Compare auto reliability with reliable results at TrueDelta.com!
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 114
Thread: More fuel pump relay fun!
  1. #61
    Registered Member Catzilla's Avatar
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    I will just pull the one out of the parts car that I installed in 2006 when the car was just out of warranty but the Michigan road salt had chemically attacked the white plastic and caused leaks after top-off. It should still be good. My main concern is the gas fumes, ugh.
  2. #62
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    We're still chasing gooses (which is funner to say than geese) but I think we've got them cornered now....
    The Diagram Dude
  3. #63
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    I'm fixin' to cook this goose if my trouble lamp ignites the gas fumes.
  4. #64
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    You could make a meal of it,... Thanksgiving and Christmas are coming up...
  5. #65
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    No goose.
    Fuel pump assembly swapped with known good one from parts car, has approx 110k miles and ran great when parked.
    No start.
  6. #66
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Quote Originally Posted by Catzilla View Post
    No goose.
    No start.
    Is it running ??
    Is power going to it ??
    Are the relays powered and clicking ??
  7. #67
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    Quote Originally Posted by pcb View Post
    Is it running ??
    Can't hear anything.
    There are two sets of terminals. One has B+, the other nothing.
  8. #68
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    See if you can hear/feel the main and fuel pump relays clicking when the ignition is turned on.
  9. #69
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    The B+ may be for the fuel gauge ...
  10. #70
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    If Nathanagnew comes over I will have him turn the ignition while I feel the relays.
    This car is cursed.
  11. #71
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    Do you have B+ on the red/white wire or the gray wire ??
  12. #72
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    You could pull your INJ fuse to feel a click.
  13. #73
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    Gray
  14. #74
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    5,104
    You need B+ on the red wire with a green stripe to have power to the fuel pump.
    You could check to see if you have spark (this can maybe wait)
    Remove a plug put the sparkplug boot back on and lay it on the valve cover.
    If you don't have spark, then your ECU has shutdown the car.
    Check for continuity on the black wire going to the fuel pump.
    With the battery disconnected, test for ohms between the black wire and ground,... It should be near zero.
  15. #75
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    Pulling INJ fuse and replacing it causes a loud click from intake area.
    Leaving INJ fuse in, pulling green main relay and replacing it causes loud click from intake area.
    Note that no click can be heard from green main relay even though it's demonstratebly sending power to some relay in intake area. Likewise, no clicks can be heard from black fuel pump relay(s) but before my alligator clips quit working I know I got clicks from both of them.
    So sick of this car. Morale is low.
Similar Threads
  1. How to test Fuel Pump Relay?
    By PowrSlave in forum Protege5
    Last Post: 04-05-2018, 01:03 AM
  2. where is the fuel pump relay on my 01 mp3 protege
    By eaguiar72 in forum Mazda MP3
    Last Post: 09-11-2014, 07:46 AM
  3. fuel pump relay
    By jbrewer4639 in forum Mazdaspeed Protege
    Last Post: 04-07-2011, 07:51 PM
  4. fuel pump relay
    By HONDA_KILLER in forum Mazdaspeed Protege
    Last Post: 01-20-2010, 06:41 PM
  5. Fuel Pump Relay
    By CantCMe in forum Mazda Protege
    Last Post: 10-20-2007, 07:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
