Best brakes how? Take a look at the EBC web site, pick a type of brake pad that sounds good to you, and look at the spider diagram. Not all manufacturers have this information available. Tirerack.com shows several pad models and brands with their evaluations. I have had performance pads with great hot bite and poor cold bite--really had to press hard when cold. I won't get those again. Will it need rotors? If they aren't significantly grooved, try sandpapering the glaze off and wash with brake cleaner. About brands...Centric gets good reviews. For performance I've had success with Powerstop and EBC. There are other excellent brands out there. Grooved rotors seem to work better than drilled rotors if you think that added performance is useful. I had grooved rotors on my trailer-towing Tundra with good results.
I went through the EBC pad choice procedure. They recommend either of these
Greenstuff:
EBC medium dust fast street pad with 15% brake improvement
Capable of repeated heavy brake use without brake *Fall-Off*
Very minimal disc/rotor damage characteristics
Superb material for lighter model Asian and European sport compacts
Features red *brake in* surface coating for instant safe braking after install
Ultimax2:
Superb daily driver R90 type approved pad.
Features red *brake in* surface coating for instant safe braking after install.
New 100 % ECO friendly material with ZERO sulphides.
No shims for noise reduction needed.
More bite from cold.
Works in hot and dry climates as well as in cold.
I'd get the Ultimax2 for my driving. Look at the other fine brands as well.
Greenstuff:
Ultimax2:
