Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
Thread: Second Gen (2017 and up) CX-5 AA/ACP Installation Videos
  1. #1
    Registered Member Corbin628's Avatar
    2018 Mazda CX-5 Touring with PP
    Join Date
    Jun 2018
    Location
    CT
    Posts
    60
    I've created some videos documenting the process to install the necessary parts for Android Auto and Apple CarPlay in the second generation CX-5. The first video shows taking apart the interior, routing the cables and installing the new aux hub. Second video shows the process of putting all the trim back together. Do realize that version 70 of the firmware needs to be installed prior to installation of any new hardware. Enjoy!
    https://youtu.be/GYEaddWnbiQ
    https://youtu.be/8choSrR3f-M
  2. #2
    Registered Member 7eregrine's Avatar
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,891
    COURTESY OF ADAMOZ:
    For 2015.5 on-wards MAZDA CX-5 Genuine Car Play and Android Auto in their MZD/Mazda Connect Infotainment System.
    This upgrade KIT is NOT For 1st Generation Mazda CX-5 with TomTom in Dash Navigation System.
    Here again are the GENUINE Mazda Part Numbers for the required new parts..
    1 x TK78-66-9U0C AUX Hub Unit.
    1 x C9**-V6-605 USB Data Cable SET (2)...see READ-ME Warning.txt in Server in link.for your Part Numbers.
    Plus New NA N 70.00.021B FIRMWARE.
    or
    Plus New EU N 70.00.021A FIRMWARE.
    or
    Plus New 4A N (ADR) 70.00.021A FIRMWARE....NA at the moment!
    First,
    MUST Install new Firmware FIRST (with Old Parts still installed).
    Then you MUST Remove the Old AUX Hub and remove the Single USB Cable from old AUX Hub and up to the CMU Unit (under Display Screen).
    To remove these Parts you need to remove Console, Gear Lever Surround, Gear Lever Knob, Rear Console, Side Wall Panels at front of console under dash, and the Trims around the Touch Screen and Centre Air Vents, you then need to unbolt the Screen to access the CMU under the Screen to change over the 2 NEW USB Cables, which runs down to Newly Install AUX Hub.
    Once you have done this you can turn on ACC mode and CP/AA will boot up and Run.
    I REPEAT....
    YOU MUST Install new 70's FIRMWARE BEFORE you install the NEW Parts, those being new AUX Hub and 2 new USB Data Cables........ Your Old now Removed unused Parts MUST BE DISCARDED.
    Be VERY CAREFUL IF you buy ANY of these Parts from China Sellers at the Taobao Website as ALL the modules they currently sell are
    ALL OLD Stocks and are incompatible with the FIRST Official Release of 70's Mazda Firmware, You have been WARNED!
    This has all been tested and failed months ago, so don't think you know more as no NEWS is New News.
    .Pdf Installation Instructions of the 2 new USB Cables for all Mazda's can be found here in this link...
    https://my.hidrive.com/share/hsodpqj...Mazda_Firmware
    Mazda Parts Availability..
    Been told Parts Arrive @ Mazda Australia in August for a Release in September.
    Mazda Motors Europe has ALL parts available now from all Mazda Dealers in Europe and UK.
    Mazda USA has parts and some Dealer you can buy from, but limited stocks are ONLY meant for 2018 GL Mazda 6, More USA Stocks in December.
    Many owners will want their Mazda Dealer to supply and Fit CP/AA, it is about a 1.5 Hour job, a Dealer Install for Labor and Parts ??
    BTW: I am ASH8 from Mazda 3 Rev, Miata, RX-8 Forums.
  3. #3
    Registered Member
    CX-5 AWD, 2017
    Join Date
    Aug 2017
    Location
    Sweden
    Posts
    200
    Watching that video for most of the owners it seems to be an out of reach modification. I wonder how much Mazda is going to charge us doing that modification. I know that Hyundai had a similar upgrade for its owners and did not cost more than 100 US dollars.
  4. #4
    Registered Member
    2017 CX-5 GT AWD
    Join Date
    Dec 2017
    Location
    OH
    Posts
    835
    Quote Originally Posted by raj55 View Post
    The parts are $200 US, and likely 2 hours labor will be charged.
