigger hammer just for this one if I can buy a bolt thru that hole which is the only purpose of that hole
  4. #4
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    On my car, the t-bolt that holds down the jack in the trunk fits that threaded hole.
    You could see if it fits the threaded hole then us it to take to the hardware store to match up to a bolt.
    It's made out of cheap metal and you'll need a better quality bolt.
    The Diagram Dude
  5. #5
    Join Date
    Aug 2016
    Location
    Baldwin, WI
    Posts
    350
    Quote Originally Posted by heyitsrain View Post
    Buying a hammer for this one job would be a small waste of money but buying a new hammer you will use on future projects. Still like the t handle idea tho
  6. #6
    Registered Member NaturalFlavored's Avatar
    Mazda P5
    Join Date
    Feb 2015
    Location
    Tucson
    Posts
    499
    My front rotors come right off after taking off the caliper.
    I don't know how it'd be stuck on there that badly.
  7. #7
    2008.5 MGM MS3 rsvinylgraphics's Avatar
    Donated: $5
    Join Date
    Oct 2009
    Location
    Indiana
    Posts
    1,137
    Quote Originally Posted by NaturalFlavored View Post
    well you live in Arizona, he lives in Canada - RUST
  8. #8
    Registered Member Saudade's Avatar
    2003 P5
    Join Date
    Nov 2018
    Location
    SoCal
    Posts
    5
    No issue in this CA .
    Try some heat with a torch. Focus on the rotor around the hub, between the studs.
    2003 Protege5, Auto. Approx 224k
  9. #9
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    I had to buy a sledgehammer to get my wheels and rotors off.
    I took off the lug nuts and booted the hell out of the tires and they wouldn't budge.
    My 8 pound sledgehammer worked though,.. tires and rotors.
    To the OP... Put some grease or anti-seize between the hub and rotor and between the rim and rotor... It makes getting them off way easier next time.
  10. #10
    Registered Member
    17 Mazda 6 GT
    Join Date
    Apr 2017
    Location
    Ontario, Canada
    Posts
    529
    This is the price we pay for living in the great white North.
    Pretty much every car I've owned I've had to hammer the crap out of the rotors to get them to break loose.
    On my last car, I used a little wheel bearing grease on the back of the rotor when installing new ones, and that made things a lot easier a few years later.
    I also do the same (grease the inside) on my wheels/rims before installing them. They come off no problem when I need to swap them out or rotate them later on.
    Getting back to your problem, one thing I did in the past was to re-install the wheel, but leave the lug nuts slightly loose.
    Go for a gentle short ride in front of the house, and the weight of the car will break the rust bond on the rotor.
    Sometimes just rocking the car back and forth with the lugs nuts on loose will break the bond. Not too loose though. You don't want to snap the studs.
    Short story: A few years ago I was in Florida, and took my 10 year old Nissan Altima in to a local shop in Orlando for a new muffler.
    The tech couldn't believe the condition of the underside of the car. He'd never seen anything like it. Canada eh.
  11. #11
    Registered Member
    protege5
    Join Date
    May 2016
    Location
    GA
    Posts
    324
    If you are replacing them anyway, take off the caliper and you'll have a big open spot on the rotor. Use the biggest hammer you can find (I use a big deadblow) and hit the rotor from the inside and knock it off. May take a few swings but it'll let loose.
Similar Threads
  1. Stuck front rotor
    By kleinz in forum Mazda5 Wheels, Tires, Brakes & Suspension
    Last Post: 02-06-2017, 04:20 PM
  2. 2002 Protege Front Rotor Replacement - Stuck!!!
    By staspmr in forum Mazda Protege
    Last Post: 06-11-2014, 10:33 PM
  3. MS3 Front Rotor/Pad Replacement How To
    By 2jmotorsports in forum Mazdaspeed3
    Last Post: 08-05-2011, 02:58 AM
  4. WTB: Front brake rotor
    By Hellnightkid in forum Global
    Last Post: 01-10-2006, 06:01 AM
  5. Front Rotor removal??? help!
    By caper007 in forum Mazda Protege
    Last Post: 04-13-2005, 09:56 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
