Results 1 to 6 of 6
Thread: Fill Up the Rear Bumper Exhaust Cut Outs with Stainless Steel
  1. #1
    Registered Member
    2018, Mazda, CX-5, Snowflake Pearl, Grand Touring
    Join Date
    Aug 2018
    Location
    Southern Arizona (40 Miles south of Tucson)
    Posts
    151
    A few weeks ago, someone on this forum submitted a picture of the rear of his
    CX-5 with larger than OEM, exhaust tips. Then, someone asked him for
    additional information. To my knowledge, none was forthcoming. I haven't
    been able to locate the original post. Perhaps someone else remembers it.
    Because I thought this mod looked so great, I decided to take it upon myself
    to locate a set of great looking Stainless Steel tips that would satisfy what I
    wanted to accomplish. I am totally satisfied with the results.
    These are top grade, double wall, stainless steel. They are quite heavy and
    the dimensions are perfect for what I wanted. The seller is in New Jersey with a
    link to his Ebay site below. The shipping was very fast.
    Cut off the OEM exhaust tips directly in front of them. Let the tips be the
    guide. Once you look under there,you will see how easy it will be. This
    will leave enough OEM exhaust pipe to mount the new tips. I used a Sawzall
    with a metal cutting blade for very fast work but you can use other types of
    saws also, either manual or powered. Clean off any inside burrs left behind.
    it will look better. Also, I sprayed the cut ends with black Hi Temp paint
    so that they will not show when looking inside of the new, larger tips.
    Our OEM exhaust pipe is 2" outside diameter. The inlet size of the new tips
    are 2 1/4" inside diameter. As a result, there is quite a bit of slop. I
    solved this minor problem by cutting about 12 equally spaced slots on the
    inlet end of the tip with a hand held cut off tool. I'm sure there are other
    ways to cut the slots. I do have a welder but am not proficient enough to
    weld these, due to the size differences. This method is tight enough that I
    have confidence they will not come loose. Of course, now that they are clamped
    down exactly where I want them, I can always weld them now. Maybe I will but probably not.
    The muffler clamp sizes I used were 2 1/8" which gave a really tight fit
    after being completely tightened. During the early stages of this tightening
    process, you can make any last minute adjustments you choose.
    https://www.ebay.com/itm/2-1-4-inch-...QAAOSwjytaYGil
    2018 CX-5 Grand Touring Snowflake White Pearl----2016 MX-5 GT Soft Top Ceramic White Metallic.
  2. #2
    Registered Member
    2018 CX5
    Join Date
    Jul 2018
    Location
    United States
    Posts
    137
    Looks great..should have come that way from the factory. I did this few years ago when I got my BRZ.
    Exactly how are the OEM tips attached to the exhaust pipe?
  3. #3
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    151
    Thanks.
    Yes, they should have come from the factory with these kinds of tips but glad they didn't. Now mine is unique.
    The OEM tips are welded.
    IMHO, these are, without a doubt, the most beautiful exhaust tips I have ever seen and the quality is superb. I suspect Mazda would never spend the money for something like this for an OEM build.
    The 4" diameter outlet is perfect for evenly filling the half round opening in the bumper.
  4. #4
    Registered Member
    Mazda CX5 GT
    Join Date
    Mar 2014
    Location
    Scottsdale, AZ
    Posts
    17
    This really looks nice. Excellent workmanship. Great job!
  5. #5
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    151
    Quote Originally Posted by AZJoeD View Post
    Thank you
  6. #6
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,820
    Blog Entries
    6
    Should those fit on a Gen 1 CX-5 as well?
    I'm thinking of selling my Racing Beat and putting stock back on with some aftermarket tips.
    http://www.racingbeat.com/CX5/Cat-Ba...sts/75200.html
    https://www.youtube.com/watch?v=1SprcadX7PM
    https://www.youtube.com/watch?v=Uth5ATwS324
    '15 CX-5 GT 2.5L w/tech package - 50K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
Similar Threads
  1. Replies: 8
    Last Post: 03-11-2015, 06:30 PM
  2. *New* Mazda OEM Stainless Steel Rear Bumper Guard CX-9 - SOLD
    By Suliman in forum Completed Transactions
    Last Post: 03-24-2014, 08:01 PM
  3. Installing the stainless steel rear bumper guard
    By tully in forum CX-9 Accessories & Appearance
    Last Post: 06-13-2010, 03:23 PM
  4. Stainless Steel Rear Bumper Guard
    By Gunga in forum CX-9 How-To
    Last Post: 05-15-2010, 03:30 AM
  5. Does anyone know what the "Stainless Steel Rear Bumper Guard" is?
    By SC300ES in forum CX-9 Accessories & Appearance
    Last Post: 01-14-2009, 07:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
