Hello, Mazda community!
I need your help to find out what is wrong with my CX 5.
I have 2015 Mazda CX 5 GT AWD Technology pack. In which I recently replaced an engine because the old one had a hydrolock due to flooding. The car itself wasn't flooded. It used to stay on the hill tilted, the wave hit it few times and the water reached inside the intake manifold and when my family member tried to start the engine the water get inside the engine and damaged the pistons. Long story short I swapped the engine with the same one but lower miles. Everything supposed to be fine but after I put everything back together and started the engine it used to run great for about 10 - 15 seconds and then stopped. I tried to start it a few times and every time the same result. No check engine light is on but when I plugged a code reader I got this results.
P2119
P2109
P061B
What do you think might be the problem? Maybe I need to recalibrate the throttle body and the pedal sensor? Or it is something more problematic?
I appreciate your time guys, I really need your help to solve this problem and finish fixing the car. Thank you!
P2119
P2109
P061B
