In Memory of Member 1338
Results 1 to 2 of 2
Thread: Camber bolt kits, which hole to install?
  1. #1
    Registered Member grffn's Avatar
    Donated: $8.08
    '02 P5
    Join Date
    Jan 2017
    Location
    Hawaii
    Posts
    244
    Ordered a 2 pairs of MOOG camber kits that arrive today and wanted to make sure I have it all right before I go about installing them.
    From what I've read and looked up, the camber kits go in the top hole for the rear. For the front, I hear mixed opinions whether it's the top hole or bottom hole. At the moment I have more answers saying the bottom hole in the front because the top bolt is already an OEM camber bolt or something?
    Also is the tab facing inward towards the engine and lobe outward?
    TLDR:
    Camber bolts install in...
    Front: bottom hole
    Rear: top hole
    Tabs: faced toward engine, lobe facing outward
    Did I get this right?
    Thanks
  2. #2
    Team Pro5 Jackie chan's Avatar
    Pro5
    Join Date
    Mar 2011
    Location
    Seattle, WA
    Posts
    1,924
    Both front and rear should be in the top hole. As far as adjustment goes, you'll need to get it on an alignment rack to set camber properly.
Similar Threads
  1. Camber bolt install tip + string alignment at home
    By flatlander937 in forum Mazda2 Lounge
    Last Post: 02-15-2015, 04:56 AM
  2. exhaust s-pipe: what is this threaded bolt hole for?
    By chuck b in forum Mazdaspeed Protege
    Last Post: 09-08-2014, 01:50 PM
  3. Camber bolt install tonight, quick question
    By PGTBrow in forum Mazda2 Lounge
    Last Post: 09-26-2012, 12:47 PM
  4. Camber bolt kits
    By ogsp5 in forum Protege5
    Last Post: 12-03-2011, 02:43 AM
  5. Fix stripped bolt hole in valve cover?
    By pasadena_commut in forum Protege5
    Last Post: 12-17-2005, 09:59 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