  5. #5
    Registered Member
    Join Date
    Jun 2018
    Location
    Los Angeles
    Posts
    42
    Corbin, you’re awesome. My local dealer has the parts and I’ll be picking them up Monday.
  6. #6
    Registered Member
    CX-5 Touring w/Premium
    Join Date
    Jul 2018
    Location
    KPTK
    Posts
    16
    Thank you for both videos!
  7. #7
    Registered Member
    Mazda CX-5 GS 2018
    Join Date
    Aug 2018
    Location
    Ontario
    Posts
    5
    I wonder if the cost would go down if we did the software upgrade ahead of time, then got the dealer to just do the hardware part... I can't see it taking 2 hours to do just the hardware part...
  8. #8
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,891
    Surely would.
  9. #9
    Registered Member
    MAZDA CX5 • AWD • GRAND TOURING • MACHINE GREY
    Join Date
    Jan 2018
    Location
    SoCal
    Posts
    75
    Quote Originally Posted by 7eregrine View Post
    COURTESY OF ADAMOZ:
    Broken link for the firmware in post: http://my.hidrive.com/share/hsodpqja.l#$/Mazda_Firmware
    Direct Link for parts (or your contact your local dealership): http://shop.mazmart.com/en/apple-car...kyactiv-models
  10. #10
    Registered Member
    Mazda CX-5 GS 2018
    Join Date
    Aug 2018
    Location
    Ontario
    Posts
    5
    surely would be less , or surely would be 2 hours :-)
  11. #11
    Registered Member
    Mazda CX5
    Join Date
    May 2018
    Location
    DE
    Posts
    23
    https://www.auto123.com/en/news/appl...-mazdas/65100/
    Supposedly 90 minutes and $445.
  12. #12
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,891
    Less. They charge an hour for the software install, which is ridiculous.n Not like someone needs to sit in the car for an hour while it loads.
    Quote Originally Posted by dero1969 View Post
  13. #13
    Registered Member
    2018 CX5 SE-L Nav+ 2WD 2.2D 150hp Auto
    Join Date
    Sep 2013
    Location
    Derby UK
    Posts
    398
    They need to be available to keep pressing the brake pedal every 25 minutes to stop the CMU going to sleep during the update which would then risk bricking it. The engine is NOT running during this process. I wouldn't rely on the tech going in and out of the car in between other jobs and remembering to go back in and press the brake pedal when required I've updated my firmware 3 times now and I read my Kindle when in the car and set my mobile timer to remind me to press the brake pedal. It has NEVER took an hour though even with the EU update which is larger due to all the different language information so they are still overcharging.
  14. #14
    2016.5
    Join Date
    Jan 2017
    Location
    CLE
    Posts
    4,891
    I have a hard time believing they are paying a tech to sit in your car to press the brake every 25 minutes.
  15. #15
    Registered Member
    Join Date
    Sep 2013
    Location
    Derby UK
    Posts
    398
    Why do you have a hard time believing it? This would be why they justify the high price for the update. (It doesn't mean I agree with it). The fact is that someone needs to be available to press the brake pedal every 25 minutes whether they sit in the car or remember to get back in the car to press the brake pedal when they've been doing other things. If they don't remember, they'll most likely brick the unit. I know what I'm talking about as I've carried out three firmware updates on my car.
Similar Threads
  1. 2017 led door Scuff/sill plate installation problem
    By sypher2012 in forum CX-5 How-To
    Last Post: 07-02-2018, 11:14 AM
  2. 2017 CX-5 OEM Crossbar Installation/Removal
    By jax14 in forum CX-5 Accessories & Appearance
    Last Post: 11-22-2017, 03:51 PM
  3. Replies: 35
    Last Post: 07-16-2017, 04:35 PM
  4. Replies: 1
    Last Post: 06-30-2017, 11:56 AM
  5. New Mazda 2017 CX-5 Videos
    By clads01 in forum CX-5 Lounge
    Last Post: 05-26-2017, 10:45 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
