What maintenance would you suggest at 70000?
tkruger
2013 Mazda5 Sport
I have a 2013 Mazda 5 sport automatic. Done filters, oil etc. per the schedule or slightly before as stated in the manual. Is there any maintenance in-addition to that anyone would recommend at this point? Other than brakes, oil, filters and alignment nothing has been done since I purchased it 2 years ago with 13,000 on it. Asking now as end of October I plan to switch the tires to snows and will take a weekend to do everything at once on all my cars.
Drain and fill the transmission fluid if you haven't done so already. Check your power steering fluid.
At 70k, I did the belts because one was cracking
I also did brake fluid.
Had to do two door lock actuators also.
I have been doing trans fluid every 60k
I bought mine at 0 miles, it has 103k miles now
At 88k I needed new front shocks .
I replaced the brake discs and pads on my Mazda5, in the process, I also flushed out the old brake fluid and replaced that. So, even if your pads/discs are good, maybe you should look at flushing out old brake fluid. The old fluid came out kind of dirty and it had less than 75K on it.
Latest posts
