I'd have to run premium, and it would still be slow as balls. No.
So per your findings it basically hangs with the new SVT Raptor stock at speed but tuned its 'still slow as balls'? Wait for it..
It*s a beautiful curve too, btw. Almost too pretty to believe, honestly. And no, I*m not saying it*s not real by any means, but I really wanna see the A/F of this thing...
Uh yea, why do you think I wanna see the A/F and timing charts as well? BTW, my dyno charts show them (A/F anyways).Lines up with dynos from individuals available on fb/mazda6forum. There are a lot of very detailed threads on that forum regarding OVtuning on the 2.0/2.5 sky from individuals, as a lot more of those drivers are interested in power gain (it seems). Even the old tunes from 2014 had a much more linear curve. If you have a 16+ CX-5 with a denso ECU you have a better tuning platform and more performance gain than <16 which have Mitsubishi ecu. A/fs are normal.. if they weren't the engine would be pulling timing or limping constantly
Please remember, I*m a supporter of what OVT is doing, I thought it was a sham when he got ran off from here...
Yeah no f'n way he 'matted it' unless it was in limp mode..5.1 to 60 for the new ecoboost Raptor..something doesn't add up here- numbers are numbers but they ain't even close- he's smooshing my gen1 x1 and my x1 smooshes my gen1 CX5.
https://www.caranddriver.com/review...ving-impressions-review-car-and-driver-page-4
The dyno reads to the wheels. Its probably about 160 to the wheels for yours, I would guess with a 14% correction from flywheel to the wheels, so roughly 35hp more...
Wouldn't be so beautiful if it started at 0 rpm.
And stock would be WAY uglier.
The one thing I don't like about the stock tune is how it gets on the cam just above 3k, like an early turbo. Actually it the lack of guts below that I dislike even more.
I'd be interested in seeing that lower half of Chris' dyno.
I'm curious if anyone has ever done an engine-dyno of the 2.5 or 2.0 Sky. I am very curious how much the transmission and accessories rob. I am betting they are pretty damn frugal honestly.
I've never seen a pull start at 0rpm. Usually it's 2500 and up, 1500ish is an exception.
At 0 rpm? Lol -most dyno pulls are done in 3rd or 4th gear. Good luck with that. Rip the engine out and put it on a stand if you want more. That ain*t happening...
Of course a stock dyno won*t be quite as pretty, but it*d be nice to see it graphed over this one...
*3k rpm like an early turbo*. Lol An *early turbo* is torquing hard way before that, and peaking in the 3k*s, running outta steam up top (easy to tune out too, btw).Of course it lacks a little guts down low, it*s a low displacement NA motor with no FI...
Stock 370Z dyno. Note the CFE smoothing factor (the dip seems to be artifact). This is a no-tune car. My 370Z felt like that graph indicates, as well. Very impressive for a 232ci engine!
http://photobucket.com/gallery/http...yhoes/media/NewStock370ZDynoBaseline.jpg.html
As to turbo running out of steam...
That's why you need a proper system. Size the turbo to the engine and the engine timing to the event anticipated via VVT or cams if your engine needs cams (the 370Z does not use cams for the intake valves).
Dude...do you think the new raptor is "Fast"? It's a full-sized truck. It's slow as balls, too. The 1/4 mile speed I'm seeing is 13.8@100mph. Welcome to 1980's econo sports car + mild bolt-ons (CAI + pulley's) territory!
The mentioned 370Z runs in the same ball park as well. Imagine that...5.1 to 60 slow as balls and you're driving a cx5? You must hate yourself
Pretty hard to do in 3rd or 4th gear. Even a street tune is done in the same gears as well...
Been there, done that. I*ve gotta small turbo car that pulls like a raped ape on the top end. It used to fall on its face. Cams, boost held constant to redline, and meth injection are a powerful combo. The low end is still more fun, though, and it should be. If I wanted a true highway puller, I*d go for more displacement, and turbo/s the size of watermelons...
See how this dyno included the a/f. It is a nice curve btw, and I love how the Z cars sounds, but they*ve always been slow to me for what they are. Not a low blow, but I like them in general, and know of two folks here that have twin turbo kits on there*s. Not what you think it would be...
