CorkSport.com is MAZDA PERFORMANCE!
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 114
Thread: More fuel pump relay fun!
  1. #16
    The Diagram Dude pcb's Avatar
    2002 mazda protege 5
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Try swapping your main relay with the parts car.
    But both relays should click when the fuse is plugged in and out.
    See if there is power in the socket for the INJ fuse.
    There should be power to one of the terminals.
    The Diagram Dude
  2. #17
    Registered Member Catzilla's Avatar
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    Main relay is green, right?
    Both the green ones I have on hand go clicky when given 12v.
    There's 11.5 volts going to the INJ fuse.
  3. #18
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Its looking like the power isn't getting through to the INJ fuse.
    Look for the fat black wire going into the fusebox and check for+12 V in the connector.
    Try to follow the fat black wire through the fusebox., checking for +12 V along the way.
  4. #19
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Fuel pump relay is #2, main relay is #4. (I don't know about color.)
  5. #20
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Quote Originally Posted by Catzilla View Post
    The power goes from the INJ fuse right to the main relay.
    Try to trace the connections between the two, looking for a bad connection.
  6. #21
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Looking at your picture, the main relay is green.
    You should have +12 V on one of the terminals in the main relay all the time.
    It's sounds like power isn't getting from the INJ fuse to the relay.
    Try to clean up the contacts in and under the fusebox. The scorched ones are probably for the main and fuel relays.
  7. #22
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    So basically I have to pull the entire damn harness out of the car.
    It dawns on me that this fusebox isn't a power distribution box. Wires bring power in, the power either passes thru a fuse or waits to pass a relay, then leaves to goes to run something like a fuel pump. If it splits, those splits are buried in white plastic and not serviceable. This is even true for the 100 amp main, it comes direct from battery + and goes off into la-la-land in the harness that dives under battery.
    From your diagrams, pcb, there should be some indicator where in the harness power comes from, leading to the INJ fuse which is receiving less than 12v, and where it goes in the harness before returning to the fusebox to the fuel pump relay, at which point the juice leakage has reduced it to less than 1v. I have to find the bad spot(s) in the harness.
  8. #23
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    I found this...
    Your fuse box is probably OK because it was working.
    Focus on the connectors underneath that are kinda scorched.
    Try to get continuity from the INJ fuse to the main relay.
  9. #24
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    I just took this picture of my fuse block with the engine off and key removed...
    Do you get B+ (11.5 V in your case) between battery negative and the right side terminal in the connector for the INJ fuse ??
  10. #25
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    No continuity between INJ fuse and green main relay. With ignition on, no power to signal side of green main relay.
    Fault lies in harness or connectors between INJ fuse and green main relay. Really not looking forward to trying to repair this.
    The scorched-looking connectors on the fuse box bottom have no melting, just browned grease, and their metal spare-grabbers look good.
    I'm may give up and part the car out over this. I just paid hundreds of dollars for a bonded title and registration, $170 for a new starter, $300 for brand new rear calipers and brackets, $125 for brand new pads and rotors, $400 for new A/C compressor from the rusted out car, and hundreds of hours of my time on stupid crap like mysteriously walking P/S belt and burned out HVAC fan connector, plus swapping catalytic converter and bumper and tailights and door panels from parts car. I'm so mad I could spit. This was supposed to be a reliable daily but it's a piece of crap.
  11. #26
    Protege5
    Join Date
    Sep 2018
    Location
    DFW
    Posts
    62
    Quote Originally Posted by pcb View Post
    Yes
  12. #27
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Well...
    All I can think of that is cheap and easy is to spray down both sides of the connectors with electrical contact cleaner while plugging them in and out a few times to help scrape a better contact.
    Dielectric grease doesn't conduct electricity and the terminals could have a film on them.
  13. #28
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    Just for clarification sake, try a different 30 amp square fuse in the INJ fuse connector.
    They're kind of a weird fuse and might not look blown if is.
  14. #29
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    I found some specific info of what wires to test in the harness...
    Check for B+ on the "I" terminal W/G wire (white with a green stripe.) of the FB 03 connector (emission harness) that is plugged into the fuse box underneath.
    With the plug connected probe into the connector from the back and check for B+.
    I'm thinking the ECU won't call for power to the main relay control circuit unless there is power to the main relay.
  15. #30
    Join Date
    Jun 2011
    Location
    ontario, canada
    Posts
    4,836
    I'm thinking if you don't have +12 V on the W/G wire then you could splice in a wire to that wire, then to a fuse, then directly to the battery.
    That may send the B+ voltage through the W/G wire into the relay.
    You could test my hypothesis by just plugging a wire from the battery to a fuse to the W/G wire then test for B+ at the main relay.
    You would be essentially be bypassing the bad internal connection and using the backdoor to get power in.
Similar Threads
  1. How to test Fuel Pump Relay?
    By PowrSlave in forum Protege5
    Last Post: 04-05-2018, 01:03 AM
  2. where is the fuel pump relay on my 01 mp3 protege
    By eaguiar72 in forum Mazda MP3
    Last Post: 09-11-2014, 07:46 AM
  3. fuel pump relay
    By jbrewer4639 in forum Mazdaspeed Protege
    Last Post: 04-07-2011, 07:51 PM
  4. fuel pump relay
    By HONDA_KILLER in forum Mazdaspeed Protege
    Last Post: 01-20-2010, 06:41 PM
  5. Fuel Pump Relay
    By CantCMe in forum Mazda Protege
    Last Post: 10-20-2007, 07:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
