VersaTuner - tuning software for Mazdas
Page 8 of 8 FirstFirst ... 678
Results 106 to 114 of 114
Thread: More fuel pump relay fun!
  1. #106
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Watch out for the sharp edges on the cover plate.
    The Diagram Dude
  2. #107
    Registered Member Catzilla's Avatar
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    ECU swapped with known good ECU from 2002 parts car. No start.
    Like everything else on this car, someone has already been there - bits of electrical tape sticking out of ECU's wiring harness is a clear indication of shoddy repairs of unknown nature. Several wires have been taped up in there.
  3. #108
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Maybe inspect all the taped connections.
    If the wires were just twisted together and taped, the connection can go bad.
    Vinyl tape leaves sticky goo on the wires over time.
  4. #109
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Check out his thread.
    It may help with your problem.
    (if you didn't already get rid of the car)
    https://www.mazdas247.com/forum/show...=1#post6625002
  5. #110
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    Took a chunk of my tax return and had the Blue Lemon towed (with a freshly charged battery) to a local mechanic I know and trust as being a strictly honest fellow, and who relishes electrical challenges. Gave him the full story and let him have a crack at it.
    The next day, after going through multiple 10 amp engine fuses (apparently they would only blow as he turned the key off after cranking?) and getting some really oddly low RPM readings he found the Root Cause:
    The harmonic balancer/toothed crank position sensor trigger wheel/crank pulley unit was disintegrated. The toothed wheel that the crank position sensor reads is bonded into place with rubber, and this rubber was rotted out with heat and age.
    The oddly low RPM readings were the toothed wheel hanging loose and spinning only partially with the crankshaft. Sometimes it would hang up on the destroyed plastic of the lower timing belt cover and not spin at all - and with no crank timing input from the sensor, the ECM would not send spark.
    One brand-new balancer unit later, car starts and runs fine. It doesn't even blow the 10amp engine fuse any more.
    Now I have a spare car, as my new daily is an amazeballs clean low-mileage B16 Sentra SER Spec-V with 200hp and a 6-speed manual. I will continue to swap good parts onto the Blue Lemon from my parts car (especially interior) and eventually plasti-dip it before my 13 year old son needs a car. I also plan a full timing belt job with new covers, LOL.
    Lesson learned: crank but no spark: check the crank trigger wheel for wiggle.
  6. #111
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Awesome !!
    We put a lot of effort trying to figuring it out.
    I guess we were barking up the wrong tree. lol
    I thought the toothed ring was connected to the inner hub and wouldn't slip.
    I guess it's just glued on like the pulley rings.
    It's gonna bug me as to why it was blowing fuses and has now stopped.
    That sounds too magical for me. lol
  7. #112
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    The toothed ring to pulley hub connection appears to be a co-molded rubber bond. I'm going to take pictures of the new unit when I take it off to do timing belt at some theoretical point in the future when I get my parts car's stripped carcass out of my junk-filled garage.
    The fuse blowing magically clearing up bugs my mechanic too. He went through 3 fuses. He gave me the wiring diagram printouts (a kindred soul, Pcb!) showing how the coils run through that fuse. Me no understand such electro-wizardry.
  8. #113
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Just an FYI.
    Apparently the aftermarket under drive pulleys aren't made with any rubber (they're solid metal) so the toothed ring is probably more rigidly mounted.
    Your mechanic sounds like somebody I'd like to hang out with and talk shop.
  9. #114
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,840
    Quote Originally Posted by Catzilla View Post
    This is bugging me too.
    If the ECU shuts down the engine because there is no crank signal, then it should throw a P0335 code to let us know why.
Similar Threads
  1. How to test Fuel Pump Relay?
    By PowrSlave in forum Protege5
    Last Post: 04-05-2018, 01:03 AM
  2. where is the fuel pump relay on my 01 mp3 protege
    By eaguiar72 in forum Mazda MP3
    Last Post: 09-11-2014, 07:46 AM
  3. fuel pump relay
    By jbrewer4639 in forum Mazdaspeed Protege
    Last Post: 04-07-2011, 07:51 PM
  4. fuel pump relay
    By HONDA_KILLER in forum Mazdaspeed Protege
    Last Post: 01-20-2010, 06:41 PM
  5. Fuel Pump Relay
    By CantCMe in forum Mazda Protege
    Last Post: 10-20-2007, 07:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
